Question about Vizio VW32L 32 in. LCD HDTV
Tv doesn't power up
Can't get tv to power up.
  • Vizio Master
  • 8,457 Answers
Check ur power source with other devices?Yes.than ur tv power supply board is dead.Replaced the power suply board will solved this problems.Tries wesites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Posted on Apr 27, 2010
VC IArt tv doesn't show picture and the power button flashes
There is shorted component/s in the power regulator section to your TV. Check and replace them.
May 07, 2012 | JVC AV-27D302 27" TV
RCA TV doesn't power on
Check the fuse. Check is you smell any burned fume from the TV..
Next time give the model and year of your TV.
Mar 24, 2012 | RCA 20F510TD 20 in. TV/DVD Combo
THE T V WILL NOT POWER ON
plug the cord into the outlet. If the wall outlet doesn't work find a different one. If the tv doesn't turn on with the remote take the plastic off of the batteries in the remote. if this all doesn't work, then there's something wrong with the tv and you should return it and get a new one.
May 16, 2011 | Tatung LD30HL Television
Had a power outage now the TV displays only a black screen, and doesn't respond to any remote functions except for power.
sounds like you may have also had a power spike and possibly fried the tv. have you tried unplugging the tv for about 30 mins and plugging it back in? some tv's have built in surge protectors that need to be re-set
May 14, 2011 | Toshiba 32CV510U LCD TV
Hitachi L26D103. Less than 2 years old. Working fine one day. Turned on the next day and the sound works, but not the picture. This is an issue when in both the TV and DVD modes.
Good day!
If your TV doesn't have a picture even you play a DVD it means there is problem to your TV.It could be the Inverter board or the cold cathode lights is busted.
This are the steps on how to fix that problem.
  1. Remove the back cover of your TV.
  2. After that,plug in the TV and power it ON to perform a voltage data.
  3. Check the the output voltage of your power supply by using multimeter tester (range in DC) then check the 24vdc(supply of inverter board).
  4. If you have 24vdc in power supply output,check also the input voltage of inverter board if have 24vdc.If doesn't check the wire connection from power supply to the inverter board.
  5. If have you input voltage of inverter then check the high voltage output of it,if have at least 500vdc so be careful to check it because it have a high voltage.
  6. If doesn't have high voltage output replace the inverter board and if have a output voltage the cold cathode lamp inside is busted so you have to replace it
The inverter board looks like this:
You can buy it to this link: http://www.shopjimmy.com/catalogsearch/result/?q=Hitachi+L26D103+inverter+board
If this solution will be helpful please rate my answer. Thank you and good luck.
May 06, 2011 | Hitachi L26D103 LCD TV
When I turn on my set, light turns green, then after 30 seconds turns red won't come on
Sounds like there is a problem with the power supply. Try unplugging the T.V. and hold the power button for 30 seconds. Plug the T.V. back in and see if that helps. If it doesn't try switching to another outlet, and if that doesn't work then you may need to replace the power supply which would probably cost anywhere from 140 to 200 for one.
May 05, 2011 | Fujitsu PlasmaVision P50XHA40US 50 in....
Sanyo television doesn't turn off either by using the remote or by turning it off at the tv.All other fuctions work using the remote or directly on the set.Even using the sleep timer doesn't turn...
Unplug the set and hold the power button for 30 seconds. Plug it back in and see if that fixes it. If it doesn't then it sounds like there is a problem on the board underneath the power button. Something isn't allowing the circuit to be cut.
May 05, 2011 | Televison & Video
Please i need manual for norcent lt-3751 lcd 37" tv because this tv dont power on
Make sure the power cable is plugged into the T.V. and the wall outlet. If it still doesn't power on try a different outlet. If that still doesn't work then there might be a problem on the board that needs repaired.
May 05, 2011 | Norcent Technologies LT-3751 37 in. LCD...
Hi my plasma tv doesn`t switch on?
could b flyback transformer, hard to tell with out benc testing , no power is cheaper to fix than picture problems and normally a lot less God Bless
Apr 15, 2010 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Vizio VW32L 32 in. LCD HDTV Logo
104 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
