Not Spinning or Draining !
I have recently purchased a 2nd hand Indesit WIDL102 Washer/Dryer - its less than 6 months old,it runs through the wash cycle fine,but when it comes to rinse or drain it just sits there humming as if something is jammed,but the drum turns freely in the was cycle and the water pumps in fine.I have also tried starting it up just in "Drain" mode and it still sits there humming,any help is greatfully appreciated thanks !
  • 32 Answers
Hey there
well from what I can understand here you need to check first 2 things
1) Check that the hose that is connected to the machine is empty and that there's nothing blocking the water.
2) another possiblity is that your Pump isn't working.
saince i don't knwo the model I can't tell what kind of pump you have, if you have direct pump is should be abouve the motor, it' pretty easy to inspect it and look at it, it may be blocked from all kind of junk (coins.....) another option is that the pump blades are worn out so it's not pumping ( i don't think its your case since your washer is prettry new)
Hope this helps
Bono
Posted on Mar 24, 2008
Washing machine is washing but not draining or spinning
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 26, 2011 | Indesit W 123 Front Load Washer
Indesit WDL 126 dryer - at end of cycle not draining or spining
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Feb 11, 2011 | Indesit WA 125 Front Load Washer
WIDL102 indesit washer dryer not working properly
check heater element/ should read about 32ohmns on multimeter if not reading replace,if ok replace stat
Apr 03, 2010 | Indesit W 123 Front Load Washer
Ive got a Indesit WIDL102 washer dryer and it will wash but will not dry any longer. It goes through the cycle but the clothes come out wet. Any suggestions???
This problem is normally caused by either the thermostats not working properly or the heating element is the problem.
Both are normally located in the air tube of the dryer down stream of the blower.
Sep 25, 2009 | Dryers
Indesit washing machine not spinning - fault code timer and dor lock light flashing
my indesit washer/dryer wd12x programme dial goes all the way when it reaches spinning
May 30, 2009 | Indesit W 123 Front Load Washer
Dryer geting to hot
When that happens it is usually because of a broken thermostat or a devective vent system, see : It overheats.
Nov 20, 2008 | Indesit W 123 Front Load Washer
Indesit WIDL 102
almost certainly a new module and eprom. these modules have given a lot of problems.
not really worth doing
Jun 25, 2008 | Indesit W 123 Front Load Washer
My Indeset widl102 washer dryer
sounds like a faulty water valve if not pcb or pressure switch sorry cannot be more precise but thats indesit for you regards jason
Jun 12, 2008 | Indesit W 123 Front Load Washer
Washing Machines Logo
177 people viewed this question
Top Washing Machines Experts
