Question about Garden
I purchased a 034av chainsaw w/o manual question: under the air cleaner cover theres what looks like a cooling air adjustment its located on the right side looking from behind whats it for and is there an reason to adjust it . Thank you Rich.
    President:
  • 2,220 Answers
Morning Rich;
Your OM is not listed but there is is a link where you can request one, please do.
Stihl Product Instruction Manuals
http://www.stihlusa.com/information/info_product2.html
It is difficult without seeing exactly what you are inquiring about but I suspect it is part of a winterizing modification. I have never needed to modify any of my saws but it is moderate where I use them. A stop in your local Stihl dealer will answer both questions with certainty.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on Apr 27, 2010
Could some help me with factory carb settings on this saw
Adjustment and Tuning of a Chainsaw Carburetor ' Chainsawr
store.chainsawr.com/.../tuning.../1126042-adjustment-and-tuning-of-a-c...
Carburetor Adjustment for Chainsaws Carburetor adjustment is critical on chain saws ... These saws have what is called a "fixed jet" which is set from the factory.
Stihl Chainsaw Carburetor Adjustment - Tune-up Settings
tekindoor.com > MISC
Stihl chainsaw's have three carburetor adjustment screws (LA) Idle Speed screw - This ... When the engine is tested at the factory the carburetor is set to obtain a ...
How to Adjust the Air and Fuel on a Stihl Chainsaw ' Home ...
homeguides.sfgate.com > ... > Adjustable Mortgage Rates
The fuel/air mixture in any gasoline-powered engine is regulated by the carburetor, and the carburetor in a Stihl chainsaw is factory-adjusted to provide the best performance.... You'll find three adjustment screws for the carburetor, usually located under the air filter cover.
Factory carb setting on Craftsman 2.0 or Poulan Micro ' Firewood
Dec 04, 2015 | Garden
Mcculloch parts manual
you can purchase the magneto at most any parts shop unless its an obsolete saw. the magneto is located on crank cooling fins under the pull start
Jan 07, 2014 | Garden
Looking for location of cooling fan relays on 1999 chevy cavalier
the relay is under the hood behind the air cleaner box, their is a tab in the front and back of cover push them away from the cover and pull straight up, If you are standing at the drivers tire it should be the 3rd. relay in from the right and they cost about $9.00. hope this helps
Jul 14, 2012 | 1999 Chevrolet Cavalier
I have a B and S Quantum XTE 50 on my mower and have lost the manual. I would like to know where the air cleaner is so that I can clean it. Thanks Christine
Hi, front right hand side of the motor under a rectangle plastic cover. One screw holds the top of the cover in place while the bottom locates with plastic lugs. Hope this helps, regards Phil.
Jul 25, 2011 | Garden
It will not run unless it is choked
sounds like it is running lean, increase your fuel air ratio and up the idle speed, both these adjustments can be made by jet screws wich are located on the carbuertor. You will need to consult your manual for the location of these. Also clean or replace your air cleaner and use fresh fuel with the recommonded 2-stroke mix. If you have no luck with the adjustments, increase your fuel/oil mix up richer.
Jan 21, 2011 | Poulan Garden
I have a 2008 Passat. I purchased an air filter which is located under the engine top cover. How do i remove this cover without breaking it.
I looked up your car on Autzone.com's site and my online resource but no data on how to take the air filter out was there.
Maybe, you'll have to purchase the Chilton or Haynes repair manual or go to repairpath.com or alldata.com to get the information you require on your computer.
Oct 12, 2010 | 2008 Volkswagen Passat Sedan
My pcn 4545 chainsaw has started to over rev upon starting. The idle adjusting screw is backed off all the way and not the cause of the problem. Can you please tell me how can this be corrected and...
Remove the air cleaner and watch the throttle arm on the carburetor while operating the throttle trigger--suspect that the trigger assembly has acquired sawdust and dirt sufficient to limit proper travel of the trigger mechanism. Careful notes as you dis-assemble the trigger will help get it back together properly. There is little except proper maintenance to prevent debris accumulation in the trigger mechanism. Note: air leakage behind the carburetor can also cause high idle speeds--make sure the carburetor is fastened securely and that there are no flaws in the gaskets and heat insulator located behind the carburetor. Hope this helps!
Jul 13, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
Chainsaw runs, but dies when given gas.
adjust the gas and air on the two little screws on the carborator
Dec 26, 2008 | Poulan Pro Chain Saw 46cc 20"
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
