Question about Whirlpool Duet GHW9150P Front Load Washer
Control lock light is on.
Unable to shutoff or turn on.
  • 5,911 Answers
The Control Lock is actually a safety feature that enables the consumer to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance. This can usually be reset and does not require a technician.
With the lock on, the control panel is disabled and you cannot use any of the controls, except the button to unlock it. It can inadvertently be set following a power outage, leaning against the control panel, or pressing and holding the wrong button. This is usually not an indication of a malfunction.
If this is a Whirlpool manufactured front loader, the following link explains how to lock/unlock this feature:
http://www.fixya.com/support/r3608801-control_panel_lock
These instructions are also printed on the front panel of the appliance and in the owner's manual.
If this does not correct your problem, then you may have a more serious problem than a simple operator control button issue (such as an operator console problem or main control board issue). Please post back and let me know if you need further assistance. I hope you find this information helpful.
Posted on Apr 27, 2010
The 'CONTROL LOCKED' light is on and I am unable to use the dryer.
Have you tried turning the control lock off by holding down the designated button or buttons to do so? If that does not work try disconnecting power from the machine for a short period of a time and then reconnecting to see if a reset resolves the problem.
Jun 21, 2012 | Whirlpool Dryers
Lock light is blinking / oven light on
i would unplug it or turn the breaker off to the unit for at least 5 minutes see if this resets it or the code goes away, if not then usuallly the lock flashing relates to a bad lock assembly,, also if there is any control locks make sure those havent been accidently puches hope this helps
Jan 31, 2010 | Frigidaire Kitchen Ranges
Control locked indicator light on
some one may have pushed the child lock.it is one of the buttons on the pannel. it may just have a picture of a pad lock next to it. push and hold it for 4 sec. Of to the right.
Nov 21, 2009 | Dishwashers
We had a lighting storm and the current went off. When the current came back on the oven door locked and now wont open.
The lighting has sent a surge though the control board, in return, causing a short within the main control circuits.
The EOC(electronic Oven Control) is unable to send the unlock command. it is shorted at this time. replacing this failing oven control(EOC), will restore the normal functions of this unit.
Normally, you would recive a door lock malfuction error code in this case to signal a door lock mechinism failuer but, in this case, the control has took a direct hit and, it is unable to fuction correctly.
Jun 15, 2009 | Maytag CWE4800A Electric Single Oven
Control Lock is on my front loader.
You should be able to unlock the control lock by holding the "end of cycle" signal for 3 seconds or until the "control locked" status light turns off.
If that doesn't work, please post your model number.
Mar 07, 2009 | Whirlpool GHW9400 Front Load Washer
Water is not coming into my Maytag dishwasher.
Is the door open or unlatched?Make sure the door is completely closed and latched. On models with a dual-digit display, the control displays "- -" during a cycle if the door is not latched. Check for obstructions (spoons or utensils), that may be interfering with the door operation. A lower dish rack that is installed backward will also cause incomplete door closure. The lights for cycles selected will flash if the door is opened while running a cycle.
Is there power to the dishwasher?Check your household electrical box to see if a fuse has blown or if the circuit breaker has tripped. If the unit has a plug-in power cord, make sure it is plugged in.
Does your dishwasher have a rotary timer knob?The cycle selection must match the position of the timer knob. Turn the timer knob to the beginning of the preferred cycle. The timer knob should click when you reach the start of the cycle.
Is the control lock option activated?
The indicator light next to the lock graphic will illuminate when the controls are locked. Press and hold the Heated Dry option (button with lock icon) for three seconds and the light should turn off. Instructions are also placed on the label on top of the inner door to unlock the controls.
Is the delay start option activated?To cancel the delay and cycle, press Start/Cancel twice.
Is the water shutoff valve turned on?Make sure that the water shutoff valve is turned on.
Mar 03, 2009 | Maytag 24 in. MDB6600A Jetclean II...
Dryer problem
try pressing the End of Cycle button on the far right for more than 3 or 4 seconds.  It should reset.
Dec 28, 2008 | Whirlpool GEW9250 Electric Dryer
Control lock
bottom button on last row on right side of control panel depress and hold for 3 seconds it should activate or deactivate control lock if this does not help you could have a faulty control panel
Dec 14, 2008 | Whirlpool GEW9250 Electric Dryer
Dryer problem
Here is the link to the owner's manuals etc. if you need it; http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=GGW9250PL&siteCode=WHRCOM Check the first owner's manual, page 14. It says; " Control Lock. This feature allows you to lock your settings to prevent unintended use of the dryer. You can also use the Control Locked feature to prevent unintended cycle or option changes during dryer operation. To enable the Control Locked feature when dryer is running: Press and hold the END OF CYCLE SIGNAL button for3 seconds. The control is locked when a single beep is heard and the Control Locked status light is on. When the dryer is off, it is not necessary to press the Control On button before activating the Control Locked feature. To unlock: Press and hold the END OF CYCLE SIGNAL button for 3 seconds to turn this feature off. NOTE: When the dryer is running and Control Locked is on, the dryer can be stopped by pressing the Pause/Cancel button, but can?t be restarted until the control is unlocked." Hope this helps :)
Jul 16, 2007 | Whirlpool GGW9250PL Gas Dryer
Whirlpool Duet GHW9150P Front Load Washer Logo
57 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
