Question about Galaxy Radios DX-959 40-Channels Base CB Radio
G959 mod meter will not work but modulation is 100% others rfine?
Bubbles where is your shop at....Do you have a website....Swr & power readings work fine, Just the Modulation mode that will not work...But tested from an external meter I have 100% modulation.Sometimes the modulation test mode on the radio will work but gives highly inaccurate reading just on the modulation test mode......I do know the modulation is 100% it is just the meter reading is giving me inaccurate info..
    Champion:
  • 219 Answers
If its the meter on the radio don't worry about it they do go bad but it won't effect the radio. My shops in North Florida. And no I have no web site at this time.
Posted on May 01, 2010
How to peak mod
you need an external meter.Set it up for SWR on channel 1/19/and 40. Now after you have done this you set the meter on s/rf and modulation.Key the mic and check what your reading is. There is a modulation transformer inside and a variable not to far from it, turn it all the way to the right then all the way to the left.One way should give you more modulation and other should take it away. Just remember where the settings were and if they are not where they were the reset them as you procede
Feb 15, 2016 | Midland 1001Z 40-Channels Base CB Radio
I have a Radioshack trc-487 cb radio with weather band . I would like to turn up the modulation... Peak and tune... get better reception... anything... I would like to know the internal parts I have to...
Hello Randy, do you have a fiberglass or stainless whip? What is your SWR & power meter readings now? --- The stainless whip may be creating a feedback and picking up static from transformers. Do you have a power microphone? If so you need to use a modulation meter to set it for 100% modulation. It could also be causing the crackling, that or your engine alternator.
A 1:1 SWR implies a perfect match between all elements of the antenna system...this is what you want. If an antenna system is not working well, the power reflected by the antenna will travel back through the transmission line and arrive at the output of the transceiver. From a practical point of view, SWR numbers in the range from 1:1 to 1.5:1 are considered to be very good, meaning that the antenna is radiating most of the power sent to it...
I would not recommend tweaking the boards on the realistic radios. You can however tune your whip. Start by making a base coil with some copper wire, 14 gauge will work. Run one end under the whip mount end and then tightly wrap the wire around the base of the whip. Experiment with 20 - 30 wraps for best performance & SWR.
The Astatic 575M6, or the Sadelta MB-4(hard to find) are very good power microphones that will help with modulation and peak power transmissions. Let me know if you need more help with tuning, if the "crackling" is still there.
Here is a link for your radio, in case you don't have one.
http://support.radioshack.com/support_electronics/36554.htm
Nov 16, 2011 | Radio Communications
I can only hear the others. When I talk they can't hear and my red anntenna keeps coming on when I push button to talk.
Assuming the antenna is mounted and grounded correctly,when you try to transmit/talk does your meter needle move to the right with your voice,if it doesn't make sure meter knob is set to receive/transmit or mod[modulate] does it move to right now,if not make sure the mic gain knob is turned up or if it is a power mic,is it turned up&have a fresh battery.The antenna light could mean high swr readings which you will have to adjust by tuning the antenna with the radio meter or external meter,you can search swr adjustment on your computer if unfamiliar..some antenna warning lights are factory set too sensitive but most times are telling you there is a problem.If all is set&tuned properly and you still can't get a local signal to respond, your radios transmit finals could be blown,which you'll need a qualified radio tech to determine..Good luck& 73's
Aug 13, 2011 | Cobra 29 LTD CB Radio
I don't understand how to adjust the SWR or how the built in meter works for my DX949.
Here is a basic instruction on how to adjust the SWR. When you adjust the SWR, you are not changing anything on the radio. You are actually tuning the antenna for best SWR. The lower the better. SWR stands for "Standing Wave Ratio" Or in layman's terms, SWR is energy that is reflected back into the radio. The higher your SWR reading, the more RF energy that is not leaving the antenna, and getting reflected back into the radio. This can cause damage to the transmit section of the radio. The length of the antenna is what will change this. The length of the antenna must match the length of the radio wave. The following instruction will explain how to take an SWR reading, and how to use that reading to ascertain weather the antenna is too long or too short.
Here is a quick explanation of the meter. There are 3 settings for the meter. SWR, MOD, and PWR. When you are not keying the radio the meter will show you your receive signal. How strong some ones signal is. When you have the switch on MOD and key, when you talk it shows you modulation. How much audio you are putting through the radio. When its on power, and you key the radio, it shows you your dead key wattage.
Tuning your antenna:
It is important to tune your CB radio antenna to the proper length. The length must exactly match the wavelength of the frequency you transmit on. Or be really really close.
All Cb antenna's have a way to adjust the length of the antenna. If it's a mag mount, the metal whip can be slid in and out of a metal collar. Usually a set screw. If its a fiberglass whip, the way to tune it is on top. It either has a small metal rod with a set screw to adjust the length, or it threads in and out to adjust length.
Either type you have it will need to be adjusted for proper length. Here is how to tune the antenna to lowest SWR.
Some radios have a built in SWR meter. Some do not. If yours doesn't have an SWR meter, then you have to use an external SWR meter. Radio shack carries one, and you can find them cheap on ebay.
If you have a built in SWR meter or external, the procedure is the same:
1. Turn the radio to CH 20.(This is the center of the band.)
2. Switch the meter switch to SWR
3. Key the radio. (Important. Do not talk while keying the radio.)
Where the meter falls after that point is you SWR reading. If its above 3, that is real bad. 2 is not gonna kill your radio but its not the greatest. 1.5 and under is a good place to be, but the lower the better.
If your SWR is high, Here is how to find out if your antenna is too long or too short.
1. Turn to CH 1
2. Repeat SWR procedure. You must calibrate every time you do it.
3. Remember the SWR reading.
4. Turn to CH 40.
5. Again repeat SWR procedure.
6. Compare the reading between CH 1 and CH 40.
Now if the SWR is higher on channel 1 then channel 40 your antenna is too short. You must make it longer.
If the SWR is longer on channel 40 then on channel 1, then the antenna is too long, you need to make it shorter.
Make height adjustments about an eight inch at a time, and take reading each time.
once the SWR is significantly lower and the reading on channel 1 and 40 are about the same, you a about matched. At this point turn the radio to the center of the band, channel 20 and take an SWR reading.
You should now have a low SWR reading, 1.5 or under. If you are 1.5 or under, you are good to go.
If you cannot get the SWR to an appropriate level, there may be an antenna problem.
Nov 16, 2010 | Galaxy Radios DX-949 40-Channels Base CB...
Cobra 29 ltd classic ant light
Your SWR is probably NOT fine. You need to use an external meter if you have had work done to the radio. Especially if you have had a swing mod done to the radio. When you do this, the dead key of the radio is lower then the calibration knob on the radio can adjust for. It will always come up lower then it actually is.
Your radio might have been fine before the work was done on it because it was putting out very little power. Now you are most likely putting out 50 watts or more. Big jump from 4 watts.
When your raise the power in a radio, you will notice more when the antenna is not properly tuned.
In most cases with a stock CB, even when the antenna is not even near tuned, you will get a reading less then 1.5 anyway.
the more power you put out, the more important it is to have a good match.
But an external SWR meter, and check it. be careful if the ANT light is on.
You might also want to check your coax, connections to it, and your antenna for anything wrong.
Apr 22, 2009 | Cobra 29 LTD CB Radio
Swr meter not moving.
If the radio is working don't worry about the meter unless you absolutely want it. These little meters are not very accurate or reliable. Get an external SWR meter to check the antenna.
Apr 15, 2009 | Cobra 29 LTD CB Radio
Cobra 29 nw ltd classic
Hello candy_72_99,
Hello candy_72_99,
If I am correct what you are saying is that your radio has poor modulation? ok. First I need you to run two tests for me.
1) Power output Test: connect a power meter to the antenna jack and the other connector of the meter to the antenna, Key up the mic and record the power reading is should be 4W PEP or 36.02dbm
2) Then I want you to take an oscilloscope and put a 1khz tone in to the mic while measuring the RF output at 100% modulation the wave form should not clip.
If these two test are good then your modulation is ok. What I believe you are asking for is more power or better power efficiency.
Try to tune your antenna for 1:1.0 or 1:1.2 SWR with a SWR meter this should deliver the full power to your antenna.
I hope this helps
Thank you,
Shuttle83
Nov 04, 2008 | Cobra 25 LTD 40-Channels Base CB Radio
John Q president cb
If by calibration, you are referring to the check if your antenna is tuned, below information may be of help.
S/RF/SWR/CAL SWITCH. When in the S/RF position, the meter swings
proportionally to the strength of the received signal. When transmitting,
the meter indicates relative RF output power.
When in the "CAL" position, the SWR meter can be calibrated by adjusting
the "SWR CAL" control to the "CAL" mark on the meter face.
When in the "SWR" position, the standing wave ratio is measured.
SWR METER. Measures standing wave ratio of the antenna system.
Used to properly adjust the length of the antenna and to monitor the
quality of the coaxial cable and all RF electrical connections. If there is any
degradation whatsoever in any of the foregoing, due to humidity, salt
spray, vibration or corrosion, the SWR meter reading will rise, thereby
indicating that a problem exists.
To calibrate, switch to the "CAL" position, transmit by pressing the mike
switch, and adjust the SWR control to the "CAL" mark on the meter; then
switch to "SWR" position for the SWR measurement.
If however you are referring to the internal calibration or tuning of the transmit and receive sections, you would need several instruments/equipment such as RF generator (0-30Mhz with 1Khx modulation), Spectrum Analyzer, Modulation Scope, Dummy Loaded Wattmeter, Frequency Meter and some others. These of course are not readily available to the average user.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 12, 2008 | Cobra 29 LTD CB Radio
Cobra 29 ANT light
I believe it to be feedback but be aware of your Standing wave ratio because using a linear amp radiates signal to the point that it could cause that light to come on. There is a problem if the radiated signal is feeding back into the amp a a higher level that it can withstand over time.
Sep 08, 2007 | Cobra 29 LTD CB Radio
Galaxy Radios DX-959 40-Channels Base CB Radio Logo
332 people viewed this question
Top Galaxy Radios Radio Communications Experts
Steve
Steve
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
