Question about Motorola Mobility RAZR2 v9 Cell Phone
EVERY THING WORKS BUT SCREEN DOES NOT DISPLAY JUST BLANK AFTER GETTING A LITTLE WET
    President:
  • 1,561 Answers
Helllo
It is the flex on your phone screen that is malfunctioning, that is why there is no display.
All you need to do is to change the flex on your phone screen.
You can also go the link below to see how a wet phone can be rescue and to work back.
http://www.wikihow.com/Save-a-Wet-Cell-Phone
But from the problem your phone is having, it is the flex on your phone screen that is bad. just change the flex.
Take care.
Posted on Apr 27, 2010
Testimonial: "EXCELLENT ADVISE THANK YOU"
  • Sulaimon Jimoh Olayemi Apr 27, 2010
    I strongly advice you change the flex on your phone screen, because from all indication, the flex on the screen of your phone is bad that is why it did not display.
    Take care.
MY SONY CAMERA GOT WET ITS NOT CAPTURING PICTURES OR NOT RECORDING VIDEOS. EVERY THING IS WORKING BUT THE SCREEN IS NOT DISPLAYING WHAT DO I DO??????
sir,
if your camera or any electronics appliances happened to enter water or moisture, you must remove the power source(battery)at the immediate, hence the water is a conductor of electric power it will spoil the entire circuits of it. in this case there is very rare possibility to cure. any how please open your camera and take out the LCD display, there may be corrosion on the clipping connectors, try to clean all the connectors, wash the total circuit board with cleaning liquid, re connect all then power on.
Nov 15, 2015 | Sony Cybershot Dsc-w330 14.1 Mp Digital...
When i switch on my Korg PA800, the screen just show's blank. The screen light gets on but just blank blue. What could be the problem?
Hi, Provided your Korg works as normal, besides the display being blank and lit, I may have the answer. It sounds like the contacts connecting the display have somehow become dirty. This could have happened from something getting spilled on the display. To fix is easy enough if you have a little mechanical aptitude. unplug unit/take batteries out,and disassemble unit to gain access to the main circuit board where screen is located, the screen may be held in place with a tin casing either soldered to board or with prong set though the circuit board and twised on the reverse side to hold in place. After removing this there should be a little rubber strip between the screen and circuit board-this is the contact strip that you need to clean with rubbing alcohol. Clean the screen where the contact strip meets the screen. do the same on the circuit board, reassemble and you should be back in business. I hope this was useful, thanks for asking FixYa, and good luck, Prodzilla.
Apr 22, 2011 | Korg Pa800 Synthesizer
Hi! I have a problem with my Nokia 7370 : the screen is blank and nothing is happening. I tried switching it off, then on again, but no luck, I have nothing but a blank screen. Even when I plug the battery...
can u hear any sound like nokia tune which comes when u turn on your mobile? It could be because your display is damaged or not working so please visit nokia showroom and they will help you.
There can be several things which can be reason for blank screen like:
1. Your display is not working
2. Battery of mobile is not working.
3. May your mobile is not charged and charger which you are using is not working. Try charging with some other charger of nokia same pin.
4. It could be software issue. Please update software in your mobile.
60% it could be a display issue.
Jul 21, 2010 | Nokia 7370 Cellular Phone
Display screen has gone blank
You would need to change the screen. Go to a phone repair shop to assist you in changing the screen. It will cost you a little.
Best regards
Jun 06, 2010 | Panasonic GigaRange KX-TG5432 Cordless...
My sony cybershot t90 got little wet
The actual working part of the camera is not affected as the picture is taken properly. But the display part of the camera is only affected.The wetness might have penetrated across the sides of display screen to the inner parts.The display part needs replacement..
May 23, 2010 | Sony For Cybershot Dscwx1 Tx1 T90 T700...
My phone has a blank screen
Are both displays blank, or only one? Is there any backlighting coming on? Any cracks visible? Was there any damage (dropping, etc.) that you remember around the time they went blank?
If you determine that your phone is actually turning on, do the other functions of the phone work? In other words, can you dial a number and hit "Send" and successfully make a call? Can you get sound out of the external speakers by pressing the little "speaker" key at the lower right of the inside keyboard?
If everything seems to work and the ONLY problem is the displays being blank, it is possible to replace the display module. If you have some electronics experience, and you are considering doing it yourself, see this thread for a little more detail about my experience (I did it successfully.) But you'd want to know that the display is the *only* problem before committing to replacing it.
Otherwise, there's not a lot of repair you can do on these things yourself.
Jan 31, 2010 | LG enV3 VX9200 Cell Phone
Display screen is blank when i am taking pictures
A little more info may be required, if its a canon, after you turn it on look for the little Disp button, press that to cycle through the various display modes. If its not a canon please tell us a little more.
Jan 22, 2010 | Cameras
Wet cell phone-blank screen
Well it depends on the type of screen you have in the phone. Some have edges that can split open and lose the fluid that projects the picture so your best bet is to just replace the phones screen, if every thing else works fine
May 31, 2009 | Cell Phones
Lcd flat screen trouble blank screen
Please check your CPU ram I thing problem in ram.
Nov 22, 2017 | Acer TFT screen 17" AL1715MS Flat Panel...
It turns on but a blank white screen only shows
i had the same issue when my phone got slightly wet. try taking everything apart (sim card, battery, back). let them dry out for a little bit then after like a day or two put the phone back together. turn it on it will be a white screen for a little bit but give it like 2 or 3 mins and if should come back. I did this for my phone cuz i really needed the pictures off it and it worked! hopefully if will work for you too. GOOD LUCK!
Jul 16, 2008 | Nokia 6133 Cellular Phone
Motorola Mobility RAZR2 v9 Cell Phone Logo
475 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
