After every load the softner tray is full of water, whether I used softener in that load or not.
  • Washing Mach... Master
  • 19,396 Answers
Hi.
the problem is caused by blockage.The hose at the bottom of the detergent compartment must be checked after removing appliance front or upper panel.
Here an article on the same problem: rinse aid compartment is always full of water.
Regards.
Posted on Apr 27, 2010
Maytag 7500 Water in cups for bleach & softener
you should have a small amount of water in the resivoir this is part of the siphon system
but you do want to keep it clean every 4-5 loads put it through the dish washer
Oct 06, 2009 | Maytag Neptune MAH5500B Front Load Washer
My washer wont drain out the fabric softner just adds water to it. cleaned the part where i put the softner thinking it was clogged but still happening.
Usually, the softener syphons out from the tray. The tray will have a tube, the tube will have a cap. Water filling the tray forces the liquid around the cap and tube. The falling water (now inside the tube) creates a vacuum-syphon effect.
Pull the tray, remove the cap, clean and try again. Provided the water's getting there, this should help.
Regards! --W/D--
Jul 14, 2009 | Frigidaire ATF6000ES Front Load Washer
FABRIC SOFTNER TRAY STAYS FULL AND IS NOT RINSEING OUT
HiYa dh1200s
The softener tray needs to be cleaned out or the sensor for this replaced.
Yes, not enough water entering machine so not enough water to rinse out the softner
Please leave a good rating before you sign off.
Mar 29, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Fabric softner tray is left full of murchy water after wash cycle has finished. Machine is brand new and only been used once. Its a Hotpoint Ultima WDD960 washer dryer.
is the machine got good water pressure cus somtimes little water gets in the fabric soften tay and it dosent flush all the softner out. hope this helps.
Sep 02, 2008 | Hotpoint Ultima WD72 Front Load...
Fabric softener always left in tray
hi there are you using concentrated softner if so water is down as some softners are to thick to go through the dispenser also give the whole drawer a soak in hot soapy water incase there are any blockages.
hope this is of some help
Nov 11, 2007 | LG WM-1480FHD Front Load Washer
Fabric softner
Remove the dispenser tray. Inspect the area just above the fabric softener portion of the dispenser. There should be a series of holes where water feeds into the tray during the rinse cycle. Sometimes these holes become clogged with fabric softener residue. If the holes are clogged, water will never dispense the fabric softener out and it will stay in the tray. If you take some cotton swabs and meticulously clean all the holes out, I bet your problem will go away. Let me know if this was helpful to you.
Oct 05, 2007 | Frigidaire GLTF2940ES Front Load Washer
Softner remaining
Try diluting the softener, some softener are too thick. But first clean out the softenre tray, by pulling it out, or with a tooth brush. Do look into your user manual. Does water enter the soft tray, check this too.
Sep 08, 2007 | Zanussi FJS1225W Front Load Washer
Washer
Most likely your softener tray is clogged. There are some softeners which clog easier, this can be diluted with a little water before you pour it into tray. The softener tray needs to be cleaned.
Feb 20, 2007 | LG WD-1280FHD Front Load Washer
Bleach and softener dispensers filled with water at end of cycle
Yes, remove the dispenser tray by pressing on the button on the softner and pulling out tray completely. Now lift the flap over the softner compartment and clean thourougly with hot water, making sure all tubes and holes are free from residue softner/detergents. Replace flap by making sure the bigger tube fits OVER the smaller tube and click into place. Replace tray. Water is present due to the "syphon effect" of the dispenser not working, caused by residue detergents blocking the tubes/holes. Oshie
Oct 28, 2006 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
