Question about Jensen Mobile PC Tablet
My Jensen GPS Model NVX430BT is showing a fatal error when I push the Navigate button it says "Initialization error: nolanguage files were found in /MyFlashDisk/iGO/lang. it was working okay the first time I used it. How do I fix it?
Bad direction
Posted on Jun 09, 2010
I forgot my password for my tablet azpen model A746G what should i do?
To perform a factory data reset on your Azpen tablet, you need to backup files first from your device because it will delete all data. If you are through, you have to switch it off. Hold the volume button while you press the power button for ten times. Then press the reset button four times. Then release all buttons when it switches on. If you see the Android symbol and triangle on the screen, use your volume keys to navigate through the recovery menu. Select Wipe data/Factory data reset. Use power button. Select delete all data. Then select reboot now.
Still have any issues, you must go to customer care at +1-800-243-0051
Apr 27, 2017 | Tablets & eReaders
I need a users manual for navmii gps navigation software For Windows
https://www.microsoft.com/en-us/store/p/navmii/9nblggh10k57 = software.
Navmii used to have an old manual at http://www.navmii.net/bin/Navfree_UserGuide_v1.0.1.pdf
The link no longer works.
Here are some basics:
Basic Navfree Help
Navigation is easiest if locations are added to Favourites before navigating. To check a location before adding it to Favourites, or find a location near another location:
Tap Menu icon at bottom right of map screen. Tap Navigate on Main Menu. Tap Address or Google.
Type name to find. Done. Tap down-arrow beside item . Tap Show on map.
Check it is the correct place. If so tap down-arrow and Add to Favourites.
Or drag map to required location. Tap on map. Select Add to Favourites. Change name if required.
To enter a route from A to B, when A is not the current GPS location.
Need to disable GPS in Android Settings - Location.
Easiest if A and B are entered into Favourites. Use Google Search or Address to find names and descriptions, then Add to Favorites.
Then tap Navigate on Main Menu. Tap Favourites and select A.
Tap box with Favorites name in it, and select 'Route from Here'.
Tap Menu icon at bottom right of screen. Tap Navigate. Tap Favourites.
Tap 'Route here'. Tap 'Selected' (not Gps).
Tap 'My Route' to see Route on map.
To clear route: From Main Menu, tap Clear Route.
Cant edit or delete (sometimes) Favourites. Use Jota app . See forums.
Still looking for manual, there blog is very helpful which is the link above.
Helpful links,
https://groups.google.com/a/navmii.com/forum/#!forum/android-app
https://groups.google.com/a/navmii.com/forum/#!topicsearch/user$20manual/android-app/CibF963hA5I
Nov 16, 2016 | Tablets & eReaders
My Nextbook model NX785QC8G freezes when you turn it on. How do I reset it to the factory settings? I have looked, but have not found a reset button.
Check http://support.nextbookusa.com/support/index.php?/Knowledgebase/Article/View/84/0/reset-instructions-for-nx785qc8g.
1. Hold down the Volume (+) and the Power button at the same time, until you see No Command on your screen. (The tablet will act like it's going to turn on and go black, continue to hold your buttons until No Command shows up on your screen)
2. Release your buttons when you see the No Command appear on your screen.
3. Tap the Volume (+) once, and a blue menu will appear on your screen.
4. You will use the Volume (-) to navigate and the Power to select. Tap theVolume (-) until you highlight "Wipe Data Factory Reset"
4. Press your Power button to select it.
5. You will see a list of "No's" and one "Yes." Use the Volume (-) to go to the onlyYES on your screen.
6. Press your Power button to select the Yes.
7. This will prompt your tablet to go through the motions of resetting itself. When you see the words ''Wipe Data Complete", tap your Power button once to selectReboot System Now.
8. Your tablet will power off and power back up on its own; this will take a little longer than normal, so give it a couple minutes before it boots.
Dec 29, 2015 | Nextbook Tablets & eReaders
Forgot password to get in tablet how do you reset it
RTM. Read the Manual. If you need a manual, google the make and model and manual and you should find a .pdf file you can download. Or go to the manufacture's website and contact them.
Nov 23, 2014 | HKC 7" Touchscreen 8GB Tablet 1GHz Android...
Help desk
You will usually have to load your navigation info while you're attached to a wifi network. After that it should use the gps satellite system to navigate you. It will need to be connected to wifi to redirect you if you leave the route that is programmed in.
Mar 29, 2014 | Samsung Tab Tablets & eReaders
Hipstreet tablets
Ahh , You have a nice problem on hand that made me almost want to toss this tablet out .
There is a few tricks to get your Tablet back , You require a few things
-A usb cable to connect to computer
-Internet connectivity
Now Lets start by putting the tablet in Android recover mode .
1. Connect the tablet to the USB port on the Computer .
2. Press and hold the power button and the Big button on the tablet , Keep pressing it until the logo of the android gut with his gut open shows up .
3. It is possible to perform a reset using the ADB (Android Debug Bridge)
I did mine on Windows XP , (Does your tablet install correctly in the Device manager? )
If so That is great news , You may goto step 5
If not Goto step 4 :
Step 4: Getting the Chinese driver equivalent for your tablet .
Get the drivers for the Ainol 7" Auror tablet (or equivalent )
Now Before the driver will work with your device (you can try to install it but it will give you an INF error)
You must edit the file (.INF) to match your USB id of the tablet
(At the bottom of the file change the STRINGS section to the device codes of your tablet ) (found by right clicking the Unknown device in the device manager . the (VID_1f3a_PID_efe8) is the HARDWARE ID and the
[Strings]
USBDRV="USB Devices"
USB\VID_1f3a&PID_efe8.DeviceDesc="USBDevice(VID_1f3a_PID_efe8)"
YOUR STRINGS:
USB\<YOURDEVICEID>.DeviceDesc=USBDevice(<YOURDEVICEID>)"
Step 5:
Get the Recovery tool from here
https://spideroak.com/share/KNQW243VNZTUGYLMNRUXG5DP/manta_mid08/home/willing/Android/Builds/Manta/Recovery/CWM_Recovery_Manta_MID08_windows_install.zip
This will give you a suite of tools to restore your device to factory reset
Use it to install the recovery partition , and then reboot your device in recovery mode , Then use the Vol + and - buttons to navigate and power button to Enter .
Good Luck
Jan 03, 2014 | Hipstreet Tablets & eReaders
I have a PANIMAGE media tablet 7'' 2GB/GO, model numberR79RT2W5.. it turns on and thats it, it shows a constant blue line centered at the bottom of the screen, i can press the menu button on the top of the...
You'll need to do a factory reset:
1. With the device off, press and hold Volume Up and Power.
2. Release the Power button when you see the logo, but continue to hold Volume Up until the recovery screen appears.
3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.
4. Press Volume Up continue.
This will reset you device to factory settings, however anything on your SD card will still remain.
At this point you will need to start fresh as if you just bought the device -- register with your email address, etc.
Oct 26, 2013 | Generic PanImage Android MM Tablet eReader...
HE tratado de instalar CALL OF DUTY , Y PIDE ARCHIVO OPENGL
you need to uninstall the game and reinstall and make sure your disk is clean i have had this myself
Nov 16, 2008 | Tablets & eReaders
Jensen Mobile PC Tablet Logo
345 people viewed this question
Top Jensen Tablets & eReaders Experts
Are you a Jensen Tablet and eReader Expert? Answer questions, earn points and help others
