Question about Garmin Nuvi 660 GPS Receiver
Juice spilled on a garmin nuvi 205
Does anyone know how to crack open a Garmin Nuvi 205? Juice was spilled on it and it still turns on and works but it blinks alot, I think if I could open it to clean it up a bit and let it air out it would be fine. I just cant seem to find how to open it! There are absolutely NO screw holes at all, and I'm a bit nervous at just wrenching it open. Any help would be greatly appreciated!!
  • Garmin Master
  • 2,130 Answers
NO NO NO!!! There are hidden screws under the decal.... if you try to pry the case open without removing the screws you will crack the case. I've repaired literally hundreds of Nuvi's.
I would not recommend taking the unit apart as you risk damaging the unit. If the spill is around the LCD, the touchscreen & glass may need to be removed from the LCD and cleaned. It takes special care to separate the two without cracking them.
Also, you need to use the right cleaning agent or you will make the problem worse.
- Jim
SHARCNET-USA
Posted on Apr 29, 2010
  • 67 Answers
If you put 2 thin screwdrivers into the left hand side of the unit near the indentations and push them in you should be able to get it open that way there are a couple of clips that hold the unit together... if the unit is working fine then i honestly dont suggest trying to open it you may break something inside and damage it beyond repair.
Posted on Apr 28, 2010
Nuvi 205: I pushed the SD Micro chip into the wrong part of the slot. It disapeared into the back of the casing. Does anyone know how to open the casing?
Garmin uses small Hex / Torque type screws to close the casing for the Nuvi and Dezl range.
A Hex / Torque tool set in different sizes can be found in cellphone repair shops or hardware stores.
Jul 06, 2011 | Garmin nuvi 205W GPS Receiver
Tip
How to Download your Garmin Nuvi 205 or 205W Users Guide. Models: Garmin Nuvi...
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 275
Have you lost your User's Manual or the Quickstart Guide for your Garmin Nuvi 205 or 205W GPS?
Would you like a digital copy for easy searching of terms and quick reference?
Both manuals are available from the Garmin website, or just follow the photo links below:
I hope that helps.
on Jan 17, 2010 | Garmin nuvi 205 GPS Receiver
Unlock maps
I do know a 'workaround' to Garmin's copy-protection for maps you legally are entitled to use, but before that, when a Garmin Nuvi 205 stops working or behaves strangely, there are two steps you can take yourself to try and get it going again:
  1. Perform a Hard Reset,
  2. Run WebUpdater to reinstall that firmware.
I hope that helps.
Mar 15, 2010 | Garmin nuvi 205 GPS Receiver
Garmin nuvi 205
TIME FOR A TRIP TO GARMIN
Feb 26, 2010 | Garmin nuvi 205W GPS Receiver
My garmin nuvi 205 won't turn on
Whenever these devices start acting up, such as not turning on or not loading past the Garmin welcome screen, I recommend performing a hard reset of your Gamin Nuvi 205. Also, use Garmin's WebUpdater service to make sure you have the latest software on your device.
I hope that helps.
Feb 11, 2010 | Garmin nuvi 205 GPS Receiver
Spilled juice in my purse this morning and the garmin nuvi 255w got water on it. now it will not come on at all!
Place your gps in a gallon jar with dry rice in it. Leave it for 24 hours or more. The rice will draw the moisture out of the unit and into the rice. Place on charger as normal, then power up.
Dec 18, 2009 | Garmin nuvi 255W GPS Receiver
My garmin nuvi 205 is not talking
hello. Begin by turning the volume all the way on. It is the little dial on the upper right side of the garmin. If that doesn't give you sound, return the unit as it is under warranty.
Dec 06, 2009 | Garmin nuvi 205 GPS Receiver
Garmin NUVI 205 when turned on says can't unlock maps!?!
Whenever Garmin Nuvis have map problems, I recommend performing a hard reset of your Gamin Nuvi 205. Also, use Garmin's WebUpdater service to make sure you have the latest software on your device.
I hope that helps.
Oct 24, 2009 | Garmin nuvi 205 GPS Receiver
Garmin nuvi 205 will not turn on
Whenever these devices start acting up, like not turning on anymore or getting stuck at the Garmin welcome screen, I recommend performing a hard reset of your Gamin Nuvi 205. Also, use Garmin's WebUpdater service to make sure you have the latest software on your device.
I hope that helps.
Oct 03, 2009 | Garmin nuvi 205 GPS Receiver
My Garmin nuvi 205 will not give voice prompt
The germin nuvi 205 can be pre loaded specific data on the route and has voice. i dont know if yours has been pre loaded, with 3.5 navigation data.
Mar 19, 2009 | Garmin nuvi 205 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
126 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
