Question about Necvox RE-8169D 8 All-In-One Motorized System Car Video Player
My dvd does not appear to be tuned in properly as the picture 'scrolls' like the old VCR tracking problem. I think the seperate dvd player under the seat should have a remote (not with car when i bought it)Is there a solution to this problem
  • 93 Answers
It sound to me like some of the rca cords have wiggled there selfs loose, If you can locate those and make sure there plugged in tightly. Or even replace them. If they are always getting pulled when the dvd player gets moved around. It should go back to normal.
Posted on Apr 27, 2010
When I press the TV/VCR button on the remote, the picture on the TV becomes fuzzy and we see no signal from the DVD player. The first sign we were having trouble was that we couldn't set the time...
The TV/VCR button is usually not a function of a DVD player itself.
Normally this is a button on VCR remote controls that allow you to switch between whats playing in the VCR or whats coming in from the 'air/cable signal' from the cable or antenna wire on the back.
If this is a VCR/DVD player combo unit it would appear that the TV may be on the wrong channel for proper operation of the VCR functions (ch 3 or 4 are usually the selectable option on the back of the unit).
Make sure your DVD player is plugged into the correct input on the TV(video 1/svideo/or component ) and the TV is tuned to that same input. If the TV is on the correct input then the TV/VCR button shouldn't do anything at all which is normal operation when watching a DVD. If this doesn't clarify please reply with the model # of the unit. I would be happy to help more.
Aug 05, 2009 | Panasonic Televison & Video
VHS output is fuzzy
i think its the tracking adjustments.
May 27, 2009 | Sanyo HV-DX2E DVD Player/VCR
Vhs picture problem
Dear Zepp,
Firstly, video is not a clear as DVD.
Suggestions:
Do the video heads need cleaning?
Is the video tape a bit worn?, Try another video tape.
Do the video tracking controls needs tweaking?
Aug 09, 2008 | Samsung DVD-V4600 DVD Player/VCR
VCR tape playback not good
Check your "tracking" If the tape played fine in the old machine, then tracking is the answer, provided that the new machine records good.
Jun 27, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Can't receive proper dvd/vcr signal
Your Toshiba TV uses the American NTSC standard.
Your DVD/VCR uses the Australian PAL B/G standard.
Unfortunately the two are not compatible as they stand, but there may be an option in the DVD/VDR menu to force the output to NTSC. This varies from make to make.
Another option would be to modify your main DVD player to make it multi-region so it will play ALL of your DVDs. Some models can be modified with a simple handset code, some can be modified with a software update, and others need an internal modification.
Post your make and model, and I can advise you on modification.
May 14, 2008 | Televison & Video
Grundig TV - Tuning DVD & VCR
Hi there!
If the DVD recorder has an RF out then you should be able to tune it on UHF bandwidth. The cable should run from the RF Out on the recorder to RF on the TV. Switch the recorder on, put in a DVD and press play before tuning. Some DVD's require a disc before a Menu appears. Good Luck, Regards, JUS004
Mar 23, 2008 | Grundig GF70-600 TV
Dvd/vcr sylvania combo
did a few google searches and suggestions were made to buy a**ther vcr...** way to fix the vcr heads. thanks anyways!
Mar 08, 2008 | Sylvania (SRDD495) DVD Player/VCR
The insigina combo
i would check the tv TO DVD/VHS COMBO connections OR REPLACE OLD AUDIO VIDEO CABLES especially if the tv plays clearly.
Dec 11, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
Toshiba dvd Video player & vcr SD-V396SU2
Thanks. We have replaced the unit with a JVC but will give the SP/SLP a try just to see.
Anoyed
Nov 29, 2007 | Toshiba SD-V394 DVD Player/VCR
VCR Playback
An "F" connector may be loose. Solutions: Check and hand tighten the cable fittings to the converter, TV set, and VCR. also: Adjust the fine-tuning on the TV set, VCR, or converter box. Good luck
Nov 27, 2005 | Emerson EWD2204 DVD Player/VCR
Necvox RE-8169D 8 All-In-One Motorized System Car Video Player Logo
332 people viewed this question
Top Necvox Car Audio & Video Experts
xxxxxx xxx
Are you a Necvox Car Audio and Video Expert? Answer questions, earn points and help others
