Question about OKI C9600hdn Laser Printer
I'm getting a 929 fatal error on an Oki 9650 this happened after a paper jam
5 Suggested Answers
Soulvisitor
  • 1113 Answers
SOURCE: oki 9800 230 fatal error
No reset need to fix fault then clears...check toner carts are secure on drums, all their contacts are clean,
Replace Toner Cartridges with Gen OKI new ones... are you using non oki product? Cause Toner carts, thats where I would start looking cause the error is the machine not receiving correct information from a little chip built into the toner cartridges to allow operation to begin.
Posted on Dec 21, 2007
SOURCE: fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Posted on Feb 25, 2010
jyackle5
  • 8197 Answers
SOURCE: oki c5500 paper jam.........cleared paper
To replace the fuser go to the link below.
http://www.laserquipt.com/support/idx/43/581/article/Fuser-Replacement-.html
Good Luck
Posted on Oct 20, 2010
F Victor man
  • 812 Answers
SOURCE: 929 fatal error on my
This is a very unusual error. 929 refers to the waste toner motor not running properly. Remove the waste toner bottle and put a hoover to the outlet to the bottle in case the toner is hard and blocking the exit of toner into the bottle.
Posted on Jun 30, 2011
OKI C330dn Call Service fatal Error:980
That particular error indicates a fuser failure. Try turning off the printer and re-seating the fuser. If this does not clear the message then the fuser needs to be replaced. With such a low number of prints warranty should cover it.
Aug 29, 2014 | Oki Electric Industry C330dn Led Card...
ERR 041
Must have Engine (fatal) and Jam Error logs display on the Control Panel or listed on ..... 041. paper jam. switch off the printer, remove its cartridge, look for paper jam or piece of paper jam in the rollers, clean it, place cartilage properly, switch ON the printer. it will work.
Jun 11, 2014 | OKI Electric Industry B4300 Led Printer
929 fatal error on my oki 9600 printer
Jun 30, 2011 | OKI C9600hdn Laser Printer
I have am Oki Data C6100 and I just got a 980: FATAL ERROR message. I replaced the fuser about a month ago and now it is showing up again. Last Wed I had a paper jam several times. I took out the jammed...
paper jam is a main issue in printer when you clear the paper jam normally a tiny piece of paper falls into the printer and the printer get stuck again to clear the printer of tiny piece remove the toner and use a light blower and blow away the piece of paper this should be done only after removing the power and the usb from the printer after cleaning connect the power and the usb and restart your computer
Jun 28, 2011 | OKI C6100n Laser Printer
How do i solve fatal error 980
i got that error on the first day i got my oki c5950 it was a result of a paper jam in the fuser unit, i removed the jamed paper but the error was still there, i contacted oki support and got a detailed explanation on how to fix this error with a patch file, so if u or anyone out there r still having that problem send me a mail on ecks80@hotmail.com and i will forward u the info.
good luck
Sep 14, 2009 | OKI C5500n Laser Printer
I have a oki 9600 Fatal error 917
Replace the transfer belt unit. A 917 is a belt **** sensor error.
Jun 19, 2009 | OKI C5150n Led Printer
'928 Fatal Error message' on OKI C5550MFP
928 - fuser motor lock error
take out fuser and check for paper stuck on roller
make sure roller can move
if roller is stuck or damaged, repalce fuser unit
Apr 11, 2009 | OKI C5550N Multifunction Printer - Color...
Fatal error 980 OKI C5500 printer
Mar 15, 2009 | OKI C5100n Laser Printer
OKi C5800ldn 231: fatal error 03
I have the Oki 5650 which had been great for about 18 months. Then found that the C cartridge was showing error as 'not installed'. After much fiddling about with it and checking on the internet I can now rectify this by either pushing down on the top of the printer while it boots up, or removing the small chip on the left top of the toner (make sure you have 'earthed' yourself to prevent any static damaging the chip when you handle it!) and taping securly onto the top of the cartridge above the chips proper slot. This now has been working OK for 6 months. Strange how this only affects the C cartridge (which has also been replaced and had the same problem). I suspect that the printers RFID chip reader for the C cartridge is having problems reading the chip and moving the chip closer to the reader by either taping to the cartridge top of puching on the top cover while printer boots up resolves the problem (for now anyway!) This can also trigger the 'service call 231 fatal error 03' message which also disappears if you follow the above procedure.
Hope this helps you.
Feb 13, 2009 | OKI C5800Ldn Led Printer
Oki 9800 230 fatal error
Dec 07, 2007 | OKI 9800hdn Laser Printer
OKI C9600hdn Laser Printer Logo
1,417 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
