Question about Minn Kota Riptide Sp Saltwater 70 Bow Mount Trolling Motor With Autopilot
Dont know how to reset the shock spring on my riptide bow mount
I hit a stump the other day, and the shock spring and top yoke popped out. That is one stiff and strong spring to compress...Is there a tool or trick to it?
4 Suggested Answers
Editor925
  • 285 Answers
SOURCE: Mounting a sonor/transducer on a MinnKota Riptide ST
Did the unit come with a strap to mount the transducer to a bow mount electric? Most units do... If not there is probably one available for the unit as an aftermarket accessory or accessory from the manufacturer... Regarding the transducer wire, just wrap and rout this up the front of the bow mount motor shaft so when you pull the motor up and secure it, it is not going to get in the way. You could cable tie the cord down near the bottom of the shaft and one up near the top where they wont interfere with the motor bracket when the motor is positioned up on the boat.
Posted on Mar 17, 2009
  • 6 Answers
SOURCE: I have a Minnkota Riptide 80# thrust trollmotor.
1. possibly a broken connection to the motor where the propeller is located. 2. Also could be a bad motor. 3. Look for a fuse location for a possible blown fuse to the motor. 4. motor brushes could be the problem.
Posted on Nov 24, 2009
  • 7 Answers
SOURCE: minn kota riptide 55 bow
Sounds as if the motor has either bearings going bad and/or water has gotten in the housing washed the lubricants out. Motors do wear out eventually. I'm not sure if the brushes are replacible. Have you checked for any constrictions like fishing line? And also the contacts on the controller could have minor corrosion meaning take it apart if possible and clean with steel wool or a dremel.
Posted on Oct 16, 2010
Breakaway bow mount on 5200
check the springs see if one of them popped off happens sometimes
Apr 09, 2013 | Boating
I have a minkk kota riptide salt water bow mount trolling motor. The motor functioned properly last time out. This time the motor failed to come on. one of the batteries was found to be bad and...
Many times on the battery lead, actually the part that tightens to the battery, has a circuit breaker. You will notice a small reset button on each positive lead....of course there are two for a 24v system. Reset each one!
Jan 12, 2011 | Minn Kota Riptide St Saltwater 80 Bow...
Minn kota riptide 55 bow mount with foot control and auto pilot. problem is prop doesn't seem to spin as fast so top speed is about half to two thirds of what it was when new. unit is about 5yrs old.just...
Oct 16, 2010 | Minn Kota Riptide St Saltwater 55 Bow...
How does the pin that holds the yoke come out. I have tried knocking it out with no luck. I also can't seem to find any retainer holding the pin in.
call the 800 number for minn kota on the motor. they will be able to tell you the best way to remove it on that particular motor. they have a very good tech support system at that company.
May 29, 2010 | Minn Kota Riptide St Saltwater 55 Bow...
Riptide RT65 24 volt with auto pilot goes nuts.
your magneto is shorting [ arcing on high needs, openup and replace magneto. call minkota and order a new magneto for your model, unless under warrantee.
Apr 13, 2010 | Minn Kota Riptide Sp Saltwater 70 Bow...
I have a Minnkota Riptide 80# thrust trollmotor.I have power to the head but motor will not run. It is a bow mount with twist grip control.When I mash on the power indicator button ,it lights up showing I...
Nov 23, 2009 | Minn Kota Riptide St Saltwater 80 Bow...
Online manual needed
I have minnkota riptide i had to take the handle off and a little spring & white plastic piece poped out of the handle i just wanted to see where it goes
Jul 11, 2009 | Minn Kota Riptide St Saltwater 80 Bow...
Bow mount 80lb to transom mount
Parts can be purchased from this dealer...There are schematics on the site for review....
http://www.northlandmarine.com/MinnKotaQuickRef.htm
May 06, 2009 | Minn Kota Riptide St Saltwater 80 Bow...
Mar 17, 2009 | Minn Kota Riptide St Saltwater 80 Bow...
Minn Kota Riptide Sp Saltwater 70 Bow Mount Trolling Motor With Autopilot Logo
Top Minn Kota Boating Experts
Mike Marcotte
Mike Marcotte
Andrew Taylor
Andrew Taylor
Colin Stickland
Colin Stickland
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
