Question about Hamilton Beach 40616 Coffee Maker
Hamilton Beach 40616 Perculator
Perculator will sound like it is making coffee. When it is complete, there is only hot water coming out. The grounds in he stainless steel filter don't even get wet. Somehow, the water is not making it up the tube to the grounds, but it sounds like the water is perking. We are doing nothing different, it has happened twice now.
  • 515 Answers
Try to replace the delivery (ascending) pipe in the middle.
Hope this can help you
Posted on Jul 17, 2008
It will not make coffee in either the Keurig pods or regular ground coffee. It says PURGE, or NEEDLE after I clean it and use paper clip to remove grounds. What else can I do?
Customer Reviews: Hamilton Beach 49995 FlexBrew Single ...
www.amazon.com/Hamilton-Beach...FlexBrew.../B00...
Amazon.com, Inc.All in all, the Hamilton Beach FlexBrew Single-Serve Coffeemaker is an ... exhibit the same exact problems using the K-Cups recommended by Hamilton Beach.
Hamilton Beach FlexBrew Troubleshooting Common ...
? 3:39
https://www.youtube.com/watch?v=yA2dlGKUBKM
Sep 7, 2015 - Uploaded by Ronald Kretz
Hamilton Beach FlexBrew Troubleshooting Common Problemmust see if you ... Hamilton Beach Single ...
Customer Reviews: Hamilton Beach FlexBrew Single-Serve ...
https://www.walmart.com/reviews/product/21130276
WalmartProblem the model I purchased was the only one they made that uses K Cup. ... MyHamilton Beach FlexBrew Single-Serve Coffeemaker was truly a wonderful ...
FlexBrew® Single-Serve Coffee Maker (49995R) - Hamilton ...
https://www.hamiltonbeach.com/all-coffee-maker...
Hamilton Beach BrandsThe FlexBrew® Single-Serve Coffeemaker allows the flexibility of brewing freshly ...Not sure how much coffee grinds to add when brewing your next cup? ... and thenrunning 2-3 cycles of cold tap water before making the next round of coffee. ... 2016Hamilton Beach Brands, Inc. Trademarks by Hamilton Beach Brands, Inc.
Hamilton Beach FlexBrew 49995 - Consumer Reports Online
Jan 05, 2016 | Hamilton Beach 49995 FlexBrew Single Serve...
Coffee pot not releasing water
Maybe you've already figured it out, or just tossed the thing by now...lol... I found your question when trying to research the exact same problem. I ended up finding the answer in the Hamilton Beach Use and Care Guide for the appliance:
http://useandcares.hamiltonbeach.com/files/840225000.pdf
Right at the top of page 10, it says that the 'Piercing Nozzle', right above where the K-cup sits is clogged, and needs to be cleared out. Once this gets clogged, it won't work, even if you are using regular ground coffee.. the hot water simply won't flow.
Sure enough, it fixed it for me! Good luck.
Apr 20, 2014 | Hamilton Beach 49995 FlexBrew Single Serve...
Hamilton Beach Model 49756T does not filter water from resevoir pump into filter.
at only 2 months chances of it being calcified are slim, the fact that the coffee is dry is the catch. some place when you close the lid there may be a little trip switch, a tiny tab like the one on your washer causes your washer to start when you close lid, same concept but way small. THat's not it? There are some coffee pots that the position you place the handle will create a varence in the lids ability to properly come in contact with the filter cup, a pressure censor so to speak. Then i would guess there is a blockage in the transfer line, and last a pot that just killed itself after 2 months. (it's still under warranty :))
Mar 28, 2012 | Coffee Makers & Espresso Machines
Hamilton Beach brew station dispenses very slowly. I have cleaned it twice but still takes a long time to fill a cup!
Try to have a look whether there is a limestone layer built up on the element.
That will slow it down, while most probblems will stop it alltogether.
Remove by leaving white vinegar in it overnight.
Sep 04, 2011 | Hamilton Beach BrewStation Deluxe 47474...
I have had my hamilton beach brew station for a year. The past 2 weeks, the water put in the bottom reservoir does not empty completely into the coffee reservoir. It leaves about 8 oz in the bottom water...
On your machine there is maybe inside water reservoir a hose or tube that goes down to bottom, or suppose to go down to bottom, to **** up all water. Look inside and see if hose is going all the way to bottom, maybe it got hung up or crooked. Please let me know, glad to help, thanks mike ( mr bean man )
Jun 08, 2011 | Hamilton Beach BrewStation 47214 Coffee...
The cofee maker my dad gave me wont make any coffee
You may need to run a pot of white vinegar and water (50/50) through several times to flush out the line and heater. Make sure that the plate under the pot is getting very hot or it won't pump water from the reservoir. Hope this helps!
Feb 10, 2010 | Hamilton Beach Stay or Go 45234 Coffee...
No water is dripping
the heating element is not strong enough anymore ,or the sensor that tells how hot it is and turns it on and off is failing
Oct 28, 2008 | Hamilton Beach 49444
Hamilton Beach Perculator
Try these guys first for an original spare; http://www.hamiltonbeach.com/cgi-bin/main/co_disp/displ/pgname/replacements/strfnbr/20 If you get no luck from them then i would hunt around for a similar knob on an old pan lid or similar, or get any machine shop to make you one up - if you have any trouble actually fitting it, please ask again Hope this helps :)
Apr 11, 2007 | Hamilton Beach 40616 Coffee Maker
Hamilton Beach 40616 Coffee Maker Logo
165 people viewed this question
Top Hamilton Beach Coffee Makers & Espresso Machines Experts
Jerry Greenberg
Jerry Greenberg
jason
Are you a Hamilton Beach Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
