Question about Hitachi 53FDX01B 53" Rear Projection Television
Top half of screen is double vision and green and purpule.
  • Hitachi Master
  • 8,457 Answers
Ur tv have convergence problems,it dead.U must know how to solders?U must replaced 2 STK convergence ICS and some or all it resistors.Tries websites like Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Posted on Apr 27, 2010
I own a Panasonic HDTV projection monitor PT-47WX42C I am having convergence/warping issues; There is a large green/red curve in the bottom rear of screen about 4 inches tall, and stretching over more...
Replace the convergence ICs they will be big black ICs and will have Part number on them example STK392-110
Mats Electronics has them for 9.95 each you will need 2 .
1-800-628-1118
Sep 10, 2010 | Panasonic PT-47WX42 47" Rear Projection...
Hitachi ultra vision green and purple double vision picture about
Convergence is out, need convergence board repaired, usually bad stks, 392-110s
Jun 07, 2009 | Hitachi 60V500 60" Rear Projection...
Double vision on tv with purple and green colors
This television set, as well as most rear-projections, is prone to convergence driver problems. There are two large chips (STK392-110's) in the TV that need to be replaced, as well as some resistors that are likely damaged as well. Any competent TV repair shops should be able to repair this TV for 200-300 dollars. It is important to note that if the back of the TV is taken off without the proper prep., the Digital input (DVI) will be disabled permanently.
Hope this helps you...
Dec 30, 2008 | JVC AV-56WP74 56" Rear Projection...
Red and Green double vision
Depending on the age of the unit. You have a convergence problem. This is not uncommon. You can contact a servicer thru this homepage and have them look at it. Convergence issues could be anywhere from 200-350 depending on your area.
Dec 17, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
DOUBLE VISION AT TOP OF MY SCREEN. DISTORTION.
Good Day, wars;
You may have a poor seated cable connector. Unplug TV from A/C, remove back look for a large black connector. It connects between the Main Digital Module and the Drive PWB. Re-insert both ends several times to make better contact, use contact cleaner if have but not always needed. Good Luck, big IRISH.
Sep 04, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Double- Vision
More than likely your akai has defective stk392-040 Convergence chips . it also may have open resistors generally 3.9 ohm flame proff. this board is attached to the top left looking from the back of the set it is screwed on by 1 screw black in the center . after installation this will probably half to be converged dinamically. which means you will half to get to the grid this is done by using the remote press mute 183 quicly to enter numbers on thew remote 2 to adjust red 4 to adjust blue horizonta 6 to adjustred vertical and 8 to adjust red vertical using center button to go up and down
Feb 20, 2008 | Akai PT4298HD Rear Projection Television
Yellow at the top, double vision, blurr
Good Day, turott1;
You need repair in the convergence circuit, purchase KIT 10. You can buy this at B&D ENTERPRISES, at 1-800-458-6053.
Dec 30, 2007 | Hitachi 50UX26B/27K 50" Rear Projection...
Hitachi 53FDX01B 53" Rear Projection Television Logo
275 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
