Question about Exercise & Fitness
Treadmill maintence - Exercise & Fitness
  • Ben Winton
    Ben Winton May 11, 2010
    What is your question?
  • Ben Winton
    President:
  • 832 Answers
Here is a typical guide for maintenance their may be a slight variation from different manufacturers all in all the same.
NOTE: To prevent electrical shock, be certain the treadmill is turned off and unplugged from the electrical outlet before performing any cleaning or routine maintenance. TREADBELT LUBRICATION For average use of your treadmill, factory recommends you lubricate under the treadbelt once per year. For heavy use, which is more than 10 hours per week, factory recommendation is lubricating every six months. . LUBRICATION PROCEDURE: 1. Turn off and unplug treadmill. 2. Cut off the end of the tube of lubricant. 3. Holding the tube in one hand, insert the tube underneath the treadbelt halfway between front and back and halfway between right and left. 4. Squeeze the full contents of the tube onto the deck in a circular pattern in the center 1/3 of the deck. 5. Plug in and turn on treadmill, then walk normally on treadmill at 0.5 mph for five minutes. CLEANING DAILY: Perspiration should be wiped from the control console and treadmill surfaces after your workout. CLEANING WEEKLY: You should wipe down your treadmill once a week with a water dampened, soft cloth. Be careful not to get excessive moisture between the edge of the digital display panel and the console, as this might create an electrical hazard or cause the electronics to fail. IMPORTANT: DO NOT CLEAN OR WIPE THE TOP OF THE DECK UNDER THE CENTER OF THE RUNNING BELT. MONTHLY: Clean dust and dirt that might accumulate under and behind your treadmill once a month. Small rubber particles from the soles of walking shoes will accumulate alongside the belt and also behind the unit
Posted on May 15, 2010
Surface needs maintence?
You need to wax board or flip it. It is running dry and causing excess stress on motor
Jul 09, 2014 | Bodyguard Exercise & Fitness
Tip
Why your old truck keeps (or doesnt) running
It cannot be stressed enough, that basic routine maintence is the best way to prolong the life of any car or truck. The sad fact is people overlook some of the most important parts of maintence. First i would say, transmission maintence, ie. ****** flush and filter replacement. Most high mileage problems can be avoided by having this done as per your manufactor suggests. Second is ignition, regular replacement and testing of the ignition system can prevent/repair many problems. Another overlooked aspect is body lube points. There is a zerk for almost anything that is bolted to anything else.
on Aug 17, 2012 | 1991 GMC K1500
Perform maintence light
maybe car needs something.
Feb 16, 2013 | 1999 Jeep Grand Cherokee
The maintence require light is on what is the promblem
the maintence reminder lamp means you are due for oil and filter change.to reset maintence light, turn the ignition switch to the on position engine off.push the reset button on clock control panel for 3 seconds,then turn off ignition switch.then turn back on the ignition switch the maintenance light should be off is so.it has reset.
Apr 15, 2011 | 1996 Acura TL Series
I dont know what the name o it, the one say for when ur caps r off or not on it is beside the maintence button when i start the car it does not go off
If it's to the left of the maintence light and it look like a engine, then it's your check engine light. If you can get a code, i might be able to help you.
Dec 14, 2010 | 2002 Honda Odyssey
The servicd writer suggests throttle control maintence every time I take my 2002 Escalade in for service. The car has 38000 miles on it, does it need that kind of service?
No service required unless the engine is idling to slow and stalling at red lights. This maintence is only requied on a as needed basis. Idle speed should be 550 to 650 rpm.
Sep 20, 2010 | 2002 Cadillac Escalade
Maintence light blinks 10 times what does that
i have found that the handas use a maintenence light as there change oil light. look in your owners manual for a reset. i would reset it and see if it comes back or go have the computer pluged in and have the code if there is one retreaved
Aug 23, 2009 | 2001 Honda Accord
Maintence light
No...light will soon go out...Now, get out there and buy a can of SeaFoam (AutoZone) and add it to the gas tank with instructions.
Good Luck
Jun 14, 2009 | 1992 Honda Accord
Why does the maintence required light flash 5 times when started?
It will; always do that on some vehicles, as long as it doesnt stay on for an extended period of time, i wouldnt worry about it so much.
May 20, 2009 | 2005 Honda Accord
How do i shut off my maintence light without going to dealer
in the cluster press the button hold it put ignition switch on maintenanse light will flash after 10 second will come off hope it FIXYA our problem thank you pierre
Jul 04, 2008 | 2002 Honda Odyssey
Exercise & Fitness Logo
361 people viewed this question
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
