Question about Microsoft Windows XP Professional
Sc990 in ricoh aficio2045 - Microsoft Windows XP Professional
  • 903 Answers
Sc990 is a non-specific software error. Many times a firmware update will fix it. In the meantime, turning the machine off and back on should reset the code.
If your machine is very dirty or hasn't been serviced in a long time, that could cause the sc990 code as well.
Posted on May 29, 2010
Update firmware for MP 1600
SC990 means that the hard drive has failed..... It needs to be replaced with a new one or a hard drive from another copier of the same model. Or you can disconnect the finisher.
Jan 12, 2014 | Ricoh Aficio MP 1600 Black and White...
SC548 AND SC990
Sc548 can generally only be reset by entering service mode, and generally is caused by a defective thermistor (thermostat) in the fuser, and/ or power fluctuations. Sc990 is a software issue. I'd consider a new HDD> You'll need a tech for these problems.
Aug 13, 2011 | Ricoh Aficio 2022 All-In-One Laser Printer
I have problem in Ricoh AF 2045 SC 990 pl z help me out from it
this is software performance error.but this in most cases will appear on life over of either drum or developer.
Jul 26, 2011 | Ricoh Aficio 2035 Copier
Sc990- functional problem
sc990 has many reasons first drum unit defeactive and software on machine sluggish
Feb 22, 2011 | Ricoh Aficio 250 Copier
Service SC 990 RICOH Aficio 551
sc990 is a general software error. It could be caused by a specific application or function, or it could be caused by a problem with the process control. In general, you can get rid of the sc990 error by turning the machine off with the main power switch (the orange switch on the left side of the copier) but if the error comes right back, the best first solution is to update the machine's firmware.
Nov 18, 2010 | Ricoh Aficio MP 1600 Black and White...
Sc990
sc990 is the software problem. replace the HDD of the machine and it should be fine. don't format the hard drive as it might result in laser error code.
Oct 22, 2010 | Ricoh Aficio 1035 Copier
I have A problem of SC990 in the ricoh aficio 2035/45 and also I get light copies and over tonning problem.
The light copies and overtoning is probably caused by the developer going bad. Do you have a service contract on your copier? It's likely time for a whole PM (preventive maintenance) procedure.
The sc990 is probably caused by the copier's condition as well. Once you have the PM done (or at least replace the developer, rebuild the photoconductor unit, and clean or rebuild the transfer unit) the sc990 codes should go away along with the poor copy quality.
Jun 19, 2010 | Ricoh Aficio 1035 Copier
Sc990
sc 990 relates to the nv ram chip on the main board also check the values of the lazer unit are correct and not changed
Jun 16, 2010 | Ricoh Aficio 450 Copier
I have ricoh 1035 & eror sc990. without hdd ,i can print and copy one side and by hdd i have error. i do . & # toghter for 10 second for soft reset and nothing happend. in code menu: 5801 - 2109 -...
If you use Katun OPC drum in your machine and is work more 80000 copies you need to replace the OPC drum and the drum cleaning blade.After replace the drum perform the process comtrol and the SC990 disipaire.Whenever use other genuine parts and not original Ricoh parts appair SC codes to refer HDD parts.100% this method is working.
Nov 21, 2009 | Ricoh Aficio 1035 Copier
Ricoh 1045 sc990
Generally changing the cylinder (blade and developer) Initialize td and id sensor usually it is solved. If it is not thus it proves the following thing: press point and numeral (enter) simultaneously for more than 10 seconds until this clear the service call. If the problem persists can be the hard disk, change.
Jul 31, 2009 | Ricoh Aficio 1035 Copier
Microsoft Windows XP Professional Logo
908 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
