Question about Canon imageRUNNER 6000 Copier
The green power light comes on and the doc feeder pickup tire solenoid cycles twice when the copier is turned on, but the display doesn't light up and nothing else comes on, runs or cycles. Have turned it off and on and unplugged it a couple of times, but still the same thing.
  • 1,219 Answers
It may be stupid but check the display contrast, around button with half white half ligt. If it is stupid thing replace display.
Pls. rate :-)
Posted on May 10, 2010
Testimonial: "Thanks for the suggestion! The problem, however, turned out to be a loose wire on the fuser web-out switch that was touching the frame."
Konica minolta bizhub c654e error 9401
Raise the doc feeder when you press start to make a copy does the bright lite come on???? Try this procedure if code come back have tech come to replace the bright light under the big glass
1.
Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
May 20, 2016 | Konica Minolta Office Equipment & Supplies
Lights on console are off and unit won't start.
Hello Brian,
I had a similar problem with my dishwasher sometime ago. My husband tried to fix it following the owner's manual instructions but nothing happened. Tired of trying it I called a technician and they came the same day and fix it! They had to replace the keypad, I don't remember how much it was but I know that it was a fair price, around $150, much less than buying a new one!
I'll give you their contact info just in case it helps you. Good luck!
Appliance Repair Toronto Fix Appliance Repair
Mar 15, 2017 | Kenmore Dishwashers
How to fix error c9401
Exposure lamp failure to turn on, raise the doc feeder hit the start button bright light come on under the big glass if not replace the exposure lamp and board if required.
reset procedure if code comes back get the lamp
1. Turn OFF the main power switch.
May 20, 2014 | Konica Minolta Bizhub C300 All-In-One...
Como soluciono error c-9401
the bright light under the big glass failure to turn on, raise the doc feeder then hit the start button to copy something a very bight light should come on, if not get the exposure lamp and or board replaced
try this once if the code comes back do above
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON again while pressing the Utility/Counter key more than
10 seconds after.
5. Turn off the Main Power Switch and turn it on again more than 10 seconds after, and make sure that the machine properly starts.
Feb 14, 2014 | Konica Minolta bizhub C351 All-In-One...
Auto doc feed does not activate
two possible problems :
- check the connection of the document feeder
- check the sensor on the document feeder that triggers the pickup
- check the clutch of pickup roller
Jul 27, 2012 | Canon PC-795 Copier
"remove original from document processor"
Sensor in feeder is probably broken. To get around this until you can get it fixed power down the unit and unplug it. Unplug the cable that connects the Doc feeder (in the back) to the main unit (two screws hold it on. Then power the unit back up it will work with out the Doc feeder. You will just have to put the copies on the main glass.
Jun 29, 2011 | Kyocera Copystar CS-1820 Black and White...
Error Code E000001-0004
The main thermistor TH1 has poor contact or open circuit.The thermal switch TP1 has an open circuit.The fixing heater has an open circuit.The SSR is faulty or the DC controller PCB.After the main power switch is turned ON the temperature detected by the main thermistor does not reach 70 C.The error must be reset in service mode :COPIER - FUNCTION - CLEAR - ERR
Jan 19, 2010 | Canon imageRUNNER C3200 Copier
Minolta DiAlta model 151f, when i try to use the automatic paper feed on the top of the machine the paper goes in about half way then stops then a message comes caution original doc jam
Try cleaning the pickup wheels that pull the paper into the feeder. There might be an electrical sensor problem also that is not sensing the right paper size. So lets start with cleaning the feeder
Jan 04, 2010 | Minolta Office Equipment & Supplies
Doc. feeder jam, after paper removed completely
HP LaserJet 3030 All-In-One Printer
Mar 11, 2009 | HP LaserJet 3030 All-In-One Printer
Canon imageRUNNER 6000 Copier Logo
56 people viewed this question
old marine
old marine
