Question about Garden
Hi, I have a honda 13.5 twin cut ride on mower. It's about 5 years old. I used it 2 weeks ago no problem but I tried to start it yesterday but it wouldn't start. The battery is full as a charged it again yesterday and it onlt took a few minutes. The key is turning to position one and the yellow light is coming on. But when turning to position 2 there isn't a peep out of it and the yellow light flashes. The blades lever is disengaged but in position at the back, battery connected properly, brake off, spark plug dry, full of petrol, full of clean oil. Can you help? Garreth
  • garmaybury Apr 27, 2010
    The battery is full and wasn't drained. It nothing obvious so need another solution.
    Hi, I have a honda 13.5 twin cut ride on mower. It's about 5 years old. I used it 2 weeks ago no problem but I tried to start it yesterday but it wouldn't start. The battery is full as i charged it again yesterday and it only took a few minutes. The key is turning to position one and the yellow light is coming on. But when turning to position 2 there isn't a peep out of it and the yellow light flashes. The blades lever is disengaged but in position at the back, battery connected properly, brake off, spark plug dry at external connection, full of petrol, full of clean oil. Can you help? Garreth
    President:
  • 2,468 Answers
Put the brake on,then check the seat safety switch and make sure it is being fully depressed to make contact(check with a continuity tester) that yellow flashing light is a warning that something isn't in the correct position to safely start the macnine,also make sure the transmission is in neutral,wiggle the transmission lever when trying to start it,there is a safety switch in the tranny to keep it from starting if in gear accidentally
Posted on Apr 27, 2010
    President:
  • 1,619 Answers
If the spark plug is dry sounds like maybe the fuel cut off is still shut? If you try and start the plug should be at least wet if its not firing but turning over. If it is not turning over the battery may be drained from something being left on or just has a bda cell. Try and charged it or replace the battery.
Castlegarden twincut ride on lawn mower cutting out
some engines have a low oil level sensor yes. ck. oil level
Jun 02, 2013 | Garden
Western lawn mower
Your mower could have been sold by Western Auto many years ago. I have no idea who manufactured it for them
May 28, 2013 | Garden
I have a Bush Hog zero turn mower with a Honda GVX620 V Twin engine. When it had less than 5 hours on it it ran fine after mowing and but the next time i tried starting the mower it flooded badly enough...
It very well could be the vent tube. I suggest you remove the air filter and air filter cover. On the left side of the carburetor is a vent tube. Remove the vent tube and try gently blowing into the tube. If you are unable to blow without restriction, the tube is blocked. Clear the block with compressed air if that is available. Reattach the vent tube, the filter cover and the the filter and you will be pleased to discover the flooding issue is resolved. This is a common problem with this engine. Newer versions have an internal vent and do not have the same issue.
Jun 10, 2012 | Garden
The mower is about 5 years old. The batterY is two years OLD and the tractor will start with a jumper battery box. When I try to crank the engine, the starter sounds like its binding but after a few...
Not necessarily the battery can be weak with a small internal failure and can cause the issue of shorting out and not staying charged. This is very common on small batteries for these mowers. The replacement batteries you get at the hardware stores are the worst culprits for going bad after just a year or 2. The main battery that comes with the tractor are usually much stouter than the replacements. Before we tear intot he charging system I would suggest a new battery or hook up a temporary car battery if you have one to see if the guage acts up, or if you have a volt ohm meter test the charging system by reading the battery as it is running. It should be between 13 and 14 volts if it is worrking correct. You can also use the old stanby tried and tested method of pulling the positve cable off the battery after the mower has been started and see if it stays running. This will give us a base to proceed from. Let me know what you have tried and what you find.
Nov 03, 2011 | Garden
Poulan 38" riding mower.
Battery is likely dead - or has built a sediment bridge - shorting the anode and cathode.
Jump-start the tractor with your vehicle - or another battery to check.
Or - use a multimeter to ensure your battery is not draining to 0V when you attempt to start.
This also indicates a failed battery. It may have a decent float charge - but when the load starter) is applied - the voltage will drop right out.
Thanks for using FixYa!!
Aug 03, 2011 | Garden
I have a Z445 with a Briggs & Stratton 23 hp V twin, the air filter will not seal, lets trash into engine. It smokes, uses lots of oil. Can I put a Honda or Kohler on it, don't want another B &...
Hi, yes you can. You will need to take the model, type and code numbers with you to a Kohler or Honda dealer. Either will have a listing on an equivalent engine. Regards Phil.
Apr 30, 2011 | John Deere 23HP VTwin Dual Hydrostatic 48"...
I have a craftsman Dlt 3000 riding mower with a 20hp kohler v twin . engine starts and runs for 5 seconds and shuts off
no model # on my DLT3000. Replaced rear fender a few years ago where the model # used to be. I can't get the right parts w/o model #. It was by my dad sometime between '04 and '07. It's red w/42" cut, 20hp koler pro motor.
Sep 18, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Engine drags while trying to start
It may be a problem with the camshaft-compression release. Some of the Briggs & Stratton models had a weak spring on the compression release whis is parts of the camshaft. you may also want tocheck that all wires are clean and tight. Also if it's a over head valve model check the valve clearance.
Jan 26, 2009 | Garden
Craftsman 247 88190 0 snow blower auger frozen
my auger and impeller froze too. fixed by clearing all snow, ice,stone build up behind impeller it works fine now.. hope that helps
Jan 19, 2009 | Ariens 34 In. Zoom Series Riding Mower
Garden Logo
19 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
