Question about Acer Aspire M1641-U1521A PC Desktop
Moniter not rebooting when pc is switched on
When moniter is plugged into tower thier is no nothing comes on screen as if monitor is not recieving signel from tower, also keyboard not working
  • joecoolvette
    joecoolvette May 11, 2010
    Means computer is not working. No Video Signal to the monitor, no keyboard working. Acer's are known for cheap quality Power Supply's, and cheap quality Electrolytic Capacitors on the motherboard. If you have a bad power supply, more than likely it has a weak voltage power rail. There are three main voltages produced by the power supply. 3.3 Volts, 5 Volts, and 12 Volts. The 12 Volt power is the one to be most concerned with. The power supply is rated in Wattage to denote it's power. Voltage times Amperage = Wattage. Note* 1) ALL the lights use less than 1 Watt of power. 2) EACH fan uses 2 to 3 Watts. 3) A typical Processor uses 51 to 125 watts when operating at maximum capability. Depends on what processor it is. The Intel Pentium Dual Core E2180 can use up to 65 Watts.http://en.wikipedia.org/wiki/List_of_Int... Means if you have a bad power supply, your computer lights could come on, and fans could spin, but the Processor won't be working. No processor, no computer. No computer, no Video Signal to the monitor. Do you wish to know how to test the power supply? Do you have a multimeter, or a power supply tester? An inexpensive multimeter can be purchased for around $10 to $12. Most auto parts stores have them, and are but one place that carries them. An inexpensive power supply tester can be purchased for $20. Simply state so in a Comment.
    Problem Solver:
  • 7 Answers
Check the pins in the monitor that plugs up to the back of the computer and see if they are bent.
Posted on May 01, 2010
Moniter reads no signal but tower light is on
Have you changed your resolution recently? Have you installed any programs recently? Have you made any hardware changes lately? Make sure the monitor is firmly connected to the tower and to the back of the monitor. Is the monitor plugged into the wall outlet? If you have two video ports on the back of the tower make sure you are plugged into the correct one, you may also try switching to the other port. Try another monitor if you are able to or try the monitor on another tower to see if you can isolate the problem to the monitor. Do you get anything appearing on the monitor when you first start the computer up? Have you been using a video card or onboard graphics?
Jan 04, 2011 | Acer Aspire X3400 (2702458) PC Desktop
No signal to monitor
Hi, Have u tried removing the RAM and CMOS battery and then again put it.
Jan 25, 2010 | eMachines T6534 PC Desktop
Desktop monitor went black & and wil not power up
Try the fuse on the monitor power cord, and if this does not cure, you will have to get another monitor....pretty good prices on ebay!
Jan 04, 2010 | Computers & Internet
Desktop PC monitor suddenly went black & power light went off
1 either ur VGA card is corrupted or
2 RAM is corrupted
3 Last may be your motherboard is gone - not sure
I have a ctx moniter says undectected mode
CTX 15"1024x768 TFT LCD-Black Monitor · i have a ctx moniter says ... Answer. i have a ctx moniter and wen i plugnitin to pc tower itsays undeceted mode watdoes this mean. Close Close. ASUS Eee PC 1000H
Dec 03, 2009 | CTX 15"1024x768 TFT LCD-Black Monitor
Samsung 713N screen goes black
OK. IN XP GO TO DEVICE MANAGER AND CLICK ON THE MONITER AND UPDATE THE DRIVERS.IF IT TELLS YOU IT CAN NOT FIND A BETTER DRIVER UNINSTALL..REBOOT AND DOWNLOAD NEW DRIVERS FROM CO. WEB SITE.RICHARDM69
Aug 31, 2009 | Samsung SyncMaster 713N 17" LCD Monitor
I CANT GET MY MONITOR TO TURN ON
It could be the Monitor, the VGA adapter, or the PC itself. If you power on the monitor without anything connected to it, do you ever see anything on the display?
If not, it is probably the Monitor. If yes, it is likely the vga adapter and/or PC.
Mar 18, 2009 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
Moniter is black but has power
It's your video card! No Doubt! that happened to mine once and my friends and it was the same thing!
Dec 19, 2008 | HP Compaq FP5315 15" LCD Monitor
Speakers killed my moniter
Well as you have already tried disconnecting the peripherals from your computer, and tried restarting the computer too which did not help you, it sounds to be an hardware issue with the monitor. However if incase you have not tried this, you can disconnect the monitor completely from the tower, power on the monitor, if it powers on and you get a message as no signal, your monitor is working good. If not replace the monitor. If the message appears on the monitor screen, disconnect everything from the tower, push and hold the power button on the tower for a minute. Connect just the monitor and check for any display. If you do get display, thats good, connect one device at a time and check to see if the display appears.
If theres no display with just the monitor connected, the issue would be with the graphics card. You may need to replace it or get the system repaired.
May 27, 2008 | Dell Dimension 2400 PC Desktop
PICTURE TUBE
32 inch Albatran Monivision Moniter, when plugging the VGA in the tower thers no picture. the moniter comes on saying " No Signal No AV Box Action
Dec 16, 2007 | Albatron Monivision 29" Picture Tube...
Acer Aspire M1641-U1521A  PC Desktop Logo
142 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
