Question about GE Spacemaker JVM1640SJ Microwave Oven
Sounds sluggish and then automatically shuts off
GE Spacemaker 2.0, Model # JVM2050BH03, less than 4 years old. Only repair thusfar is I had to replace a burned out turntable motor. When we turn on the microwave, it sounds "sluggish" and then automatically shuts down completely as if it has lost it's power source. We unplug and then re-plug and microwave turns back on but still remains "sluggish". Same problem occurs again.
  • GeorgePH May 16, 2010
    Have a GE Spacemaker 2.0 microwave, M#JVM2050BH03. Microwave sounds "sluggish" when initially turned on and then shuts down completely (loses all power) after about 3 minutes into the cooking cycle (as if it's overheating). Then about 5 minutes later, power is automatically restored. Have changed the charcoal and cleaned other filters. Recently changed out turntable motor (but it is working).
    President:
  • 2,468 Answers
If the lights dim in the oven when it sounds sluggish,your high voltage capacitor could be beginning to short out and drawing too much current,its under the cover,be very careful and discharge it before touching it in case,because it can store +2100 volts A.C.,then also check the front to back resistance of the high voltage diode as these can leak and cause similar problems,if these are both o.k. then suspect the magnetron tube for drawing too much current,if it shuts down unplug it and again discharge the cap then put your hand near the side of the magnetron and see if its hot this may draw too much current and make the unit run slow and sluggish,then have an ampere draw run on it and see how much its drawing per the specs of the unit
Posted on May 16, 2010
  • danny Hendrickson May 16, 2010
    also while at it there could be a weak thermistor on the magnetron tube near the top and on the side of the mag body,it has 2 wires connected to it and if the mag gets too warm this component opens up to shut off power to the unit to prevent overheating,sometimes they get weak from heat/age and need replaced
    President:
  • 1,297 Answers
How does the turntable turn during this time
I've seen a lot of premature failure of replacement parts
when was the turntable replaced?
Ge spacemaker microwave JVM1650 won't heat
sounds like possible magnatron or diode thats the case its not worth repairing. but if your handy then google model nuber and get the part be extreamly careful because of the power capacitor holds extream volts. turn off and allow to sit 15min before working on
Oct 23, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
I have GE Profile microwave model PVM1870SM1SS and last week while running, suddently it shut off. There is no power, display buttons and stopped running. Please advise.
From the description a major part has failed, the magnetron is suspect because it suddenly shut down in cycle, if the unit is less than 7 years old it probably has a inverter board and tends to fail, also there is the possibility the keypad control board has stopped working. The microwave in my opinion is worth getting checked out and repaired, but it will be expensive.
Apr 03, 2012 | GE Profile Spacemaker 1.8 Cu. Ft....
We have a GE JVM1540 space saver microwave. It is less than a year old. Will not heat and immediately starts smelling like burning plastic. Any ideas as to what is causing that?
CHECK THE MICROWAVE MANUAL LOOK FOR FACTORY WARRANTY ,MUST BE A BAD COMPONENT ,IF YOU MICROWAVE IS UNDER 1 YEAR WARRANTY THE FACTORY WILL REPAIR IT AT NOT COST TO YOU..CONTACT GE FACTORY.
Feb 18, 2011 | GE Spacemaker JVM1540 Microwave Oven
Microwave is ge spacemaker model # jvm1650sho5. when microwave is turned on about 4 seconds later it starts making a noise and has a burnt smell. The smell comes from the vent on upper left side and the...
this sounds like the magentron may be going. have you had any issues with it not heating? check your warranty book, some mags have a 3-5 year warranty, otherwise it's probably not worth repairing.
Nov 12, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave on but does not heat
If it is less than 5 years old, it is probably worth it to fix it. Sounds like a magnetron. The part should be covered by GE
Mar 12, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
JNM1541 GE Space Maker
If it's less than one year old, it should be fully covered under warranty.
I'd suggest contacting the manufacturer to get it fixed free or better still, if you've had it less than 30 days, I'd have the dealer replace it.
GE Customer Service is here.
It sounds like the door or door switch mounts are misaligned. It may have been damaged in shipping.
Jan 07, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Slow heating; sluggish fan; low interior light
The main power supply may have a fault. Also, the HV supply may be weak at the same time.
Jerry G.
Apr 01, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1870 Runs, but won't heat up
use a high voltage probe to check high voltage, if present replace the magnatron if no HV replace the high voltage board this is the board that has the heavy wires to the magnatron
Feb 06, 2008 | Microwave Ovens
GE spacemaker microwave 2 years old
unplug the microwave first then pull the cover off the top front of the microwave with 2 philipshead screws, the unbolt the control panel with the one screw. let it hang down the you should be able to see tha fan.
Dec 27, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
2 1/4 year old GE Spacemaker XL 1850 Microwave doesn't heat
Check this website:
http://www.partselect.com/microwave+no-heat+repair.htm
It sounds like it is either the power diode, the high voltage capacitor or the magnetron. If it is the magnetron, it may not be worth fixing as these can cost well over $100.
Do you hear a buzzing sound?
Dec 13, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
