Question about Kenmore 15899 Built-in Dishwasher
Kenmore Mod# 15812990. the thermal fuse inside the door panel blows during the rinse cycle, help please
  • ronnied44 May 04, 2010
    FixallPhil, Followed your suggestion of replacing the wires & fuse. I also cleaned all the terminals on the door switch. The foam seal around the vent were in place. Aslo did not notice any discoloration on any of the terminals on the control board. It started up OK and completed the cycle as it has before. I would like to keep this communication oper until we have ran a few cycles thru the unit, probably will be a couple of weeks from now. Thanks for response and hope it works.
    Ron,
    President:
  • 949 Answers
The thermal fuse blows due to over temperature. In almost every case where it blows it was due to a poor wire connection to the thermal fuse or a wire connection on the control board, or lastly on the door switch.
The thermal fuse should come with a small wire kit. Be sure to use this kit when replacing the fuse so that the wire connections to the fuse are tight and will not over heat when the machine is drawing the most power (typically in the heated wash or rinse). Look closely at all the wire connections to the control board and door switch, if any are discolored clean and tighten the connection.
Lastly on the left side of the console is the vent for steam, make sure the foam seal is in place around that vent so hot vapor is not migrating to the board area causing too much heat.
Let me know if you need more help on this.
Posted on May 04, 2010
  • Philip May 04, 2010
    Hi Ron,
    Yes, it is fine to leave this open and if you have questions you can respond here and when I am on I will be happy to address them.
    This repair is a troublesome one for many technicians, but I have had pretty good luck when replacing or tightening the wire connections around the t-fuse.
I have a Kenmore 800 model no. 110.69822801 dryer that stopped during a drying cycle. It would not start. I found helpful tips from your site and decided the door switch was faulty. I bought a new switch...
Check the thermal fuse, check the belt switch. If these are OK, check the timer. The timer troubleshooting guide may be located within the control panel. If the dryer still doesn't turn on, check motor winding continuity, and finally control board. Perform these checks with dryer unplugged. Most likely causes: Thermal fuse or timer. If thermal fuse is problem, clean dryer duct after fuse replacement.
Dec 18, 2014 | Kenmore Dryers
CL error code appeared during cycle
make this test and fix it. Merry Christmas
Power From The House
Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the switch
Thermal Fuse / Thermal Cut out
On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel or behind the front panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing or is sometimes round and made of metal and plastic.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replace the fuse this is the most common reason for blowing the fuse. (You can't re-set this type of fuse.)
Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Main Control
The main control board may have failed. To check this check the two main feed leads entering the control refer to the tech sheet located on your dryer. The two leads are usually a separate plug of heavy wire. Check to see if power is entering you should have 120 volts. If not the problem is not the control. If you have power coming in and nothing is illuminated the main control faulty, replce or the Timer will be replace
Dec 17, 2013 | Kenmore 4.3 cu. ft. High-Efficiency...
Knemore Series 80 Dryer - Blows Thermal Fuses, Humming Noise
The heating element is shorted to ground. You will need to replace the heating element and the thermal fuse, both available at the link below.
Heating Element $40.77
Thermal Fuse $6.99
Mar 02, 2012 | Kenmore Dryers
I have a Kenmore Series 70 Dryer and I changed the thermal fuse got hot for a few minutes the model #110.74722400
The cycling thermostat must also be replaced when replacing the thermal fuse. The cycling thermostat's failure to cycle off the heating element results in overheating of the dryer which consequently blows the thermal fuse open.
Replacing only the thermal fuse should the dryer stops running and fails to start will result in its premature blowing or even the thermal cut-out (cut-off) located on the heater duct. Like the cycling thermostat, the high-limit thermostat must also be replaced once the thermal cut-out blows open. Refer to the parts diagram in the link below and look for item numbers 31(thermal cut-off), 34(hi-limit thermostat), 39(thermal fuse), and 41(cycling thermostat.
Kenmore Series 70 Electric Dryer (110.74722400) Bulkhead Parts
Aug 21, 2011 | Dryers
+I can select a drying cycle, panel lights go on, but when I close the door and push start I get a series of beeps and the cycle will not begin.
Hi
The issue seems to be either with the Thermal fuse which is located inside the rear panel to the exhaust duct or the control board itself has gone bad. You can take a voltmeter and check the thermal fuse for continuity, if it is open then replace the fuse else the control should be replaced to solve this issue. Hope this helps...please post back for further assistance.
Daniel
Dec 08, 2010 | Kenmore Elite HE4 Electric Dryer
My Whirlpool GU2400XTP dishwasher keeps blowing the fuse. It sat up for 6months because the control panel went out and I couldn't afford to get a new one. Finally replaced the panel and the thermal fuse...
Are you replacing the wires along with the fuse? It is important to change the wires too as they are usually the cause for the fuse blowing. Be sure and get the fuse kit that includes the wires.
Is your water too hot? Hot water is fine but too hot of water can cause the fuse to blow over time. The temp should be somewhere around 120 F. Anything over 130 F is way too hot. I personally don't use a long high steam final rinse or high heat because over time the steam and cause the electronics to short as steam and moisture can get into the keyboard and inside panel.
Apr 04, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
My simpson eziset 550 washing machine just stopped during a rinse cycle all the electrics are out, can i fix this myself?
Replace the fuse inside the control panel make sure you turn if off.
depending on where you are the fuse is more than likly a "4amp slow blow" fuse
hope this helps
Feb 24, 2010 | Washing Machines
Dryer will not start
If your dryer doesn't work at all, it could be because of problems with:
Power from the house
Door switch
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Apr 01, 2009 | Kenmore Dryers
Dryer not going to cool down cycle, thermal fuse failed 2x
Most problems like this arise from air flow problems. You need to break down the dryer and clean out the lint. Including removal of the filter housing.making sure your outside vent is clear as well.If that fuse keeps blowing you especially need to remove and rinse out that filter housing.
Dec 30, 2008 | Whirlpool LER4634J Electric Dryer
Kenmore series 80 washing machine mod.# 11026842692
could be a broken 2nd rinse switch. contacts would not open up.
the noise could be coming from the gears inside the timer slipping.
if it is a kenmore, usually, it has these plastic cover on each side of the control panel. pry it slowly and lift it to exposed a screw that is holding the panel.
tnx 4 using fixya,
drcool
Oct 21, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 15899 Built-in Dishwasher Logo
78 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
