Question about RTO Freespirit 817 Treadmill Walking Belt
I get the worse electrical shocks from my treadmill...the other day I got a really bad one and the treadmill shut off and when I started it up again all the numbers on the console are cut in half??
  • 999 Answers
Better check the harness where it runs up the supports. Some of these had the harness mis-routed and screws were able to damage the wires and create shorts.
Posted on Apr 28, 2010
My treadmill stops running after 3 minutes. It shuts down and I have to reset and start over again. After another 3 minutes, it shuts off again.
Sounds like a motor or electrical system cooling problem. Could be dirt or blocked motor. Try Computer air blast can and or a vacuum to clean out motor and electronics.
Mar 04, 2015 | Proform Crosswalk Advanced Cr 525i 525x...
5.9 Lt 2001 dodge durango has 20 percent compression on cylinder 7, ran really luggish and engine shakes alot, was told could drive on 7 out of 8 cylinders after a couple weeks of driving it, i started it...
it sounds to me that #7 has a valve train problem, wiped cam to broken rocker arm,bent pushrod,broken spring,bent valve or burnt bad! Or it has broken ring on piston. shouldnt have kept driving,very bad idea. pull valve cover to check valve train. I would start there before going deeper into motor.
Mar 23, 2013 | 2001 Dodge Durango
Life Fitness 9100HR Treadmill won't start
Typically a non start up of any electrical Exercise equipment raises alot of red flags If this treadmill will not start Check the internal fuse MAKE SURE ITS NOT PLUGGED IN!!!! UNPLUG IT FROM THE WALL
2 If there is NO Fuse and you just bought it new Return it for an exchange.
3 Check your wall outlet for less then 5 Bucks you can buy a wall outlet tester that tells you if your Outlet is good Or Bad.4 DO NOT Attempt to service this item on your own the way they make treadmills you have to have a qualified service tech come out and fix it because the risk of serious shock or death is emminent.
May 04, 2012 | Life Fitness Exercise & Fitness
I have a bodyguard t260 treadmill and when I run on it there is a great deal of static electricity that shocks me when I touch the treadmill handles
The shock is a build up of static electricity on your body called Electrostatic Discharge (ESD). Friction between the walking board and belt can generate static electricity.
If experienced, the shock is not harmful or dangerous.
Nov 11, 2011 | Exercise & Fitness
Treadmill won't turn on, I get a slight shock when I click the on/off switch.
Dear Sir:
Thank you by you request, I will help you inmediately.
Please do this with very Carefully!!
The shock is a build upof static electricity on your body called Electrostatic Discharge (ESD).Friction between the walking board and belt can generate static electricity.
If experienced, the shock is not harmful ordangerous.
Thank you in advance, sincerely. God bless you.
IF YOU NEED FURTHER ASSISTANCE, PLEASE CONTACT ME
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Sep 27, 2011 | Precor 9.21 Treadmill
Treadmill shuts off when I start walking/running.
Sounds to me like you have a bad Drive Motor. Doesn't hold a load and has to cool off before it restarts.
May 10, 2010 | Exercise & Fitness
Treadmill Won't Start
you need a new lower board from the mfg. you can replace this item you self if the make the part still call them.
Apr 18, 2009 | New Balance 1400 Treadmill
Electrical
after another check,determined it was bad alternator
Jul 08, 2008 | 1998 Ford Windstar
RTO Freespirit 817 Treadmill Walking Belt Logo
195 people viewed this question
Top RTO Exercise & Fitness Experts
Jim London
Jim London
Howard
Howard
Jax Planet
Jax Planet
Are you a RTO Exercise and Fitnes Expert? Answer questions, earn points and help others
