Question about Compaq Presario 700 470024-192 Notebook
I have using laptop it mic is not working but audio is working
    Genius:
  • 1,584 Answers
You need to go thru Contol panel / sounds / and tick / activate MIC.
Posted on Apr 27, 2010
Built in mic not working
It looks like you installed a program (one that uses audio) that uses different settings for audio. If this is the case; go into that program and go to preferences or advanced settings etc and disable the audio and change it to default audio.
If not let me know :)
Oct 27, 2013 | Fujitsu Computers & Internet
I have an HP Pavillion dv2700 laptop with windows Vista. My mic was working fin until a few weeks ago, now no one can hear me on google voice or skype. I checked the mic settings and it is not muted and...
You can try going into device manager and find the device and remove it then reboot and let it reinstall the mic drivers. If that does not work try going to the HP site and see if a new driver is available and install it. The mic could have gone bad and you may have to buy an external mic.
Thanks for using FixYa
May 30, 2011 | HP Pavilion DV2910US Laptop
Webcam recorded audio have interferance
make sure you only use 1 mic .if that dont work try pluging in a diff mic. most laptops have built in mic's it might be bad disable it in control panel and use new mic
Oct 07, 2009 | Toshiba Satellite A135-S2386 Notebook
Please help me
You need to check if the mic/s is working?
Are you certain the Logitech webcam has a built-in mic?
To check if the mic works go to Start - All programs - Accessories - Entertainment - Sound Recorder and test record your voice and play back to check, also try it with the laptop's built-in mic (if it has one) and the Logitech mic.
If both mics work then you have a choice of which one you can use in Skype, most likely the best one would be the Logitech one.
You need to configure your audio settings in Skype.
When you open Skype click on Tools - Options - Audio Settings and click on Select Microphone and select the microphone you are using and save the setting.
If you still have problems get back to me with all details and error messages.
May 15, 2009 | HP 510 Notebook
Audio coming from the built in mic is not working. how to remedy this problem since even Messenger cannot transmit it's audio?
check out the settings for mic and voice chat program is on in your massanger.
mic selection in master volume properties in control panal.
if yet not working check out dust on mic hole.
or replace the mic
if your externnal mic port is not working.
There should be problem in your audio hardware also.
Jan 20, 2009 | HP Compaq nx6310 Notebook
Cannot record sound
Normally every Lap is coming wit internal mic; so
1- Simply check your mic is mute or not
2 - Check your mic volume
3 - Use sound recorder that comings with windows (just record & play)
4 - Use an external MIC (known as working) with sound recorder
5 - Check in control panel->sound and audio device --> default recording device and Voice recoding device as your system’s built-in audio device (some times it’s changing when we installing b-tooth deice)
6 - Check device manager --> under sound audio controller for any issues
7 – Uninstall & install completely your Audio Device driver with default settings.
** If you didn’t solve your prob; my advice is take your lap to a good technician with component level Repair skills.
Thank you & Best Regards
Dinu..
Dec 20, 2008 | Toshiba Satellite A215-S4697 Notebook PC
Creative HS-400 headset & Mic
I had the same problem... with my laptop, using vista. I plugged the mic dirrectly into my laptop and for some miracle, it works! try it out! ^-^
Sep 25, 2008 | Creative Labs HS-400 Headset
Cannot record
Im having the same probz, got a Hp Pavilion Vista using mobile pre amp usb when i record using a condenser mic XLR nothing is picked up from the channels in Cubase or Nuendo. Im trying to record vocals but the Mic is not picked up and i cannot hear myself in the headphones and it wont transfere to cubase.
It has worked before when i had a desktop, but this only worked with a separate m-audio sound card inside the desktop and i plug in the output jax leads from the desktop (soundcard) to the m-audio usb pre amp
Is this why it is not working for the laptop do i need a Jax connection and where is this audacity
Sep 15, 2008 | M-Audio M AUDIO MOBILE PRE - USB MIC...
Compaq laptop c700's mic is not working (sound setting is ok)
My laptop model is compaq presario c754tu, I have installed Windows Vista Business, and the audio is working fine, but the internal mic and external microphone both work together........i want to mute the internal mic..... how i can do it ? please reply me on my email id i.e. vsdoshi@gmail.com
Jun 28, 2008 | Compaq Presario 700 470024-192 Notebook
Internal MIC not working
If you are using xp, try going to the control panel, sound and audio devices, click on audio tab.
to check the mic settings, click on the volume tab under the sound recording sections. Make sure that the mic is selected and the volume turned up. It may be working only to record, not to hearback without recording...so you may have to actually be recording or talking to someone to know if its workings.
To check the sound, check to see if your audio device is selected under "sound playback" section...and make sure that all channels are unmuted and turned up. you may also have to check the volume control on the laptop (actual buttons on the pc) if there are any, and make sure that the volume is up and unmuted there also.
Hope this helps.
Mar 30, 2008 | HP Compaq Presario V6000T Notebook
Compaq Presario 700 470024-192 Notebook Logo
20 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
