Question about Canon imageRUNNER C3170U Color Copier
Need Black toner for C3170U Copier. Part number requested. Can you help?
    President:
  • 1,194 Answers
Thanks for using Fixya.
You can buy Genuine Canon ImageRunner C3170U Toner Cartridge, Black from this link.
It will cost you around $60.
Good Luck and have a nice day.
Rating the solution is highly appreciated
Posted on Apr 27, 2010
E00013-000 ir3170ci
this is error for waste toner full detection.
So, you need to empty the waste toner box. It is located in front side of copier, beneath the copier cover, right side of toner inlets. To reach it you need to remove plastic cover above the box.
For service manual emma.servis@gmail.com
Hope that helps!
Aug 24, 2011 | Canon imageRUNNER C3170U Color Copier
Where is the waste toner cartridge on a Cannon Imagerunner c3170u?
open front door of machine,waste toner bottle is situated to your left.gently pull out .
Jul 13, 2011 | Canon imageRUNNER C3170U Color Copier
I receive an error E000013-0000 in my printer
waste toner bottle inside the front cover is full, or the little "fish eye" windows in the neck of the bottle need to be cleaned. then cycle the power.
Mar 30, 2011 | Canon imageRUNNER C3170U Color Copier
I have a Canon ImageRunner C3170U/C3170I
When you open the front cover,there is a transperant bottle with waste toner remove the bottle and remove the waste toner from the bottle.There is aslso a small clear transperant plastic holder that detect the level of the waste toner.Use a no2 star skrewdriver and remove it.Clean it and put it back.And reinstall the waste toner.
Jun 16, 2009 | Canon imageRUNNER C3170I Color Copier
Waste toner
to change the waste toner on your IR 5055, stand directly in front of machine and look on the right hand side of it where the power switch is a black button on right hand sdie at the back and you will see 4 screws and a metal plate that will come off the waste toner bottle is in there just empty it out and refit to machine all will work, now on your IRC3170 just undo front door and you will see a clear bottle just undo the black screw and take out the bottle and you will see a couple of little clear windows in the bottle make sure you take them out and clean them before you emtpy the bottle, this is where the machines shines a light through it to tell if the bottle is full or not so make sure you have them clean. refit the bottle and all will be ok
May 26, 2009 | Canon imageRUNNER C3170U Color Copier
Waste toner
Turn off the copier. Remove the lower left panel on the left side of the copier, then pull out the plastic container and empty it. Reinstall the container and cover then turn the machine back on.
Apr 08, 2009 | Canon imageRUNNER C3170U Color Copier
I CAN'T USE MY MACHINE
A E00020-0081 deals with the toner density sensor or the drum. The sensor could be dirty or you may need a new sesor or a new drum unit or both. You may be over your head with tring to fix it your self. You may need to get a service rep in to deal with it... Good Luck...
Oct 01, 2008 | Canon imageRUNNER C3170U Color Copier
Check your toner waste bottle it may be full. Also the tube that transports the wast toner may be clogged. In which case its time to call a tech. John
Jul 02, 2007 | Canon imageRUNNER C3170U Color Copier
Canon imageRUNNER C3170U Color Copier Logo
56 people viewed this question
old marine
old marine
