Question about Brother MFC 7420 All-In-One Laser Printer
Add printer I am using window vista, but I can not add printer via network. I am using brother printer, it is compatible with XP not vista so can you show me how to update drivers for vista
  • Anonymous Apr 01, 2008
    Machine came with installation CD for Microsoft Vista and I run on Microsoft XP. It seems that parts of the program has loaded and even prints, but ink is absent.
  • 133 Answers
SOURCE:
I need to download brother HL 2070N
Hello Asma,
If you are using Windows Vista, Windows 7 or Mac OSX 10.5 or greater all you need to do is plug in the printer via USB cable and allow it to auto detect or if you are using a network connection, just select "add Printer". The drivers are built in.
For Windows XP or Linux you need to download the drivers.
For Windows XP
http://welcome.solutions.brother.com/bsc/public/us/ca/en/dlf/dlf/000000/000800/dlf000844.html?reg=us&c=ca&lang=en&prod=hl2070n_all&type2=1&os=7&flang=4&dlid=dlf000844
For Linux
http://welcome.solutions.brother.com/bsc/public_s/id/linux/en/index.html
Thanks,
Pat
Apr 14, 2011 | Brother HL-2070N Laser Printer
Tip
How to use a printer?
Install a New Printer DIY installation of your new printer in Windows. You may have a new printer with an installation disc, or maybe a second hand one with no disc. Either way you will find out how to install your printer onto your computer.
Add Network Printer If you have two or more computers in your house or office you will only need one printer installed on one computer for both to have printing privileges. This article shows you how to add a network printer to Windows Vista.
Add Network Printer Applies to Windows XP. Even though the instructions are similar to installing a network printer on Windows Vista, there are a few extra tips that might be interesting.
Enable Printer and File sharing How to enable in Windows XP And Vista. If you want to share a printer on your network you must enable printer sharing. It is not hard to do but it will not work if it is not enabled.
Path to your network printer How to find the path \\server\printer. If Windows does not find your network printer automatically then you will need to know the path to your network printer.
Set Network printer permissions Set who can change printer settings in Windows XP and Vista. I personally like to let everyone on the network just print and not be able to change too many settings to do with the printer.
Network printer has problems printing - You do not have permission to use selected printer.
Quick Printing Trick Cool printing trick for Windows Vista and XP.
on Jan 18, 2010 | Office Equipment & Supplies
WINDOWS 7 COMPATIBLE?
Yes, just use Windows 7 Update function to install proper drivers automatically. The drivers provided by Brother on CD do not work, though.
Feb 06, 2010 | Brother MFC 420CN All-In-One InkJet...
How to install LAN Brother MFC-5840CN on Windows 7 when original CD only has XP driver. Windows Update list specifies MFC-5840CN USB, but machine has option for LAN - is the driver the right one?
You cannot use the full driver and software package now. BUT:
Printing is possible, scanning and FAX is not possible at the moment. You download the Vista driver (x32 or x64) from the official Brother site and install it with the Printer Wizard in Windows 7.
Oct 28, 2009 | Brother MFC-5840CN All-In-One InkJet...
Network printing in vista is offline
Is it shared over a network, or is the driver installed on each PC independently? Have you installed the proper Vista drivers on the Vista PC's? The Xp driver is likely not compatible with Vista. It may be (if you used a disc) that it doesn't contain the proper Vista drivers. I would try downloading the proper driver and re-installing on the Vista PC's.
get it here:
http://welcome.solutions.brother.com/bsc/public/us/ca/en/dlf/download_top.html?reg=us&c=ca&lang=en&prod=mfc8460n_all
Jul 14, 2009 | Brother MFC-8460N Bundle All-In-One...
Networking printer issue
vista open devices & printers add printer connect direct via cat5 patch power cycle lexmark
Nov 16, 2008 | Lexmark (13A0288) Network Adapter
Brother's MFC-3240C All-In-One
I do not know if Windows Vista driver software for the MFC-3240C is available on CD/DVD.
You can download either the Full Driver & Software Package or the Add Printer Driver Wizard for Windows Vista ("regular" edition) from this page.
You can download either the Full Driver & Software Package or the Add Printer Driver Wizard for Windows Vista x64 Edition from this page.
Jun 20, 2008 | Brother MFC-3240C All-In-One InkJet...
Printing from XP to a Brother 7820N as a networked printer
We have multiple 7820s in our office. This would be a configuration problem with your windows XP computer. From the XP computer, open a command prompt and type "ping x.x.x.x" where x.x.x.x is the ip address of the 7820n. Make sure you get four successes. I would then uninstall the brother software and drivers and go to "printers and faxes" in the control panel and manually add the printer.
To manually add a network printer, with it's own print server, on Win XP:
1 Click "Add Printer"
2 Select "Local Printer Attached to this computer"
3 Deselect "Automatically detect and install my Plug and Play printer" then click "Next"
4. Click "Create a new port" and select "Standard TCP/IP" from the drop down. Click "Next". this will open TCP/IP Wizard
5. Type in Printer IP Address next to IP Address (Port name will autopopulate) and click "Next"
6. If wizard finds printer, it will show you "Finish" button. If you get a "Additional Port Information Required" window, something is wrong with your printer or windows xp network configuration.
7. When the TCP Wizard window closes, it will take you back to Add Printer Wizard. Select "Have Disk" and navigate to the \USA\WXP\Addprt directory on your Brother Drivers disc.
8. Select brxpadd.inf and click "Open" then click "OK"
9. Select "Brother MFC 7820 N Printer" from the list and click "Next"
10. Select name of printer, whether you want a default, print test page and DONE!
Jun 12, 2008 | Brother MFC-7820N Printer
Brother MFC 7420 All-In-One Laser Printer Logo
70 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
