Question about NetGear WGR614 54 Mbps Wireless Router - Wireless router - EN, Fast EN, 802.11b, 802.11g
Wireless connection problem
Unable to connect with netgear wireless router,after a reboot?can only get an internet connection via a direct ethernet link from comuter to router? i was given the following 192.168.1.1 from virgin,no luck with thiss?it keeps asking for a security key have forgotten this.
    Genius:
  • 1,584 Answers
That is the correct access IP address to acces the router properties.
If its a forgotten password you will need to "reset" the router to default by straightening out a paper clip and insert it into the rear of the router till it reboots.
BEWARE this will wipe username and password for the internet and security key. If you dont know your U/N and P/W then call the ISP to reset it.
To enable the above access the router by using the above IP address and re-insert U/N and P/W.
Access security options in the router menu and follow instructions to recreate security password.
Posted on Apr 27, 2010
No internet access netgear router
It may be the device you are trying to connect. shut down everything, unplug , remove batteries, plug in the ISP model, allow the self test, plug in the wireless device, allow it to self test, plug in, reboot the device, laptop, desktop, ipad, phone, whatever. You say you can connect using a Ethernet Cable? Just no connection wirelessly?
Apr 06, 2013 | Computers & Internet
How do i connect to apples time machine?
You can manually configure the time machine to accept wireless signal from the router or extender. If you setup WEP on the router or extender, make sure you setup WEP on the time machine as well.
For instructions in setting up wireless settings of Time Capsule click on this link -->>
http://www.apple.com/timecapsule/wireless.html
Hope this works for you.
Nov 10, 2011 | NetGear WNR2000 Wireless Router
Unable to connect EpsonTX710W Printer viaNetGear DG384
On your Laptop go to Control Panel-> Printers-> and then add printer. Select the option of network printer and search for your printer. If found add it.
Or Else check the ip of printer from ports tab in printer properties on desktop computer ans search your printer with ip address on Laptop.
Jun 01, 2010 | NetGear DG834G Router
CHANGE FROM WIRELESS TO WIRED INTERNET CONNECTION
It is possible .. just get youself an ethernet cable .. connect one end to your router and the other end to the back of the pc ( ethernet port ) .. and u will be connected via the wire.. You can disable the wireless connection from the router for that you can either call your Internet service provider or the netgear support team.
All The Best!!!
Please come back to vote, it would be a great appreciation for me and boost my determination to help so that I can keep on helping.
Zooless
May 24, 2010 | Computers & Internet
I changed the username and password on my Netgear router so make it more secure. Now, I can't get an internet connection when i have my ethernet cable plugged in to my router, only when I have it directly...
  1. Set up and plug in the Netgear router and wait a few seconds for it to boot up. Since the router is essentially a mini-computer, it won't work instantly when it's turned on. While it's booting, the power light should flash. When it's finished booting, the power light should stay solid.
  2. Step 5 Connect a computer to the router, either with a wireless or a wired connection. Reboot the computer to ensure it gets a new IP address from the router via Dynamic Host Configuration Protocol (DHCP).
  3. Step 6 Open the web interface by entering "http://192.168.1.1/" into the address bar of your web browser. If a login screen is presented, use "admin" as the username and either "1234" or "password" as the password.
  4. Step 7 Connect to the Internet, if necessary. Plug your cable modem or DSL modem into the router's WAN port in the back and run the Internet Connection Setup Wizard from the web interface.
  5. Step 8 Follow the directions and provide authentication information.
  6. Step 9 Connect more clients. At this point, clients should be able to connect and access the Internet.
Apr 29, 2010 | NetGear WGT624 Wireless Router
I can't access the internet via my Optus Netgear
I am having exactly the same problem. It occurred on Sunday 17th. I have phoned Optus who seem unable to work out what has happened. It will work wirelessly but not recognise it when set up via ethernet cable.
Jan 17, 2010 | NetGear CG814M Wireless Cable Modem...
Cannot connect to internet via wireless router
You better reset it to the factory settings and reconfigure
Nov 08, 2009 | NetGear WGR614 Wireless Router
No access to internet via wireless or ethernet
Check ADSL is active and connectted on the router.
Use webmanagement link the link below.
http://192.168.0.1
username: admin
password: admin
If the above details does not allow you to connect, check under the router for correct details.
Mar 11, 2008 | NetGear DG834G 802.11G Wireless ADSL...
Plz solve
need more information - do you have cable? DSL? Are you able to connect when you put the Ethernet cable directly into your computer and bypass the wireless router? The wireless signal is only indicating that your router is "broadcasting," but does not mean you have a usable Internet connection.
Feb 17, 2008 | NetGear WGT624 Wireless Router
Wireless routers
Just plug the cable modem ethernet into the input to your router and you will be fine. Just remember, if you decide you want to make any changes to your router settings through your browser, make sure you hook up an ethernet line from your laptop to the router before making any changes. The reason for this is if you make a change in security settings on your router while wireless, the router will reboot and if your laptop did have the settings changed in it, you can be locked out.
Not that you can't get back in, but it is a pain to have to do.
Jan 14, 2008 | Arris SURFboard SB4200 Modem
NetGear WGR614 54 Mbps Wireless Router - Wireless router - EN, Fast EN, 802.11b, 802.11g Logo
178 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
