Question about Gateway FPD2275W LCD Monitor
Screen goes white
A recurrent problem that is now happening more frequently. In the middle of working the screen goes totally white. Used to be able to fix by turning monitor quickly off and on, but now can take up to a dozen attempts, which can't be doing the monitor any good. Does anyone have any idea what is causing this? white monitor
  • Anonymous Apr 05, 2008
    Screen has just turmed bright white. It is tht same if I use my laptop or my desktop
  • Anonymous Oct 22, 2008
    screen turns black after 15 seconds have to turn it back on
Help what is the problem? Why does my monitor go white on me
Posted on Oct 20, 2008
    Novelist:
  • 159 Answers
White screen means no signal from the video card to the screen.
You have to take it apart and check the ribbon connections first. If they are okay it could be a fuse on the rear of the lcd panel , But usually when these go, they go, unless it is a resettable one.
It could also be the video board is heating up and starting to go.
ebays bammbammfran
Posted on Oct 10, 2008
Monitor aoc modelo1770 no puedo controlar el menu sequedo fijo y pasa resetiando se activa todas las funciones solas si me pueden ayudar se lo agradesco muchas grasias
Posted on Mar 24, 2008
SOURCE:
Packard bell notebook screen problem?
If hitting it seems to remedy the problem, I would say you probably have a loose cable somewhere. Either the Video Cable that is at the top behind the screen is loose or the LCD Inverter at the bottom of the screen (has 2 cable in it) is loose.
Mar 28, 2012 | Computers & Internet
How it happen I don't know. 1. There is a horizontal line found on the middle of the window. 2. Many times window is flactuated and total window convert into white screen. At this time if I push or...
The connector that plugs in the LCD panel has got loose with time. You must open the lid of the laptop, access the LCD panel and reseat all connectors and contacts on it = no new parts needed.
Nov 02, 2010 | Computers & Internet
Flash videos on line/ full screen goes to a white full screen
you could try windows media player as default it works for me
Jul 11, 2010 | Microsoft Internet Explorer 8
Random White screen On PB LCD 22inch
When the screen glows grey/white, it means that the T-CON board is bad or it is not getting the 5vdc from the logic board. or loose conection on the T-CON board which is part of the LCD panel assembly.
Does it look like this when it goes out? Checkto see if the 5vdc goes away when it goes out, the 5vdc is supplied through the switched transistor on the logic board..
http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
Jul 02, 2010 | Soyo 19" LCD Flat Panel Monitor
Screen goes fuzzy and blank.
u need a new phone i ahda similar problem with my lg kp500
Aug 09, 2009 | LG Dare VX9700 Cell Phone
White blank on acer 4315
Go to www.acer.com, choose Service and Support, choose Driver Download, choose Drivers & Downloads, select Product Line Notebook, select Aspire 4315, click Search.
The above should get you to here :
http://www.acerpanam.com/synapse/forms/portal20.cfm?website=AcerPanAm.com&siteid=7117&areaid=2&formid=3394#results
Click on "Flash BIOS v1.13 " which is the latest BIOS for the 4315.
Follow the instructions to download and extract the files.
In order to Run the Vv2-113.exe file, you will need to right-click on it and choose "Run as administrator"
Make sure your battery is fully charged before updating a BIOS and do NOT power off the laptop during the update process.
This seems to have fixed most of the white screen problems on the 4315 that I am working on. The Fn-F4 "standby" and power button (or FN key) "resume" process described earlier is worth remembering because I have still had a couple of the white screens with the latest BIOS. Both times seemed to be when the screen saver was trying to start (lots better than during the boot-up!), so I have changed from the Acer default screen saver to something simpler hoping that the change makes the problem less frequent.
Nov 11, 2008 | Acer Aspire 3690-2196 Notebook
Bleeding picture - unwatchable
Sounds like to me the set has some cold solder joints or fractures that are changing with temperture and can be fixed possibly. Are you located locally to me? i may be able to assist with the repair of your unit. Let me know and good luck. Jay
Jan 31, 2008 | Relisys RTL1720 17 in. LCD Television
Lg vx 8300
My screen goes blank from time to time and when I turn it off and turn it back on again, it seems to re-boot itself and is fine. However, I have never had this problem with any other phone and fear my phone may be dying. It is only 1 year old and worked fine for the first 8 months I had it. But the blank screen seems to happen more frequently lately. I don't think I will buy and LG again.
Jan 28, 2008 | LG VX8300 Cellular Phone
Picture/image problem
Bad solder connection in the horizontal pincussion circuit.have someone resolder.God luck.4tune
Jan 09, 2008 | Televison & Video
Monitor goes black with a white horizontal line across the middle of the screen
Check to see that the monitor cable is correctly installed. Also, make sure you have the most up-to-date drivers installed for your graphics adaptor card(both ATI and Nvidia carry catch-all driver programs to keep you up to date.) Tighten the cable screws of course, to make sure the monitor cable isnt just wiggling in its seating.
Jun 05, 2007 | LG Studioworks 900B 19" CRT Monitor
Gateway FPD2275W LCD Monitor Logo
351 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
