Question about Sony Cyber-shot DSC-W50 Digital Camera
When the camera is turned on the lens goes in and out 3 times then "turn the power off and on again". This doesn't work. Do you have suggestions? Thanks Rod
Thank's
Posted on Apr 27, 2010
Lens on my S7000 doesn't retract when switched off - now permanently extended - and camera dead
This is going to require service / repair at the shop, not something you will be able to correct.
Jan 26, 2013 | Fuji FinePix S7000 Digital Camera
When I turn the camera on, the lens goes in and out several times. Then the message comes "turn the power off and on again". I tried taking the battery out, pressing the power button for 15 sec...
Hi there this is Lens guide pin problem. 99% chacHi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success. Thanks & Before you leave, if you have found my information helpful and if you haven't already done so then please press the ACCEPT button, this is how I am paid for helping you today. POSITIVE feedback & bonus is appreciated e is replacing the lens. but before that try these below.
Feb 01, 2011 | Sony Cyber-shot DSC-W170 Digital Camera
Lens goes in and out four times then ask to turn power off and on
Option 1:
Try Initializing the Camera as follow; Initializing the Camera will reset the settings of the Camera to the factory settings including date and time. It will not delete any data saved in the Camera.
1. Touch the HOME and select the SETTINGS menu in the Camera.
2. Now, please select the MAIN settings menu.
3. Then select the INITIALIZE option under the MAIN Settings 1 menu.
Option 2:
If issue persists try Power reset the Camera by removing the battery from the Camera and inserting it after 1 minute.
Option 3:
If the issue still persists then Service may requires to resolve it.
Aug 26, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
Camera lens go in and out about 3 times, I cant take pictures.
1. Remove the battery and reinsert it after 30 seconds. 2. Try resetting the Camera. To reset, refer supplied Manual. 3. If stil not resolved, please get the device serviced.
Aug 06, 2009 | Sony Cyber-shot DSC-W90 Digital Camera
Once powered on the lense goes in and out and to power off
I had the same problem, everything started after we took it to the beach and some sand got inside. After that it wouldn't zoom, but it was working. One day, the lens were going in and out (3 times) and then a sign would appear saying to turn off and on again the camera. I don't know it it was related to the sand grain, but what worked was to shake it and knock it (gently!!) with the hand. Not very orthodox, I know...
Jun 19, 2009 | Sony Cyber-shot DSC-W170 Digital Camera
When i turn on my camera it says Turn the power off and on again
Hey, my camera the dsc- w80 did the same thing. When I turned it on, the lens opened 3-4 times and then it said "turn the power off and on again".
When the lens opened an closed, I pulled on it with my fingers and twisted it. I kept doing that: Turned the camera on and off, kept pulling and twisting the lens and now my camera works again!
May 15, 2008 | Sony Cyber-shot DSC-W100 Digital Camera
It takes time to turn on
I hold the digital camera with the lens upward when I switch it on, and then the problem doesn''t occur and I can take pictures.
I hope that this workaround will also work for you.
Nov 13, 2007 | Olympus Stylus Verve / ?-mini Digital...
Turning on the camera.
I had the same problem. I tried turning it off and hitting the camera on the palm of my hand but that didn't work. But, hitting it one time on the palm of my hand WHILE THE CAMERA WAS TURNING ON worked. I turned the camera on, it moved the lens out and I hit it one time on my hand and it works perfectly now.
Someone suggested it was a problem with the internal lens which makes sense. Also, be careful not to hit a sensitive part of the camera on your hand. I used one of the corners.
Oct 26, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Sony Cyber-shot DSC-W50 Digital Camera Logo
233 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
