Question about Tomtom ONE GPS Receiver
Turn on and shows me to remove card i do and then put back as requested. keeps going round on a loop and will not let me in
  • 67 Answers
You need to update the software via tomtom home
Posted on Apr 28, 2010
Why does my sd card does not go into the camera properly, I just removed it and want to put it back but it wont go in?
The card will only fit in one way. The end with the gold-coloured contacts goes into the slot on the camera. if it will not fit in easily, then turn it round, so the label faces the other way, and try again. If you still can't get it in, make sure there is no obstruction within the card slot on the camera.
Jan 20, 2016 | Polaroid i1237 Digital Camera
I have a 89 buick electra 98000 miles I failed emissions for high co at idle I put a obd1 tester on it it showed vehicle was not going into closed loop I replaced oxygen sensor it then went into closed...
to stay in close loop o2 sensor have to be hot
and the converter catalyst is the one who keep the heat......
converter is it factory or never been change.
with scanner obd1 you should see the voltage variation of o2 sensor. it should go from lean to rich . .500mv is the middle then under .500mv is lean and over it is rich.......with this information ecm correct the fuel delivery
hope it helps
Sep 29, 2013 | 1989 Buick Electra
Need manual to put back ball and spring back into the gun triger housing .
You may have to contact Titan and request an assembly diagram.
Jul 18, 2017 | Air Tools & Compressors
How can iget the belt back on my turntable pioneer pl 990
PUT IT ROUND THE PLATTER BASE FIRST,THEN LOOP A BIT OF STRING ROUND THE BELT LONG ENOUGH, SO WHEN YOU PUT THE PLATTER BACK ON,YOU CAN LIFT IT UP A LITTLE BIT WHERE THE MOTOR WHEEL IS THAT TURNS THE BELT, PULL THE STRING TOWARDS IT SO THE BELT GOES OVER IT.DROP THE PLATTER THEN PULL THE STRING OUT.
Mar 31, 2011 | Pioneer PL-990 Turntable
Polaroid Model a815 just bought yesterday: I took pictures with it and turned it off to get another item to photograph. When I turned it back on I got "Card Error" then a screen to Format Card:...
As you only bought it yesterday, take it back to the vendor and request a demonstration to your satisfaction. This looks like a fault, assuming so, request a replacement under warranty.
Normally, all of these camera's are straight forward to use, except perhaps Casio.
Sep 06, 2010 | Polaroid Cameras
Phone is on but no go to in only nokia show on display
It seems that your phone is not able to boot up.
Remove the batteries and keep it for say 20 minutes. Now reconnect the batteries and turn on the phone.
Rate it, If it helps.
Jun 24, 2009 | Nokia N70 Cellular Phone
How to fit a belt to a wf440p washing maching
remove the top cover and lower rear cover. loop the belt over the motor shaft and then around the drum pulley, this will probably only go round halfway as it is tight, hold the belt to the pulley by turning it rather like putting on a bicycle chain.
when it's on make sure it runs centrally round the pulley adjusting the position on the motor shaft if needed.
Jan 26, 2009 | Hotpoint Aquarius WF000 Front Load Washer
How do i insert the simm card?
most sim cards are located under the battery. remove the back of the phone, then remove battery, you should see a place for the sim card, just slide it in but make sure you put it face down and the right way round, theres usually a little diagram showing the correct way
Sep 06, 2008 | Cell Phones
Removing maxi-cosi priori cover
under the strap that is just below the grey round plastic length adjuster there is a stiched loop. Pinch the stiched loop and you will see that it can be removed.
Sep 06, 2007 | Maxi-Cosi Priori
Tomtom ONE GPS Receiver Logo
61 people viewed this question
Top Tomtom GPS Experts
k24674
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
