Question about Panasonic Viera TC-L32C12 32 in. LCD TV
Poor analogue picture on a new Panasonic digital ready TV. The use of a signal booster doesn't make any difference to the picture.
  • iamsporran Apr 27, 2010
    I have a roof top aerial going straight to the TV. The signal is weak, but I can see a picture. However, when I use a signal booster the picture does not improve.
  • Loretta Northcutt
    Loretta Northcutt May 11, 2010
    It appears that you have a straight connection from this television to the cable outlet with no cable box/receiver. Is this the case?
  • Panasonic Master
  • 736 Answers
The best site to find another antenna is this one
http://www.dennysantennaservice.com/
Then please check this site to see which channels you should be receiving
http://www.antennaweb.org/aw/welcome.aspx
Click on choose an antenna and enter your zip code and click on submit.
Posted on Apr 27, 2010
  • Panasonic Master
  • 8,457 Answers
Buy an used a roof antena or a digital antena will help the signal much better and have longer ranges.
Phillips DVD recorder connection issue?
SCART is designed to carry analogue standard definition content. So if the input signal is high def. it will distort.
Jun 09, 2014 | Philips Televison & Video
I have a panasonic viera 42 in plasma. It has a built in freeview receiver. It is in the bedroom and receives a signal through a booster from the main sky box. I can get free view channels on it but can't...
switch tv to analogue tv and auto tune on tuning menu making sure sky is on. It should find it around channel 69. If quality poor then change output frequency to a lower channel. You do this with sky menu and instruction book. Info is changing RF output in book, or google it.
Apr 30, 2014 | Panasonic PV-M1349 Combo
Panasonic User Manual
as far as I am aware, you need a standard analogue aerial to receive Freeview, not a dish. The aerial plugs into set top box, which is connected to tv by scart. Freeview is different from Freesat
Nov 08, 2013 | Lands Phones
Color went in and out, no i only get fair black and white picture often grainy
I'm assuming here that this tv is being used for analogue reception because on digital you either get a perfect picture or when the signal is weak enough, nothing at all (common when trying to use rabbits ears or in poor reception areas). Assuming analogue then, when the signal is weak (grainy or snowy picture) the colour (called chroma) is automatically turned off because grainy colour is unwatchable. This is normal. Solution, a better aerial to provide a stronger signal.
Jan 20, 2011 | Akai PDP4206EM Television
Hi i have hisence 42 inch tv will not tune in keeps saying no signal yet me old tv is fine
Hi there
I am assuming your new TV is now Digital. If so, it will be looking for a different signal to the old TV which was probably analogue. You may need a aerial upgrade/diagnostic to determine if you are recieving a digital signal. Or you can tune in the analogue channels, by switching the new TV to analogue, through the inputs/menu, and then i suggest autotune.
Hope this helps
TV_Doctor
Jan 03, 2011 | Televison & Video
Panasonic tv no signal?on any channel
Akai model LCT2715 will not pick up any chanels
Mar 07, 2010 | Akai LCT2715 27 in. LCD Television
Recorder has stopped decoding SD digital TV but analogue TV is OK
Dry joint - faulty capacitor on the PC board of the decoder. Found by wiggling the components and resoldering
Feb 07, 2010 | Panasonic Televison & Video
Loss of Digital Shows??
U have cable's or dish's boxs?unplug,replug the box for the software to down load to upgrade.Unplug,replug the tv.Go to the menu set for Air or Cable then rescan all channels
Oct 26, 2009 | iLO V27DMBX Television
Unable to get BBC 1 and 2 on Digital. Both Channels are ok on Analogue but switch to Digital and programmes start at ITV( channel3) Have re tuned since last digital update but still the same. Have used the...
There is not a problem with the TV despite it's age this is can be due to your reception of the digital package for BBC. Have you checked through he full listings? sometimes the BBC channel will be at a different number setting because of the transmitter you are receiving. I assume you are using a digital box, you can enter a menu which will give you an indication of the strength & quality of the incoming signal. Do you pick up some of the other BBC channels such as BBC3 or CBBC? It's possible your aerial strength is a bit weak for the digital BBC package & you may need to have that looked at.
Oct 07, 2009 | Panasonic Televison & Video
Panasonic Viera TC-L32C12 32 in. LCD TV Logo
88 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
