Question about Moen & One Handle Tub & Shower Faucet
Replaced trim ring and handle, now hot is cold ,cold is hot
I was putting in new tile in the shower, water had been drained from the system for about a week ,installed new trim kit and it's like the valve has reversed itself,put old trim back on and it's the same as the new.
  • 20 Answers
Remove the handle and turn the stem of the cartridge 180 degrees then put your handle back on.
Posted on Apr 29, 2010
I have replaced moen 1225B cartridge and only get cold water no hot water
when installing a new cartridge you need to put stem grease on the o-rings or you are taking a great risk of cutting the o-rings upon installation. doing this will allow the cold water to mix with the hot causing this problem it is quite common for this to happen without the grease
Apr 16, 2014 | Moen 3175 Legend One Handle Shower Faucet...
Got mira discovery mixer shower. wont get hot just luke warm or cold. taps in rest of house ok? Had it off the wall recently to tile behind it but apart from that been great for 6 years. any ideas?
There should be a hot water limiter behind the knob on the shower - shingle handle, undo the handle and move the adjustment to allow more hot water. Not familiar with mira discovery mixer
Feb 03, 2013 | Home
Is there a way to reverse hot and cold?
Is it moen brand? if so all you have to do is take off the handle and remove the cartridge inside and flip it over 180deg and put it back in.
be sure to shut the water off first.
hope that helps you.
Dec 18, 2012 | Delta 144962-SS Mandara Monitor 14 Series...
Just had a single handle shower faucet installed in my new walk-out developed basement and it seems there is a control on it I want to remove. I can't get the handle to go beyond mid-point and I want more...
Hi im Rossouw
The rest of ur house water in the showers fine?
If not they must install a prv (Presure reducing velve) on the cold going to the house and geyser befor it t,s of to the house and even if the rest of the house water is fine u must ask ur plumber who intalled it if he took the cold water going to the new shower strait of the mains if so he must corect it by t-ing in at the right cold water supply or put a velve on the cold water to ruduse the cold presure . then u will have more hot presure and that means lovely hot shower
plz vote and rate my advice thanx
Jul 17, 2010 | Delta & Single Handle Shower Faucet
How to adjust anti scald valve on american standard shower faucet
Remove the handle,and all the trim rings,and the cartridge cover. take a flat head screwdriver and use it to lift
up the red ring behind everything, this is the hot limit safety stop,
this just stops the handle from turning to full hot.
Once you have the red ring lifted up, notice the numbers and the pointer
on the ring, numbers are on the fixture,
O= hottest 7=cold
See what the ring pointer is set to now, and move it half, before you put this back together, just set the handle on the unit and run the water to see if its to hot or not enough. Once you have found what is the best setting, then replace all covers and trim, handle.
Feb 10, 2010 | American Standard Bath Faucet Ceramix...
Moen Single Handle Shower Faucet-turn on get cold, little hot
You can try to rotate the first plastic ring to the left of center a few teeth, this will let the handle advance alittle more to the hot side.
Oct 09, 2009 | Moen 3175 Legend One Handle Shower Faucet...
WATER IN TUB HOT, THEN TEMPERED
It sounds like you have an anti-scald mixer in the system that needs to be adjusted.
Jul 26, 2009 | Paini Spa Rubinetterie LaToscana 3 Piece...
Hot and cold backwards on a moen shower faucet
tun off the water.
unscrew teh allen screw under neath the handle. pull out hteh handle. undo the wall plate and gain access to the cartridge in the handle body. turn the artridge around 180 degree and reisntall all parts.
Apr 06, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Only hot water, no cold water.
The cartridges in the single handle units are prone to display this issue in hard water areas as mineral deposits such as calcium build up on the stem. The stems also have small rubber band like rings - for lack of a better term- that break apart and can clog the ports on the side where the are on. New stem should resolve the issue totally unless you have had a pipe break or other construction to the plumbing system recently. Thanks for using Fix Ya.
Mar 01, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Bathtub water does not get hot enough-
take off handle and you should see a nylon ring with teeth just take off and put back in the oppisite direction that you removed it its there to prevent kids from getting burnt
Feb 27, 2009 | Plumbing
Moen & One Handle Tub & Shower Faucet  Logo
260 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
