Question about Hotpoint Ultima WF840 Front Load Washer / Dryer
Error code F 13
I can't find my instruction manual and when i run a drying programme after about 10-15 minutes it comes up F 13.
  • 2 more comments
  • Anonymous Mar 27, 2008
    F 13 appears and dryer cuts out
  • sarahjayne3 May 05, 2008
    We are having the same problem at the moment, did you find a solution??
  • hr9hr9 Jul 07, 2008
    I have the same problem. This has happened before approx 6 month ago before my machine was even 12 month old!!! The engineer fixed it for me and told me that is was because there were so many wires near the motor and it all gets quite hot and the safety mechanism cuts it off before a fire can start etc etc.
  • bunny32 Jul 18, 2008
    I'm the same-i can't find my manual, but looking on the internet other people have had this too and no-one has the answer so it's obviously not in there anyway. My machine smelt as if something had burnt out last night, how safe is that? Has anyone found out the answer yet? Can you replace the parts yourself? How much do they cost?
  • 24 Answers
F-13 is heating element or thermostat.
remove plastic panel at bottom back, look for black marks in line with the heating element at bottom middle of drum.
part number: 1604486 may fix your problem
Posted on Apr 18, 2009
SOURCE:
How to correct error code 4 in 10 on Sharp pocket computer pc-1270
I found the answer for the PC1500, and I'm guessing the error codes for the PC1270 will be similar. Here is what the manual says:
This error occurs when there is no DATA corresponding to a READ command, for example:
10 READ X, Y
20 DATA 10
30 END
The display will say, "ERROR 4 IN 10"
The solution is to provide enough DATA to satisfy the READ. For example, change line 20 to read as follows:
20 DATA 10,15
Hope this helps.
May 04, 2017 | Sharp Office Equipment & Supplies
Zanussi zdt 6053 usually will not run full cycle (on any cycle) but stops with constant error beeps. But it is draining ok and sometimes goes full cycle (not often) Any ideas?
Could be anything!
If you suspect that there is a fault then it will be displayed by blinking LED "END OF CYCLE". As the display of failure in hexadecimal code it can flash up to max. 15 times than short pause and after that repeat fault code. You must to count the number of times the LED "END OF CYCLE" flash up.
Example from user manual: Anti-flood device is activated.
- continuous flashing of the indicator light of the running programme
- 3 intermittent audible signals
- 3 flashes of the END OF CYCLE indicator light
(which means "i30" fault code, the cycle is interrupted and the
drain pump switches on).
Possible causes:
Water leakage from the tub - sump and various connections
(pump, upper spray arm duct etc.); floating sensor blocked
mechanically; microswitch faulty; fill solenoid blocked
mechanically; circuit board faulty (solenoid triac short-circuited);
wiring faulty.
26226179-aipk5px1bmfkdpsmrgevaqwn-3-1.jpg Could be also:
To cancel a washing programme in progress:
- Open the dishwasher's door.
- Press the programme selection/cancel button for about 3 seconds,
until the indicator light of the running programme turns off and the
END OF CYCLE indicator light flashes, indicating that the running
programme has been cancelled and that the machine has
returned to setting mode. It is now possible to select another
washing programme. If a new washing programme will be
selected, check that there is detergent in the detergent dispenser.
NOTE: only during the drying phase, if the dishwasher's door will be opened and remains open for more then 30 seconds, the running programme will be automatically cancelled and the machine will return to setting mode. This will happen, always only during the drying phase, also when the machine is switched off by pressing the
On/Off button and remains switched off for more then 30 seconds.
Dado
Jun 26, 2016 | Zanussi Dishwashers
Hi, my Electrolux EWX12550w washing machine and dryer, working fine on was but when I'm drying it it starts at 13 minutes then keeps working but sticks on 10min also I get an err sign it's E10
Family error code E10 is visible to customers and (could be E11,E12 and E13 only visible in service mode) means problem
with filling water.
I suggest rapid reading alarm code when appliance is in normal operating mode (e.g. during the execution of the washing
programme).
Press and hold down START/PAUSE and the nearest option buttons for at least two seconds: the LEDs initially switch off, and then display the flashing sequence corresponding to the last alarm.
The alarm sequence continues as long as the two buttons are held down.
E11 - Problems with water fill for washing
E12 - Problems with water fill for drying
E13 - Water leakage
I believe there are difficulties in water fill for drying.
Water is necessary in the drying phase in order to cool down the steam entering in the drying condenser.
Possible causes: Tap closed or water pressure too low; Drain tube improperly positioned; Water fill solenoid valve is faulty; Leaks from water circuit on pressure switch; Pressure switch faulty; Wiring faulty; PCB faulty
Dado
Sep 07, 2015 | Electrolux Washing Machines
Dryer function on De Dietrich washer-dryer doesn't work
take care do not play with electric ??????????
????????????????????????? warning????
check heating element
check stats
check you have power at element
Nov 05, 2012 | De Dietrich LZ9619 Front Load Washer /...
Hoover washer dryer Error Code E12 during dry programme. How can I fix?
E12 means a problem filling on dry cycle.
Unplug the appliance, take the top off and check that the plastic condenser below the fan is clear and clean.
If this is ok, the most likely fault is the triple valve isn't opening properly to feed water into the condenser.
Nov 03, 2012 | Washing Machines
I need an instruction manual for an Omega WD 1052 washer, please
I have searched everywhere as well, and no luck. I did find a bit of information on it which I have pasted below -- it might help a bit if you want to play around with it.
I would also suggest reading manuals from other wash/dryer machines to get an idea how they work--then maybe you can figure yours out by just pushing the different buttons and seeing what the display says. (At the end of this post, I have pasted a link to a different Omega washer/dryer -- perhaps you could skim it and see if it is at all similar to yours.)
Information About the Omega WD1052.2 washer dryer
THIRTEEN PROGRAMME:
The WD1052.2 is sequentially segmented into thirteen rotary positions for both easy and logical programme selection and for the quick identification of programme progression.
Choose from one of three wash sequences:
Programmes one through five are for the heavily soiled, more colour fast fabrics and daily wear.
Programmes six through to ten look after the slightly soiled, synthetics and for delicate items.
Woollens are exclusively washed on programmes eleven through to twelve.
CONDENSER DRYING:
The WD1052.2 can automatically dry a half a load of washing at the end of the wash programme provided the half load button is selected and a drying time is set on the centre control dial.
At any time the WD1052.2 can be regarded as an independent dryer, that is, a wash programme does not have to proceed into the drying stage. An example would be drying damp clothing or toweling from the bathroom. Simply choose a STOP position after either 5 or 10 on the programme dial. On the centre dial choose either full heat, the pink zone, or half heat, the green zone.
Another useful variation of the WD1052.2 is the ability to choose final spin only followed automatically by condenser drying. Having completed a hand wash, for instance, simply load the clothing and select final spin, 5 or 10 with the half load button selected and drying time set.
Whenever the WD1052.2 is in the drying mode the load can be easily accessed at any time via the porthole. The drying will automatically resume once the door is reshut.
Specifications:
Freestanding or Built-in
5kg (11lb) dry weight Capacity
2.5kg (5 1/2 lb ) dry weight condenser
13 Programmes
40 minute Fast Wash
Special universal 2B programme
Dedicated woollens cycle
Independent wash temperature control
1000 or 500 r.p.m spin speeds
Half load Economy selections
Drip dry no spin programming
Anti crease hold in final rinse Selection
Extra rinse option
Two drying heat settings
Stainless steel inner and outer wash drums
Two minute delay safety door release
Built-in heating element
Front mounted easy access lint/forgin matter
inspection
Automatic balancing of wash load
LINK TO A DIFFERENT MODEL:
http://www.omegaappliances.com.au/Documents/Document_205.pdf
Good Luck--I hope you get it working!
P.S. If you find this information useful, please remember to rate me! Thanks!
Mar 18, 2009 | Washing Machines
F17 Fault on Bosch WDV24520
If you open the washing machine you will find a packing slip with all the information on the error codes and electrical schematic. F17- covers the following problems - supply hose kinked/jammed, clean filter, water pressure too low..hope this helps
Mar 14, 2009 | Washing Machines
Washing machine programme error
Hi, my LG manual for WD1238C says that OE is Drainage Trouble would imagine the Error codes are the same for all LG machines.
Jun 14, 2008 | LG Washing Machines
Minolta Di151 Error Code C-13
The trouble is that Minolta did not provide a chart of error codes in the user manual; mostly error code issues would require a technician to repair anyway -- or at least somebody trained to do preventive maintenance. If you have a routine repairman, or if you have My Konica-Minolta access, you should be able to get more information that way. Other things to check:
  • Is a preventive maintenance due?
  • What was the unit doing before it threw the code? Was it making copies? Of what quality? Did it stop in the middle or finish a run?
  • Are you using good quality, dry paper? This was posted in December -- might you be having static problems due to dry air?
If you're in the United States, you can check Konica-Minolta's Sales/Service Locator for a local repair outlet. Otherwise, you may need to contact Konica-Minolta directly.
Dec 26, 2007 | Minolta Di151 All-In-One Laser Printer
Display panel (cont.)
hi there try pressing and holding the start button for about eight seconds
Oct 10, 2007 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Ultima WF840 Front Load Washer / Dryer Logo
582 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
