Question about HP DeskJet 812c InkJet Printer
Spread sheets run togther and pictures won't print. Pictures print partially, but are skewed.
    Genius:
  • 1,584 Answers
I would uninstall drivers / re-install.
NB = Do not plug printer in till it tells you to.
Posted on Apr 27, 2010
HP LASERJET 3800 PRINTS THIN BLACK LINES ON PICTURES
that print head is clogged,
do the clean cycle shown in the manual;
new cartridge time if cleaning does not work.
all things work last week but now.
nothing new here and for sure pesky printers
and for sure not used every day. (this keep them going more reliably)
made back in 2008, so is getting long in tooth and on most this full cleaning of the whole printer is advised. ever do that?
per manual?
rtm?
https://support.hp.com/us-en/product/hp-color-laserjet-3800-printer-series/500934/manuals
Oct 09, 2017 | HP Color LaserJet 3800
Why does it print with streaks through the pictures even when ive done the cleaning method a million times?
I've had that problem and running the special blue sheet that comes with the paper pack through the printer seems to work. I've had to run the blue sheet through before each printout for a while, but the problem seems to have gone away - I guess it finally got cleaned out. It also seemed like running the blue sheet through after not using the printer for several weeks was a good idea before printing. When I get a new pack of paper, I run the blue sheet through as instructed. Instead of throwing the sheet away, I store it on top of the blank sheets inside the printer. That way I can use it again if needed.
Sep 29, 2011 | Polaroid CZA10011B PoGo Instant Thermal...
When printing pictures, I use the photo paper mode, but the pictures come out blurred and skewed. The Printer makes a lot of grinding noises.
I would say that your printer ink heads need to be alined, in the software that was provided with your printer, select align printer ink heads.
Thumbs up!!!
damnor01
Nov 07, 2010 | HP PSC 1210 All-In-One InkJet Printer
Print head seems to be out of alignment. Lines of print seem skewed and blurry. Edges of pictures are not in alignment.
Run the alignment in the maintenance software. Each new print head must be aligned.
Possibly release and remove the print cartridge and reinsert it. Maybe it is skewed.
Mar 21, 2010 | Canon PIXMA MX700 All-In-One InkJet...
My praftically brand new Canon Pixma MP620 printer grabs more than one sheet of photo paper and stops printing picture on first sheet then garbles several pictures on a portion of the next sheet. I just...
check the printer's printing preferences on properties option.should be set to normal then check the printer rollers if its dirty where the papers pass thru, if the problem persists load only 1 paper every time you print for the printer not to grab more papers.i think it is in the feeder and the sensor maybe its dirty need to be cleaned up.
Feb 22, 2010 | Office Equipment & Supplies
When I print something on my hp 6210, the words and pictures are bisected and skewed. Why is it doing this?
You may have a paper path problem, if the paper skews during printing you will get skewed lines, try cleaning all the paper path rollers you can access, look for any paper debris.
Jan 03, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Pictures are printed with stripes and poor color
make sure your printer printed an initialisation or alignment sheet once you installed the new cartridge.
you can try a partial reset of the printer and check if the printer prints fine,also there is an option of cartridge calibration in the printer properties or the printer software installed in your computer
Jun 13, 2009 | Canon PIXMA MP780 All-In-One InkJet...
I recently plugged my printer into a USB Hub Adapter, and since then it won't print a total document. At best, half the document, but usually just an inch or so. I've checked all the settings. Things LOOK...
The printer is an HP Officejet v40. It appeared to be fixed last night and printed out one entire sheet, but then went back to only printing out partial pictures and text. How much would it cost me to find out how to fix this? Do I need a new driver? What could it be?
Barb Thompson
May 14, 2009 | Brother HL-2040 Laser Printer
Streaks in my pictures
You can clean the print head by using the following procedure from the troubleshooting section of the manual:
Take paper out of the printer
Take a single sheet and put it back in - upside down (i.e. shiny side down).
Close the door and wait for the sheet to eject.
Put all the paper back into the printer in the correct orientation (shiny side up), close the lid and print again.
I've discovered even better results by keeping the special blue sheet that comes with each paper pack. I run the special sheet through before I'm about to use the printer for the first time (after not using it for a few days), and also after every three prints. The result is much better printouts for me. The special blue sheet cleans and calibrates the print head. Just put the blue sheet in the paper tray at the bottom of the stack with the bar code facing down and close the lid. It will automatically eject.
May 11, 2009 | Polaroid PoGo Digital Photo Printer
Printing out of square
If the problem is with the single sheet feeder try running regular paper through it - does it have the same issue? Is the paper skewing as it is fed in or is the print itself. If the paper is skewing look for problems with the feed rollers possibly a label has become attached to one of the rollers. If not try cleaning them with (90% or better) isopropyl alcohol on a soft rag
Jan 13, 2008 | OKI B4350 Laser Printer
HP DeskJet 812c InkJet Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
