Question about LG DR275 Recorder
No sound after recording from external input
I've recorded something from my video camera. But when I try to play it, I only have the video, without any sound
How can this be fixed?
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
Well, my video camera has separate hookups for the video, and the audio. The audio is a stereo mini-jack (I think that's what it's called) - and I use a cable that has the mini plug on one end, and a white and red RCA plug on the other end for each channel. Perhaps yours is the same?
Posted on Apr 06, 2008
SOURCE:
No audio after recording from sat. Reciever
Double-check your input cables from the receiver to the LG 389. Do you have the sat. receiver AV out connected to the front AV In on the LG DRT389? Make sure that you haven't mixed up the L and R audio connections on either side. (I've done something similar with RCA cables myself.) Next, try a different set of cables.
If that doesn't work, there may be a problem with the audio jacks on either your receiver or the 389. To check, plug the AV cables from the Sat. Receiver directly into the TV. If you have sound and video, then the input jacks on the recorder may be damaged.
Try using another input. (It looks like some models have the SCART input; you may need to set the input source in the menu under AV2 Decoder.)
The fact that you have audio output on USB and DVD's means that cables/connections between the LG289 and the TV are fine.
I hope this helps. Please add a comment with the details of which AV port you are using on the LG389 for additional assistance.
Aug 31, 2012 | LG DR389 MULTISYSTEM DVD RECORDER FOR...
My Canon PowerShot SD300 was recording sound perfectly a few days ago. Now whenever I record a video and play it back there is no sound except for static. I have resetted the settings to factory defaults...
When you play the video back and get no sound are you doing this on your camera or on the computer? I have the same camera, and noticed that when I playback something I've recorded I don't have sound either, mind you I don't have static either. But once I've uploaded the video onto my pc the sound is there.
Jul 29, 2011 | Canon PowerShot SD300 / IXUS 40 Digital...
I go to record and it looks like it is recording. But when I play back nothing is there. It is doing this on all of my tapes.Tried viewingan old tape but when played back nothing is there,
You could try slaving the camera out to an external screen if you have the cables, you should find a RCA output socket on the camera marked video out (commonly known as a phono)normally yellow also a couple of audio out sockets one red and one white.
If you plug the yellow one into an external monitor you will see if it's the camera LCD screen that faulty.
Also check the iris is not turned down when playing back or recording this can happen if the camera is set to manual.
Set the camera to automatic and try again.
It sounds to me that the iris is closed, if the head drum is spinning you should get something even if it's random signal noise denoting clogged heads anyway the camera would flash up a clogged head icon so first as check the iris.
Sep 13, 2010 | Canon ZR-950 Mini DV Camcorder
How do I turn the audio record level off so that I can record an image without sound?
If you don't want sound and have a mini jack cable, you might be able to plug into the mike jack on the side of the camera.
I have an external 2 input audio mixer on my camera. It connects through that input. If I do not have a mike plugged into my mixer and the mixer is plugged in, I will not get audio. You could also maybe try turning your audio levels all the way down.
Jul 11, 2010 | Canon GL2 Mini DV Digital Camcorder
No sound when I play back using an external micropohone however when I play back on the TV full sound. Any solution?
Microphones are input devices; they don't double as speakers. If you mean that a stand-alone set of speakers do not work, but the internal speakers of the tv do let you hear the audio track from the camera. Then I have a couple of different suggestions: 1) make sure the stand-alone speakers work with other input sources, 2) try a different cable (make sure it is connected properly).
Also how are you connecting to the different devices? The video camera has an HDMI port which will send audio and video to the TV on one cable. If you are using the RCA audio in both cases, then I suspect a problem with the external speakers.
If you mean that the audio track is clear on play-back when you use the built-in microphone during the recording and not heard if the external microphone, check the external mic for problems. Try it on another recording device. I can't rule out a jack failure without more information.
I hope this helps.
Jun 03, 2010 | JVC Everio GZ-HD7 Camcorder
I dont understand how to use an external mic. Use of external mic.
Your external mic needs to have a 1/8" plug. You will need to find the "Mic" input, this is generally found behind a removable or hinged plastic or rubber panel, and usually near the A/V plug connectors. When you plug in an external mic, the camera switches over to use it rather than the built-in mic. On this camcorder, you cannot set the recording level of the external mic. The camera sets the level automatically. So it is simply a plug-and-play, or plug-and-record solution.
Using an external mic allows you to reduce self-noise and handling noise. It is generally recommended for better videos. Different microphones are likely to interact in different ways with your camera and its automatic level-setting, so you should try out different microphones if you have more than one available to you.
Sep 26, 2008 | JVC GZ-MG575 Camcorder
Sound doesn't transfer from camera into computer
It most likely IS the .mov file. I recommend buying quicktime pro, $20,  which will allow you to convert the file, or if you get the free version of quicktime, and the video and audio play fine with it, You can use a screen recorder and turn off the "record external Mic" mode, and turn ON "Record Computer Audio" Once you're done converting (or recording) You can go ahead and edit, Hoped this helped- sincerely: animation508 (youtub username)
Jun 18, 2008 | Aiptek A-HD 720P Flash Media Camcorder
Sony handycam CCD-TRV128 Hi-8 camcorder
if your camera will play any previously recorded tapes , the microphone may have failed due to humidity - usually ; if your camcorder has an external mic input ? an external microphone - will confirm this ;
Jul 25, 2007 | Sony Handycam CCD-TRV128 Camcorder
Recording sound on video.
Audio Dubbing may vary by model. Most Digital Camcorders are equipped with this feature. To verify that your model is, please view the User Manual. Audio Dubbing * The AUDIO DUBBING function only works in PLAYER Mode. * You can add sound to the original sound on a pre-recorded tape, recorded in SP mode with 12bit sound. * Use the internal and external microphones or other audio equipment. * The original sound will not be erased. Dubbing sound 1. Set the camcorder to PLAYER mode. * If you want to use an external microphone, connect the microphone to the external MIC input jack on the camcorder. * When you wish to dub using the External A/V input, connect the AUDIO/VIDEO cable to the camcorder by inserting the cable jack into the A/V in/out terminal at the left side of the camcorder. - Press the MENU button, turn the MENU DIAL to highlight A/V and press the ENTER button. - Turn the MENU DIAL to highlight AV IN/OUT and press the ENTER button to select AV IN. 2. Press the (PLAY/STILL) button and find the timeframe of the scene to be dubbed. 3. Press the (PLAY/STILL) button to pause the scene. 4. Press the A.DUB button on the Remote Control. * A.DUB will be displayed on the LCD. * The camcorder is in a ready-to-dub state for dubbing. 5. Press the (PLAY/STILL) button to start dubbing. * Press the (STOP) button to stop the dubbing. Notes: * You can not use the audio dubbing function while playing a write protected video tape. * When you wish to dub using the External A/V input, you must connect the AUDIO/VIDEO cable to the audio system from which you wish to record. * You cannot dub sound on a pre-recorded tape in LP or 16 bit mode. Dubbed audio Playback 1. Insert the dubbed tape and press MENU button. 2. Turn the MENU DIAL to highlight A/V. 3. Press the ENTER button to enter the sub-menu. 4. Use the MENU DIAL to select AUDIO SELECT from the submenu. 5. Press the ENTER button to enter the sub-menu. 6. Using the MENU DIAL, select the AUDIO playback channel. Press the ENTER button to confirm the audio playback channel. * SOUND1 : play the original sound. * SOUND2 : play the dubbed sound. * MIX(1+2) : play back SOUND1 and 2 equally mixed. 7. To exit, press the MENU button. 8. Press the (PLAY/STILL) button to playback the dubbed tape. Note: When you playback added sound (SOUND2 or MIX mode), you may experience loss of sound quality.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
LG DR275 Recorder Logo
Ekse
