Question about Husqvarna Chain Saw 20" Bar
Chain oiler quit working
How do i change the chain oiler on a 141 huskvarna chain saw
    President:
  • 2,220 Answers
Your oiler is under the clutch, The IPL (exploded parts list) for your saw is the only detail for the oil system and is sketchy at best. Oiler components and part numbers are listed but may be on different illustrations. They are also beneficial with disassembly/reassembly (You require a special tool for clutch removal. Please ensure the one I list is a suitable substitute):
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
00198 = 198th unit Husky produced that week
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check the IPL for your saw to see if any special tools are needed. Poulan (Craftsman, Jonsered, Husky) clutch removal tool part number 530031112 if needed, is under $5 from many sources (look at the visible area between the weights if 2 small round sockets are visible you need the tool).
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of nylon rope (nothing left behind) be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. Everyone I have ever removed had a left handed thread (tighten it to loosen it).
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on Apr 27, 2010
Can the chain oiler be adjusted on a 141?
No adjustment possible.
But that can be good news when you got good oil as you can run a longer bar and chain up to 20" The shorter the bar the more oil present on the chain and bar during operation
Jan 08, 2015 | Husqvarna 36 41 50 51 55 136 141 154 254...
Tip
Checking your chain oiler
Chain oilers are a vital part of keeping your saw running well. No oil can even cause the chain to bind up. Over a period of time it can greatly increase the wear rate of your bar and chain reducing it's life. Chain oilers seldom go bad they just get clogged up with sawdust.
Remove the housing that covers that bar and sprocket. There are two plates on each side of the bar that set over the studs.They may be identical or slightly different depending on the saw but at least one of them will have a hole in it for the oiler. If you remove the bar and both plates you will see the oiler hole on the saw housing. This oiler injects oil through the plate and into a small hole in the bar where the chain picks it up and carries it around the saw. If this hole becomes plugged with sawdust it will keep your saw from oiling the bar proplerly. This hole should be cleaned out periodically. It's not a bad idea to remove the whole chain periodically and clean the chain guide all the way around the bar and get any sawdust buildup out so the oil can flow better.
on Dec 05, 2009 | Garden
Where is the adjustment for chain oiler?
depending on the saw it may or may not have one. most home owner saws are not available with an adjustable oiler. if however you are sure it has one it is accessed via the bottom of the saw on the clutch side
Feb 10, 2013 | Garden
Chain oiler not working properly
If it pumps then quits perhaps the tank vent is plugged. When it quits roll the saw, loosen;;; then tighten the oil cap. If it no better post back (below) with a model and serial number and we will analyze your oil system. If it works post back with numbers and I can at least provide a link to your exploded parts list.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 04, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Chain binds saw dies saw runs fine with out bar chain on clutch bearing? help poluan 3416 16 inch 34cc
Is your chain oiler working? If you're using saw a lot and the oiler isn't working properly the chain will get hot and bind up especially if the chain is too tight. Tighten the chain so that you can squeeze it in the center of the bar, with your second and third finger on the sides of your fingers (not a very strong grip) and you should be able to almost pull the chain out of the bar guide but not quite. Clean the oiler hole in your bar where the chain oiler injects oil into the bar. You can also run your saw without a bar and chain and see if the oiler is pushing oil out of the injector.
Dec 04, 2009 | Tools & Hardware - Others
I have 3 older Poulan chain saws, XXV, 1800, and 2000, essentially identical saws. They all use a check valve from the crankcase to pressurize the chain oil reservoir. The check valve apparently uses an...
These oilers are called diaphragm oilers and work fairly well when the saw is new with great compression. As the saw wears out, the compression drops and a side effect is less oil pumped. The diaphragm is replaceable and it's not horribly expensive. Most good saws use a gear oiler - and even the newer Poulans use gear oilers. The gear oilers tend to have less problems and don't rely on engine compression.
Oct 09, 2009 | Garden
Husqvarna 141 will not oil and when i had it serviced they replaced the oiler and it did not solve the problem.
Remove the chain and bar assembly. Start engine--should pump oil from oiler port where the bar fits on the engine side. If oil comes out, then possibly the bar-oiling passage in the bar itself is plugged with dirt or sawdust--blow clean with compressed air. If no oil comes out from the port, check the pickup tube inside the oil tank. Drain the oil into something and fish the pickup tube end out with a hooked wire. Replace if collapsed, cracked, or loose.
Jul 04, 2009 | Husqvarna Chain Saw 20" Bar
Poulan oiler don't work
Common problem with Poulan and Craftsman gas saws. Take off the chain and chain guide and clean out all the saw dust etc. Start saw without chain and look for port where there are signs of oil. If port is clear of sawdust, then it is likely the pump which is located behind the chain break assembly. you can get the diagram on Poulan website and the replacement pump will cost about $15 - $20 to replace yours.
May 22, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Have a MAC 3818 chain saw it just stopped oiling.
Same for me. Take chain off and ensure clean oil hole and channel. Clean hole if needed with fine wire or heavy nylon line. otherwise I think problem is interior, either oiler itself or oiler oil tube came loose. Since I have no excess oil coming out I suppose oiler iself is bad.Still working on it.
Apr 17, 2009 | Poulan 1630 16" Chain Saw
Chain oiler
Saw dust has clogged the passage way in the bar. take the bar and chain off and clean the groove where the chain runs, also near where the bar mounts to the saw there are holes in the groove that intersect with cross holes in the center of the bar, push a paperclip through top and bottom.
If this works for you please leave a rating, thanks
Mar 25, 2009 | Garden
Husqvarna Chain Saw 20" Bar Logo
313 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
