Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Color malfunction my printer did not function well. yellow color missing
  • 4,041 Answers
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Apr 27, 2010
HP Color LaserJet 2550L. Missing colors
The main circuit board is faulty and needs to be replaced.
Feb 27, 2014 | HP LaserJet 2550L Printer
Print test page mfc210c
good day...If you done for cleaning the printer head, the the nozzle check have some missing squares in between, either black or all color, will theirs a problem on the print head...the solution is need to replace the printer head
Nov 28, 2017 | Brother MFC 210C All-In-One InkJet Printer
The print is faded . ther are three color bar missing on the test page ( yellow, black , and black).
Hi
Go into Maintenance in the Kodak Printer Management Program and try the Nozzle Check and Head Cleaning functions until the Test page prints clearly.
Head Cleaning might be necessary after every cartridge change.
I hope this helps.
Aug 26, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Brother 490cw no red and no yellow print after a few time cleanning still not working blue and black work fine
You need to have the print head replaced. Brother is covering the cost to repair this problem if you call 1-877-276-8437 and tell them you are missing 2 colors on print outs.
Jun 09, 2011 | Brother MFC 490cw Color Inkjet...
The pink colour is missing every time i clean the
Probably one of the red cartridges is empty or near empty or possibly the yellow - it will miss whatever color is low or empty or substitute the next closest shade using the remaining colors if one is out.
Oct 02, 2009 | Epson Stylus Color 670 InkJet Printer
My printer is not printing. it will run the paper
I see you don't have much knowledge about printers. It always helps to know something about your printer. It seem you have a color printer. Usually a color printer has two cartridges. Black cartridge and color cartridge. The color cartridge usually contains three colors; cyan, yellow and magenta. If the black cartridge is empty, you won't see black text in the printed paper. Print a small photo and see. If it has all the colors, but looks dull (without proper black color), that means only the black cartridge is empty. If it is greenish, the magenta ink is missing. Generally orange colored printouts suggest cyan is missing. Likewise, purple color means the yellow ink is missing. If you installed the printer properly using the CD from the printer manufacturer, you will be notified when the cartridge is empty or close to run out of ink. But if Windows automatically installed your printer, then the system won't give such information. From the information you have supplied, I believe your blck cartridge is empty or missing. Oh, I almost forgot to say, some manufactures sell some printers (for example some Canon Pixma models) with only the color cartridge. Switch on the printer and open the printer cover. The cartridges will move to the middle. You can check whether the black cartridge is missing. Do not hesitate to contact us for further help.
Aug 13, 2009 | HP Office Equipment & Supplies
We have brother 3 in one first said needs ink yellow so we did
It is recommended to change the cartidges together, however if one of the cartridges still has ink in it, you do not have to replace them together. The printer may still print with an empty cartirdge but if you are printing something in color it will print without the missing color causing the document to look funny. Hope this helps.
Nov 29, 2008 | Brother Multi-Function Center MFC-240C...
Changed printer cartridge, color is not right on printed material
Remove the cartridge and blot the printhead on a damp tissue. A working tri-color cartridge would have a stripe of cyan, yellow and magenta on the tissue.
If one or more of these are missing you will not get proper colors from the printer. If your printer has a "prime" function this may recover a missing color. If not you will probably need to get a replacement.
Please provide details of the printer model for further suggestions.
Regards,
Bob Headrick, MS MVP Printing/Imaging
Jun 03, 2008 | Lexmark Office Equipment & Supplies
HP880c missing colors
you need to go to preferences and adjust the new cartridges, aline, clean, etc.
Jan 06, 2008 | Office Equipment & Supplies
HP DeskJet 970Cse won't print yellow
Here is a link to hp's web site. They will troubleshoot your issue. This link is linked to a page talking about HP Inkjet Cartridges and Media - Missing Color, Wrong Color, or Streaks in the Printout. There are several links in this site to go off of and troubleshoot further. Hope this is helpful:) http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpa00224&lc=en&cc=us&dlc=en&product=60097&rule=34749&lang=en Jason
Sep 04, 2007 | HP DeskJet 970cse InkJet Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
