Question about Cuisinart DCC-1200 Coffee Maker
Flashing "clean" light on my Cuisinart coffee maker--can't find my manual, sorry. Also, LOTS of steam, less coffee output than expected.
We had this problem. I can't remember all the details but we followed the manual's directions and ultimately the flashing light would come on again. We went through the same procedure a number of time over the day, and each time the self-clean light would go off, but then when we tried to make coffee it would do exactly as you described. Finally we gave up and uplugged it, ready to throw it in the garbage. But then, I was going to call Cuisinart's number (go to their web-site) and I thought I'd try it again so I could describe exactly what happened to the customer service rep. Guess what? It worked! I think what may have happened is, by unplugging it, we re-booted its computer. So try unplugging it and replugging it in.
Posted on Jul 09, 2010
  • 268 Answers
YOou can download the manual from the Cuisinart website:
http://www.cuisinart.com/products/coffee_bar/dcc-1200.html
Posted on Apr 27, 2010
For the cleaning light to go out: I've had this problem with my 1150. The manual said to go 1/3 vinegar and 2/3 of cold water. I took this to mean 2 cups of cold water and 1 cup of vinegar. Make sure that you are using WHITE DISTILLED VINEGAR!! Any other vinegar won't work for this! Press your clean button and then push brew.... and off you go. When this is finished, you won't have a cleaning light flashing anymore.
As for the extra steaming and less coffee output, check your spring loaded filter holder. 9 times out of 10, coffee grounds can get trapped into this, especially if you are using a finer ground of coffee. Run your water in your faucet and hold your filter holder over the sink. It doesn't have to be hot, but make sure it's at least warm. Place your finger over the springy area that would be hit with a carafe and let the water run through. You may also check to see if you can slide around the bottom of the filter holder by the springy area, which will help sweep grounds from the area, which ALSO can be a problem of why the steam is present and not allowing coffee to come through. Once this is done, then you should be set to go. If you are using gold filters, mesh filters, or using too much coffee, this can cause the coffee to back up into the filter holder. Switch to paper for a while, and don't go cheaply with the filters.... get the Melitta ones!
Posted on Aug 22, 2012
  • rushfan3 Oct 29, 2013
    Oh one other thing. If you DO have the water filter attachment to the machine, remove the filter. Cleaning with the filter is not ideal.
    Also, when cleaning your machine and having a water filter, replace the water filter.
We've had a Cuisinart DCC-2000 coffee maker for less than a year: 1) it stops brewing about halfway through the brewing cycle (with plenty of water still in the reservoir, and 2) the "Clean" light
This problem is caused by a clogged water filter in the unit.
Unplug the coffee maker.
Open the top panel where you normally pour in the water and set the coffee filter.
Gently pull up on the tap that sticks up in the back left corner of the open top. This will free a long plastic part that has a compartment at the bottom that contains a filter filled with charcoal.
Unsnap the small compartment that holds the filter and clean it gently under running water with light brushing.
If there is a lot of coffee build-up, the water chamber where you normally pour in fresh water needs to be cleaned out. Pour in a cup of water and invert the unit over a large sink pouring out the water through the opening you normally use to fill the unit.
Repeat this until you remove the coffee grounds.
Let the unit dry fully before plugging in to run again.
Sep 30, 2012 | Cuisinart DCC-1200 Coffee Maker
Got this coffee maker from a buddy. had been sitting for a while,ran lots of water and 2 cycles of vineger and water though without the filter to clean out debris in resevoir. still getting quit a bit in...
You may find this a useful site in the future:
http://www.cuisinart.ca/cuisinart_product.php?item_id=63&product_id=58&cat_id=2
Your Instruction Booklet:
http://www.cuisinart.ca/pdf/ibs/en/DCC-1200C_en.pdf
It is likely that calcified deposits are gradually breaking away as you now use the coffee maker. Is your Self Clean light flashing? Instructions on decalcification and cleaningh begin on page 5 of your booklet.
To clean, fill the water reservoir to capacity with a mixture of 1/3 white vinegar and 2/3 water. For your problem, let the vinegar solution sit in the reservoir for 30 minutes to an hour before beginning the cleaning cycle.
Press the Self Clean button. When the self clean light glows, turn the coffeemaker on by pressing the ON button. The self clean light will shine steadily. The coffeemaker is now in Self Clean mode. One cycle should be sufficient to adequately clean the coffeemaker. When the cycle is completed and the five beeps sound, the coffeemaker will shut off. Turn the coffeemaker ON to see if the Self Clean light continues to flash. If it does, turn it to OFF and then repeat the cleaning procedure with a fresh solution of vinegar and water.
If the Self Clean light no longer flashes, turn the coffeemaker to OFF and then run one cycle of fresh cold water through the unit before using the unit again to brew coffee.
If you continue to see debris, unfortnately you will have to repeat until clear.
Feb 16, 2011 | Cuisinart DCC-1200 Coffee Maker
Cleaned the Cuisinart with vinegar yesterday, rinsed through with water. Now it makes a lot of noise and takes a VERY LONG TIME to perk, and the result is too strong and doesn't make the expected number...
I had the same problem. We had stopped using the little charcoal filter and as a result got coffee into the intake. It was partially blocked. The result was lots of steam, but no water coming out the tube. After repeated power rinsing and a little compressed air down the out flow tube it is all working again.
Feb 11, 2010 | Cuisinart CBC-00FR 12-Cup Coffee Maker
The cleaning light keeps flashing and will not turn off. I have lost the book. What do I do?
Unplug the coffeemaker for LONGER THAN 20 minutes, and the self-clean light will go off. Also, the book is available in digital form from Cuisinart's website.
Apr 14, 2009 | Cuisinart DCC-1200 Coffee Maker
Self Clean Button
Unplug the coffeemaker for 1 hour or longer - it should reset the coffee maker and get rid of that self-clean light.
-Tha Mp3 doctor
Jan 24, 2009 | Cuisinart Coffeemakers
Program light and 12:00 are flashing, no buttons work
Press program set once, then switch to clock mode to set time.
Sep 27, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Keeps flashing 12:00
I just kept plugging and unplugging the coffee pot. Eventually, the clock stopped blinking, the buttons worked, and all was well.
Jul 19, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Self cleaning coffee maker
Unplug the coffeemaker for one full hour, and the self-cleaning light will go off.
Mar 01, 2008 | Cuisinart DCC-1200 Coffee Maker
Self clean feature on coffee pot
here is the link to the manual http://www.cuisinart.com/share/man/25_man.pdf page 8 - looks like you have a calcium buildup - descale overnight using vinegar/water 50% if the self clean feature is not able to deal with the problem. hope this helps :)
Mar 10, 2007 | Cuisinart DCC-1200 Coffee Maker
Cuisinart DCC-1200 Coffee Maker Logo
1,764 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
