Question about Samsung HL-P6163W 61" TV
Need help with blub - Samsung HL-P6163W 61" TV
  • Samsung Master
  • 8,457 Answers
Try You Tube,type in ur DLP tv model mnuber,and bulb replacement.There will have a tutoring video how to replaced ur DLP tv model of bulb.
Posted on Apr 27, 2010
Need to replace a primer blub on a tb70ss
contact Troy or Google the model number to see if you can find a service manual for this model.
Jun 16, 2012 | Troy Bilt Tb70ss Gas Trimmer
Dull picture how do I clean blub?
Its the small mirror in front behind the screen assembly needs cleaning. Dust gets the picture dim and dull looking.
Sep 22, 2010 | Mitsubishi WD-52525 52" Rear Projection...
HOW TO CHANGE BRAKE BLUBS IN A 1996 TOYOTA COROLLA
need to pull off the panels in the back of trunk area then u should be able to change out blubs
Mar 31, 2010 | 1996 Toyota Corolla
How do you change the headlight assembly?
for the most part you open the hood and turn the socket and pull the blub out if you have a autozone or any good part store and you get the blub from them they will help you install it for free wish you the best Michigan Man.
Nov 11, 2009 | 1997 Dodge Intrepid
Change headlight blub
The whole head lamp assembly has to come out to replace the headlight bulb. Here's how to do it.
Here is a link to instructions
http://autorepair.about.com/library/a/1i/bl808i.htm
Jun 18, 2009 | 2002 Jeep Grand Cherokee
Need Blubs for the Ionic Breeze GP
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;} You can purchase a bulb for the GP on ebay for under $11, which is really a good price considering what you would have paid from Sharper Image. Installation is easy, you just pull up on the tab on the bottom of the filter and pull up. When you are looking at the bulb, turn it 1/4 turn, (2 clicks) and pull it out. That is all there is to it. Item Number: 220444965077
May 24, 2009 | Sharper Image Ionic Breeze GP SI730 Air...
How can I change the headlight on a 2001 optima
You may have to take out the battery, there are 2 round gray colored covers that screw out located in front of your battery that correspond to the location of the head lights, one is for the high beam and the other is low beam. once the covers are off, unplug the wire that is attached to the blub, there is a retainer spring that holds the blub in, take each side and push down and out and the blub should come right out. be careful not to touch the new blub with your fingers, only touch the base.
Jan 04, 2009 | 2001 Kia Optima
Replacing a headlight
go to your parts store and purchase the new halegeon blub. READ very carefully the instructions on the box. DO NOT TOUCH the new blub lens.
Carefully pull and twist out the old blub and remove it from its base. Using the special material or a glove, install the new blub in the base, and then carefully insert it back into the headlight shell.
Bill
Nov 18, 2008 | 2004 Buick Rainier
1990 Buick Lesabre Custom
You will need to include more information. !. Are you referring to the turn blub in the dash or the bluds mounted in the body of the car. If in the body of the car, you need to indicate whether it is front or rear.?
If the rear, open the trunk, and in the corner nearest the tail light you will see a cloth like material that can be pulled back, which will uncover the tail light assembly. From there you can remove the blub and holder by turning it to the left or right, pull it out and remove the blub.
Bill
Oct 25, 2008 | 1992 Buick LeSabre
Samsung HL-P6163W 61" TV Logo
Henry  Thomas
Henry Thomas
