Question about Pioneer DEH-P3500 CD Player
Pal007a is the replacement of pal007c? - Pioneer DEH-P3500 CD Player
Purchased focus sport 2006 model no service manual. Mileage 43,000 kms. Need to know service intervals either time/mileage perhaps a copy of the service schedule will suffice.
These maintenance intervals come from the maintenance interval calculator
at www.autozone.com, using a starting point of 25,800 miles (43000 km), and
assuming 1000 miles (1666 km) driven per month, and "severe driving conditions," which
are actually normal usage characteristics, such as frequent short trips, urban driving, waiting in traffic, driving in hot weather, trips under 16 km in cold weather, etc.
STARTING MILEAGE: 25800 (43,000 Kilometers)
Item
Action
Service History
20000 miles or 32000 kilometers
Battery Check
Oil Filter, Engine Replace
Engine Oil Replace
Vehicle Inspect
Brakes and Traction Control Inspect
Tires Rotate
21000 miles or 33600 kilometers
Steering and Suspension Lubricate
Engine Oil Replace
24000 miles or 38400 kilometers
Engine Oil Replace
25000 miles or 40000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
27000 miles or 43200 kilometers
Engine Oil Replace
30000 miles or 48000 kilometers
Battery Check
Air Filter Element Check
Wheel Bearing Lubricate
Fuel Filter Replace
Engine Oil Replace
Fluid - A/T Replace
Cabin Air Filter Replace
Vehicle Inspect
Cooling System Inspect
Wheel Bearing Inspect
Ball Joint Inspect
Drive/Propeller Shaft Inspect
Exhaust System Inspect
Steering and Suspension Inspect
Heat Shield, Exhaust Inspect
Tires Rotate
33000 miles or 52800 kilometers
Engine Oil Replace
35000 miles or 56000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
36000 miles or 57600 kilometers
Engine Oil Replace
39000 miles or 62400 kilometers
Engine Oil Replace
40000 miles or 64000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
42000 miles or 67200 kilometers
Engine Oil Replace
45000 miles or 72000 kilometers
Battery Check
Fuel Filter Replace
Engine Oil Replace
Vehicle Inspect
Ball Joint Inspect
Tires Rotate
48000 miles or 76800 kilometers
Engine Oil Replace
50000 miles or 80000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
51000 miles or 81600 kilometers
Engine Oil Replace
54000 miles or 86400 kilometers
Engine Oil Replace
55000 miles or 88000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
57000 miles or 91200 kilometers
Engine Oil Replace
60000 miles or 96000 kilometers
Battery Check
Fuel Filter Replace
Spark Plug Replace
Fluid Filter - A/T Replace
Engine Oil Replace
Fluid - A/T Replace
Vehicle Inspect
Ball Joint Inspect
Tires Rotate
63000 miles or 100800 kilometers
Engine Oil Replace
65000 miles or 104000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
66000 miles or 105600 kilometers
Engine Oil Replace
69000 miles or 110400 kilometers
Engine Oil Replace
70000 miles or 112000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
72000 miles or 115200 kilometers
Engine Oil Replace
75000 miles or 120000 kilometers
Battery Check
Fuel Filter Replace
Engine Oil Replace
Vehicle Inspect
Ball Joint Inspect
Tires Rotate
78000 miles or 124800 kilometers
Engine Oil Replace
80000 miles or 128000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
And you can continue the pattern from there...
May 14, 2011 | Ford Focus Cars & Trucks
No sound from Pioneer DEH-P4600MP unit? Everything powers up and function,wires are installed correctly.
check the speakers to see if they work. also check if the vehicle has an amplifier. if still no sound try to connect the radio directly with a speaker in the back with the wires that come with the radio. sometimes when one of the speakers in the vehicle is shorted out it will not sound. if you have tried all of the above and still no sound you might have a bad (ic) intergrated circuit. it is located on the back end of the radio. the aluminum piece is bolted on to it. just look where two bolts are at least an inch apart almost in the middle. the ic# is pal007a. that can be replaced with different model numbers like tda 7384 and so on.
Sep 22, 2009 | Pioneer DEH-P460MP CD Player
PIONEER DEH-P86DHR NO SOUND!!
With these units, the internal amplifier is an IC that fails sometimes. It can leave the rest of the unit working ok, bit will have no audio. There may be audio from the line level RCA's but not from the speaker outs. Smell the back of the unit to see if it smells burnt. Most of the time it will, but not always. The IC is usually something like a PAL007a or similar. If you are good at soldering, you can order the part, and change it yourself. If not, you will need to seek a technician to replace the part. You may also try an external amplifier and RCA's instead of fixing the IC.
Jun 15, 2009 | Pioneer DEH-P86DHR
I have the deh p8000r has no sound
Usually with this model, when all else works, and there is no sound, the internal amplifier IC is blown. Smell the back, and see if it smells burnt. It may. It does not always tho. The IC is a PAL007a or something similar. It's kinda hard to replace if you aren't skilled with soldering, but it can be done by any decent repair shop. Also, test to see if there's a signal on the RCA's, if there is, you can forgo the internal amp, and get an external one. (it will require running speaker and power cables, but if you really like the head unit...;-)
Jun 09, 2009 | Pioneer DEH-P8000R
I've a Pioneer DEH-P8400MP. I get no sound out of the ISO speaker connector, only out of the RCA outputs. This told me that there was a problem with the IC Amplifier (a PAL007A I believe). A quick check...
no it isn't obsolete and there are replacements and cheater replacements. the pal 006a,pal005a,tda 7856/7854,7386,and the cheater one that will work and you already probably have is the ic from an original delco radio off of a chevrolet radio. but it will not have a remote wire to it.
Apr 02, 2009 | Pioneer DEH-P8400MP CD Player
Locating a PAL007A
Just get the
TDA7386 and thats all... I think it should not be the problem to get that one.
Apr 02, 2009 | Pioneer DEH-P3500 CD Player
Pioneer deh 1600
Maybe you make a mistake and burn out the audio amplifier IC and you gotta change it.
Jun 12, 2008 | Pioneer DEH-1600 CD Player
No Sound
if the att is on it will show it on the display it's more likely to be the internal amplifier that needs replacing which is a PAL007A ic
Nov 15, 2007 | Pioneer AVH-P5700DVD Car DVD Player
Pioneer DEH-P3500 CD Player Logo
816 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
