Question about Asrock K7VT4A-Pro Motherboard
Im wanting to know if the K7vt4a motherboard supports dual channel memory
    Genius:
  • 1,066 Answers
No, it does not support dual channel memory
Posted on Jun 19, 2010
I have intel 915 GLV mother board and 256mb ram, now i want to upgrade my ram to 1GB. please let me knw what kind of RAM i need to buy along with its image details.
Intel Desktop Board D915GLVG - motherboard - micro ATX - LGA775 Socket
Max Supported Memory 4 GB Supported RAM Technology DDR SDRAM Supported RAM Speed 400 MHz, 333 MHz Supported RAM (Registered or Buffered) Unbuffered RAM Features Dual channel memory architecture
Aug 10, 2011 | Intel D915GLVG Motherboard
Not recognizing memory.
The Asus P4S800-X MB can use Dual channel DDR memory and single channel memory. The dual channel memory which comes in matching packs. (Normally 2 DIMMS per pack) is the faster memory.
In other words if you are installing, 4- 512MB DIMMS of PC3200 all memory should be matched,
or you're MB may not see all connected DIMM'S.
See page vii in you're manual. If you're running windows XP, Home or Pro edition the bios will show up to 4GB of memory installed but windows XP 32bit will only show 3GB of memory. As mentioned above all 4 of you're 512MB of memory should be dual channel and run at the same speed. You can run both single channel and dual channel but you must follow Table 1 in you're manual. (1-9).
Example; PC3200 400MHz.
Or 4-512MB PC2700 333MHz. See page 1-9 for memory configurations and the QVL list supported.
Check out Asus FAQ's; http://support.asus.com/faq/faq.aspx?SLanguage=en-us&model=P4S800D-X&product=6&os=17
This should help you configure the memory.
Mike
May 09, 2010 | ASUS P4S800D-X Motherboard
Why can not I connect to the Dual chanel memory in the GA-K8NF-9
Supports Dual Channel DDR400 memory architecture. And up to 3 gb support in winxp32 bit. 4 gb support in winxp64 bit.
Dec 11, 2009 | Gigabyte GA-K8NF-9 (890552602964)...
HOW TO FIND RAM CAPACITY OF INTEL D102GGC2
Intel D102GGC2 Motherboard Each memory slot can hold DDR2 PC2-5300 with a maximum of 1GB per slot.*
Maximum Memory Capacity: 2048MB
* Currently Installed Memory: 512mb Number of Banks: 2
* Dual Channel Support: Yes
* CPU Manufacturer: GenuineIntel
* Although the memory can be installed one module at a time, the best performance comes from using matched pairs of modules.
Your MotherBoard Supports up to 2GB of memory.
You have 512mb, you can add 512mb to the empty slot.
, however,It's a good idea to keep them the same if you can.
You can install memory that is: DDR2 PC2-5300 (PC2-5300 is 667Mhz) you can use 1gb memory in each module for best performance and matching pairs since your motherborad supports dual channel.you can use sound card and SATA hard disk for higher disk support
Mar 15, 2009 | Intel D102GGC2 Motherboard
I have A am 37 mother board can i use dual channel ram in it
Your board supports two memory sticks totaling 2GB. (1GB each) It supports "PC2100 DDR" and "PC2100 DDR266" (Dual Dynamic RAM) DIMM modules.
Mar 14, 2009 | FIC AM 37 Motherboard
Does ASRock 775i65GV supports DDR2 memory?
No only DDR upto 2GB supported by your motherboard...
Dec 08, 2008 | Asrock 775i65GV Motherboard
DDr or Dual Channel Ddr
From the manual:
2 x 184 pin DDR DIMM Sockets support up to maximum 2 GB unbuffered PC 2700/2100/1600 non-ECC DDR SDRAM memory.
So, to answer your question, for your particular motherboard, no. However, to dispute the other poster, Dual channel is better than regular DDR. It's just your motherboard does not support it.
Jul 03, 2008 | ASUS A7V400-MX Motherboard
K7VT4A-Pro Mobo
Greetings,
The motherboard will read 1GB DDR400 memory per slot only.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jun 19, 2008 | Asrock K7VT4A-Pro Motherboard
Ram support
As much as I would love to spend a couple hours making you a list of Ram that your board supports, not happening.
However you can do this your self by looking in your manual.
Download your manual here:
http://www.giga-byte.com/Support/Motherboard/Manual_Model.aspx?ProductID=1863
Go to the top of page 15.
Your board requires a voltage of no more than 2.5v
GA-8IPE1000 Series includes 4 DIMM sockets, and each Channel has two DIMM sockets as following:
Channel A : DDR 1, DDR 2
Channel B : DDR 3, DDR 4
If you want to operate the Dual Channel Technology, please note the following explanations due to the
limitation of Intel chipset specifications.
1. Dual channel memory cannot be used if one DDR memory modules are installed.
2. If two DDR memory modules are installed (same storage capacity), one must be added to the
Channel A slot and the other in the Channel B slot in order to use dual channel memory. Dual
channel memory cannot function if both DDR memory modules are installed on the same channel.
3. If four DDR memory modules are installed, please use memory of the same storage capacity in
order to use dual channel memory and for BIOS to detect all the DDR memory modules.
We'll strongly recommend our user to slot two DDR memory modules into the DIMMs with the same color in
order for Dual Channel Technology to work.
You board supports this type of memory:
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=80097-16
Or
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1717669&CatId=1352
Good Luck & kind Regards.
& please vote.
Mar 16, 2008 | Gigabyte GA-8IPE1000-G (MBGA81PE1000G)...
Dual channel problem
Is the 2 GB of memory in two identical 1GB sticks? what slots are they installed in? Check to make sure they are installed in slots 1 and 3 (usually - I dont know what motherboard you are using.), and the motherboard is enabled to dual channel mode .
Mar 15, 2008 | Computers & Internet
Asrock K7VT4A-Pro Motherboard Logo
Top Asrock Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Computer Links
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
