Question about Car Audio & Video
Door speakers i have a 2007 tahoe and im running 2 l7 15" subs with a fosgate td1001 on each i need some very very powerful door speakers for my midrange any suggestion!
    Scholar:
  • 178 Answers
Www.crutchfield.com All car audio accessories you need are right there, enjoy
Posted on Mar 24, 2008
What kind of amp can adequately power P112 S8 subs
you shouldnt run it at 8 ohm it shows what ohms it can handle . to run it at 1 ohm you would need 2 subs to do this. and no i wouldnt run an 8 ohm sub on the amp.
Aug 23, 2012 | Rockford Fosgate Punch Stage P112 S8 Car...
Can 2 ohm subs be used with a 4 ohm 2 channel amp?
You can but you will have to wire your subs in parallel....to a 4 ohm load then bridge it to your amplifier.....look up parallel wiring on google....Im pretty sure you will have to run jumper wires from your positive and negative of one sub to the positive and negative of the other sub.....then run the two wires to your amp bridged.....to make a 4ohm load.....let me know if that helps you and gd luck!!!!
Mar 28, 2012 | Rockford Fosgate Car Audio & Video
Wiring for 2 subs for max performance
This amp is rated at 500 watts into a 4 ohm load bridged mono or 250 watts x 2 into 2 ohm load stereo. Do not go below that impedance in either case. The amp was meant to dissipate a certain amount of power, driving it to hard will lead to damage. Your speakers look like they are dual voice coils @ 4 ohms each. To get the max power while still saving your subs would be to parallel the voice coils on each woofer then run them in stereo with your amp. Stereo 2 ohm is 250 watts per speaker.
Dec 14, 2009 | Rockford Fosgate Punch 501S Car Audio...
What is the very best way to wire 3 sets of speaks and 2 subs through a 4 ch. amp and a 2 Ch. amp.?Thank you, Paul
Ummmm Im gonna give this a try-If it were me i would run the 4 channel ground pounder on the doors and rear panels -the front 2 channels run the component set exclusively at 2 ohms per channell and run the 8 inch 3 ways in parallel with the rear deck speakers for a combined load of 2 ohms per channel on the rear channells-naturally the 8 inchers and the 6.5's are going to be able to handle a little bit more bottom end than the component set so you can feed a little more midbass to those rear channels- I dont know the resistance of the coils on your subs or the model of the MA amp you are using but if you can throw 600 or 700 on your subs that should be sweet enough- hope its not a waste of your time or maybe you already tried it set up that way-good luck though
May 27, 2009 | Alphasonik (PMA640A) Car Audio Amplifier
Sub not very loud
Hey buddy your question caught my eye because i have a buddy that was wondering the same thing not so long ago-and im no expert but i have had my run with rockford fosgate amps and a few sonys as well. So first of all if you know fosgates well you know that they ALL put out more power than what they are rated at -example your 400 watt fosgate amp is rated at 400 watts but if you got it new than it came with a birth sheet that shows you how much its really putting out-im just throwing a number out there but its probably closer to 480 actual watts. Now you get the sony amp and it says its a 1000 watts but its all bs -it actually is rated at 400 continous usable watts- so the reason that its not any louder than the fosgate is because you bought an amp with almost identical power output. The other part of the problem is that you are limited by your speaker-you could buy an amp that actually puts out 1,200 watts and plug it right in to your sub and its going to probably blow within 30 seconds or quite possibly catch fire. The numbers when dealing with car audio that you have to pay attention to are the R.M.S. power ratings - never look at the peak or max wattage because its all bs and yea its all bs- As i was saying you are going to be limited by your sub because as it stands right now you cant put much more power on that thing without blowing or roasting the coil. All subs have a limiting factor as to how much air they can move- this is called X-MAX and that tells you how far the speaker cone actually moves from start to peak excursion- once you have supplied the speaker with enough power to reach its x-max then thats it -no matter how much power you put on it it wont move any more air than that-and you will create heat and distortion if you try and thats just begging for a blown sub. If you want it louder than upgrade your sub to something that will move some serious air like a jl audio w7 or orion hcca subs -those subs can get it on like dammmmm or easier than that get another sub and then your moving twice as much air at a fourth of the price of buying a balls out jl w7-anyhow good luck with that
Apr 06, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
About 6 months ago i had installed the mtx thunder 6500d amp to run my 2 rockford fosgate power T1 12inch subs and every thing was great untill recently it stop puting out sound it still powers up and...
good morning and welcome to fixya. not a bad setup you have here at all, you ned to start by checking the speaker wires inside the box to the connector inside and then the wires from connector to amp on outside. if everything looks fine there, then you need to check the amp for power out of the rca plugs to make sure the channel is not dead. if you are looking for a new amp you can try several different ones from fosgates new line up to soundstream's. im running 4 polk momo 12's on the tarantula amp and love it. they are great amps. hifonics also has a new line up pretty cool stuff, heard really good things about there stuff to. good luck and let me know so i can help you out.
Mar 08, 2009 | MTX Thunder 6500D Car Audio Amplifier
Door speakers
You will not be able to get much fill from door speakers. you could go splits in the doors, but they are build for MID and HIGH range. My advice to you is to POD yours doors out, so you get a better depth for your speakers. The best speaker I know for such an application is a Kenwood 8", 4 way. They are fairly deep, so you will need to pod. But they have wicked midrange.
Mar 23, 2008 | Car Audio & Video
Wiring
The two seperate wire terminals on the sub are for dual voice coils which means. If You hook up the first terminal to the second terminal then run speaker wire from the second terminal to the amp.It should then increase the subs frequency response and sound better which also means it will be able to handle more bass. As to just having one voice coil hooked up. The two terminals is pretty much the bridge for the sub.
Dec 21, 2007 | Car Audio & Video
Car Audio & Video Logo
60 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
