Question about Canon Pixma MP500 All-In-One InkJet Printer
Luz copy piscando e mensagem de erro 6A00
  • 4,041 Answers
Hi there
This answers with a titch more detail.
The 6A00 is a Canon generic code for paper path jam.
Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.
As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move.
Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
And yes I have found all those things in a purge unit.
The offending item needs to be removed or the purge unit needs replacement.
Incidentally, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model.
And it’s always a paper path error or purge unit.
The purge unit, called a spittoon assembly in an HP, Lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Also clean the purge unit out make sure all is clean.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 27, 2010
Sd260
Erro na Impressora Datacard D260L.
Mensagem 118: Problema com o tipo de impress?o.
Feb 20, 2014 | Datacard Group Datacard SD260 - plastic...
ESTÁ DANDO MENSAGEM DE ERRO L1 NA COPIADORA AL-1631
L1 signal means your copier exproser lamp carraige is not home position.Clean all surface and sensor hten solve it
with the best luck
Aug 03, 2010 | Sharp AL 1631 Copier
Error Code 6500
Isto é causado pela informação em seu registro. Refira por favor a seguinte ligação e transfira o cuidado avançado de Windows… que você não será… varredura disappointed com AWC e não tentará sua impressora outra vez. A mensagem indicada é um erro, mim está supor. http://www.iobit.com/advancedwindowscareper.html
Apr 11, 2009 | Canon Pixma MP450 All-In-One InkJet...
I have a Samsung that say Transfer Belt Error
Hi
I have a utility to reset the consumables errors on this printer, but only if the component is past its lifecount. (60k for transfer belt)
Its called CLP-300_Reset_RLCv04.exe or just RLCV-04.exe (if you can find a copy)
If you need a copy, let me know and I'll find some way to get it to you.
I've used it for transfer belt reset and it works.
Dec 19, 2008 | Samsung CLP 300 Laser Printer
Erro de sistema contate o suporte ao cliente xbox (mensagem em multi lingua) E74 ( pisca luz vermelha na parte inferior do lado direito)
E74: AV cable error... There is a problem with the AV cable, try using a different AV cable. If the cable is known to be working then there is a 90% chance it's a scaler chip problem (the "ANA" or "HANA" chip connected directly to the AV cable) in rare cases it is the GPU.
Sorry Only know English but i hope this helps
Dec 19, 2007 | Microsoft Xbox 360 Console
Canon Pixma MP500 All-In-One InkJet Printer Logo
57 people viewed this question
old marine
old marine
