Question about Mantis 2-Cycle Tiller
How do I remove the plastic flywheel from the Mantis Tiller SV-4/B type 1-E so I can replace a frozen bearing. All other internals seem fine so it would be well worth replacing the bearings but I can't get the flywheel off without damaging it.I don't have a puller small enough to fit this wheel and if I did I believe it would break the plastic anyway. I tried carefully prying with 2 wide screwdriver and it doesn't work. There is some wiggle to it but it just wont come off. Thanks for reading and special thanks to anyone who can help.
5 Suggested Answers
  • 12 Answers
SOURCE: mantis tiller sv-4 echo engine: no spark from coil
There are only 4 parts to the 2-stroke Mantis ignition system: the spark plug, the "kill button", the flywheel with embedded magnets, and the coil with integral plug wire. There are no "points" to clean or refurbish. If you've tried a new spark plug, unplugged the wire leading up the handlebars, and the magnets on the side of the flywheel are strong enough to attract a screw driver blade, then it must be a bad coil. That's all it could be. End of story.
Cruising the internet I see where these Echo coils go bad all the time. You can order the coil, but if the machine hasn't run in several years the carb will also need cleaning. So one thing leads to another. The gear box grease also needs replacing each year. What I'm trying to tell you is these are disposable tillers and due to length of time, incomplete care/ storage, ....whatever, this one's time is up.
Sorry.
Posted on Mar 21, 2009
  • 11 Answers
SOURCE: I Have a Mantis tiller that I can get NO spark
set the coil to the thickness of a dollar bill from the flywheel and tell me what happens. make sure kill wire isn't grounding somewhere else
Posted on Aug 04, 2009
panilling9
  • 284 Answers
SOURCE: what is left to do but change the flywheel?
check what they call air gap between the coil and flywheel .010-.012 gap
also be sure your flywheel is in time.
you will actually have to remove it to do this and check for the sheared key or be sure the key way aligns with the crankshaft keyway on the flywheel
Posted on May 26, 2009
  • 376 Answers
SOURCE: mantis tiller sv-4 echo engine no spark from coil
Sounds like it's flooding either from over choking or the inlet needle in the carb is leaking. Have you removed the plug and blown out the cylinder and plug with air and then tried to restart? Be careful not to keep cranking with the choke pulled out. When it 'hits' ONE time, move the choke halfway in and crank again
Posted on May 31, 2009
MANTIS TILLER WITH HONDA GX25 ENGINE STARTS FINE BUT WHEN GIVEN THROTTLE DIES OUT. ALSO A LITTLE WHILE BACK OIL WAS COMING OUT OF CARB BUT THIS HAS NOW STOPPED. THIS IS A 4 STROKE ENGINE WITH APPROX 4...
I also have Mantis tiller for 2 years. From the very beginning I had a problems. I was referred by Mantis to the repair store and was charged $90.00 for oil drainage. The second time I was waiting for handle replacement for ~ 1 month. This tiller can't handle even little jobs and the warranty doesn't worth a dime. Maybe I will be more successful using it in my living room . I have an equipment with Briggs and Stratton engines and I never had a problem.
To me Mantis mean big advertisement and waste of money.
Feb 20, 2011 | Honda Hmantis Mantis Garden Tiller with...
How do you compress piston ring in Mantis tiller to re-install
I make one with tin snips and a tin can or sheet metal from an air duct. Make sure you have the ring with the right side "UP", the beveled edge (if there is one) goes up or toward the head.
May 26, 2010 | Mantis Gas Mini Tiller/Cultivator, 2 -...
I need to find a place to buy parts for my mantis
Try this site.
http://www.alamia.us/SearchResults.asp?Cat=132
Eric
Jun 24, 2009 | Mantis Tiller
Mathis tiller sv-4 engine no spark form coil
clean and adjust the ignition points.
Jun 19, 2009 | Mantis 2-Cycle Tiller
Mantis tiller sv-4 echo engine no spark from coil mantis 2cycle tiller i got it running tryed to start it 4hrs latter same old problem wont start, plug wet with gas wont start. coil was checked by shop...
May 31, 2009 | Mantis 2-Cycle Tiller
What is left to do but change the flywheel?
May 17, 2009 | Mantis 2-Cycle Tiller
Pull cord stuck
it sounds like the recoil spring in the "housing" is jammed( or something is broken) youll have to take this apart without breaking it. you may have internal engine damage if it was unusually hot and the pullcord jammed. try using a richer oil mixture for fuel also if you fix the pullcord. hope this helps, keep me posted.
Apr 18, 2009 | Mantis 2-Cycle Tiller
Mantis tiller sv-4 echo engine: no spark from coil
Sorry.
Feb 26, 2009 | Mantis 2-Cycle Tiller
Mantis 2-Cycle Tiller Logo
574 people viewed this question
Top Mantis Garden Experts
paulfvincent
Matt Olenzek
Matt Olenzek
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
