Question about Hayward H Series Induced Draft Abg 100,000 Heater
My gas pool heater is banging
Hayward, gas heater... a metal clinking noise and the hoses doing a twitch every 5 to 20 seconds. my experience says it is that diverter shield has come loose...disconnect everything. unscrew the in and outlet connections.look into the hole, you will likely see a metal, plate with two half circles, one facing the inlet hole, and if you go around to the other side you will see the other end of the plate, with a half circle. this plate comes loose, whatever they use doesn't last.
one guy used a small hose clamp to keep it from sliding up and down the post, I used that two part plumbers putty, to "weld" it in place....homedepot, comes in a small cylinder, it's two part, you cut off a piece and mold it in your hands, worktime is only 3 min. cures in an hour.... no more clinking metal or twitching hoses.
Posted on Jun 11, 2010
  • Cyrus69 May 30, 2011
    Mine did the same thing took the water lines off
    Mine did the same thing.removed the water lines
COULD IT BE THE PRESSURE SWITCH?
Posted on Jun 25, 2012
Banging noise could be several things. Is the pump runing water through it? If the water temperature in pool heater gets too high it will creaqte a banging noise until it cools down. The heater should turn off before your circulators shut down. If this is not the case-- you may need to rewire sequencing of heater and pump operation
Posted on Apr 27, 2010
3 Suggested Answers
  • 990 Answers
SOURCE: The heater makes a banging sound after the burners
What you have is a water flow problem. The water should be going through the heater but it is by-passing it. The water inside the heater is boiling and trying to expand as steam that makes the banging sound. Their is a internal by pass in the water manifold on the side of the heater. If you take this apart you will find a disc on a spring contraption, if it is stuck open the water goes past the heater but still has pressure to kick the pressure switch and fire the heater. Either clean or replace this assembly. The other thing to check for is an external by-pass. This will be a gate valve bridging the inlet and outlet pipes. If you have one of these it should be 80-90% closed or the water goes through it and creates the same problem. This is not on all systems so don't be alarmed if you don't find it. Good luck.
Posted on Mar 29, 2010
  • 990 Answers
SOURCE: i have ahayward H1001D1
If your external by-pass is closed almost all the way then it will be your internal by-pass. You find this assembly inside the water manifold at the side of the heater. Part should be about 70-80 bucks.
It is suppose to regulate the water flow so it has time to heat but not boil. Yours is probally missing the control disc and letting all the water flow past the heater so the water in the heater is boiling and that is the banging you hear. Good luck.
Posted on Sep 04, 2010
My raypack heater cycles on and off with a big bang each time it tuns on
It may be due to gas "pooling" before it ignites. Check that the pilot assembly is correctly positioned, and the burners and heat exchanger are clear of soot and debris.
Mar 16, 2013 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Hayward pool heater model h100d1 ignites with a bang and goes out
I had the same problem. It was my igniter. It was all corroded and oxidized. Would not properly ignite the gas fast enough and when it finally ignited, the excess gas in the chamber would explode and put out the flame and cycle over and over with bang. Took igniter out, cleaned and filed down the copper prongs. Replaced and all was well.
Jun 06, 2012 | Hayward Gas Swimming Pool Heater 100k Btu...
Banging noise when heater is on
not enough water pressure check pump and filters if ok check manual bypass (on side by plumbing)
May 30, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
Hayward MILIVOLT H300 BANGING AND POPPING. STILL HEATS BANGING AND POPPING QUITS WHEN HEATING STOPS.
There are two things that can cause this...
low water flow
mineral build up in heat exchanger
Check and verify water flow through the heater
if that is ok, then the heat exchanger needs to be cleaned
heatman101
Sep 25, 2011 | Hayward H-series Electronic Gas Pool...
Pool heater is banging like crazy......also makes a whining noise.
Banging is not good. Maybe it is a gremlin with a hammer?
This issuesounds tricky. I recommend you call the Raypak technical support at800-947-2975 or 800-627-2975 and they should be able to help you figure thisissue out. Ihope this helps.
Sep 18, 2011 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Heater runs but there is load banging and knocking
Poor flow, try cleaning the filter. If it is a cartridge, try a brand new element. Next would be to inspect the bypass in the header to ensure it is sound.
Jun 11, 2009 | Hayward H Series Pool & Spa Heater 400k...
Hayward H Series Induced Draft Abg 100,000 Heater Logo
1,364 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
