Question about Uniden DECT 6.0 Cordless Telephone Expansion Handset
I want to reset handset back to factory settings. ie; eliminate one touch answering.
Had a att el52300 base that went bad so bought another one it seems to be working ok. all head sets have out of Range or no Power at base.Tried to clear with answer given but nothing worked Need help
Try the following:
1/ Make sure the power cord is securely plugged in at the base and that it's powered on ie: light is on and working etc..
2/ Reset the telephone base. Unplug the electrical power. Wait for
approximately 15 seconds, then plug it back in. Allow up to one minute for the cordless handset and telephone base to reset.
3/ Place the cordless handset in the telephone base for one minute to allow the cordless handset and base to synchronize.
Manual available here:
at&t el52300 manual
-Charles
Jul 02, 2016 | AT&T El52300 Cordless Phone
Lgl15g Tracfone. How do I hard reset?
With the handset turned off, press and hold the Volume Down key.
Note that a master reset will return the handset to the default factory settings and erase all personal information on the handset. All important information should be backed up before proceeding.
Aug 18, 2015 | Android Cell Phones
Micromax master resetting code all
1.NormalReset - Dial *#7780#
If you dial this code in Nokia handset, it will restore system setting without missing phone memory data (videos, photos, songs).
2. .Deep Reset - Dial *#7370#
When this code isdialed in Nokia handset, it will wholly clean internal phone memory. Entire phone settings and profiles will be deleted, but there is no effect on memory card data.
Remarks -
For Nokia Symbian 60 V1 supported mobile handset (7650, 3650, 3600, 3620, 3660, N-Gage)
you can dial *#7780#*#7370#
Latest S60 mobile handsets, you can dial Deep Reset through another way.
*.Switch off mobile handset first.
*.Press calling key (green), 3 and * keys or (Green calling button + 3 + *)at same time and grip them down.
*.You find a message about format mobile and then release these keys.
*. Password of Reset factory setting code will be either 1234 or 12345.
Nokia X3-02 mobile Restorefactory -
*.Go to Nokia menu lists, browse these options one by one-
*.Menu --settings-- Menu--- Restore Factory Setting
*.Insert phone code 12345and wait few moments to complete restore process.
Nokia 5230, 5800, 5233 and similar mobile handset Restore factory settings, how ?
*.Browse phone menu lists,
*.Then, go to
Menu - Settings - Phone -- Phone mgmt Factory settings
*.Insert security code -12345
*.Without data lost of internal memory, Nokia handset returns in original modes.
Hard reset of Latest Nokiahandset through another code -
*.Switch off mobile handset.
*.press and holdGreen (calling) +Red (End call button) + Camerakeys at the same time along with switch on power of mobile handset.
*.Then mobile asks to insert phone security lock code , so insert12345.
Samsung Restore factory code
*.*2767*3855#
*.*7465625*638*00000000*00000000#
*.#7465625*638*00000000#
or
*.Remove SIM card from mobile handset
*.Once off and on handset
*.Type *2767*2878# to perform internal memory reset
*.Insert SIM card again in mobile.
Samsung Androidsupport handset restore factory code -
Type*#*#7780#*#* - To Factory Restore.
Micromax Restore factory code for all version with Android -
You can use any following below code one by one to perform restore factory of Micromax mobile:
*.1122
*.0000
*.1234
=*symphony> 1122
=*nokia >5071 or 0000
=*micromax> 1234
=*tecno > 1234 or 0000
=*samsung> 1234
=*apale i phone >5869
BACK2HOME
Information from:
http://peperonity.com/sites/a--a.secret.mobile.codes/47096442
Terry
Apr 16, 2014 | Samsung Computers & Internet
Lg ally touch screen stopped working
Likely a defective touchscreen, may be software related.
1. Remove Battery, Attempt to Restart phone. repeat at least twice.
2. Perform a hard/factory reset. a. for most phones the go into your phones setting and look for a reset option. b. Follow the prompt to reset your phone to factory settings. c. Make sure to back up all your data
3. Contact a service representative of your carrier or take the device into your carriers store, most of the time they will recommend doing a hard reset as shown above, they will NOT replace a device without doing a factory reset on the phone.
all goes well they'll likely replace your handset,
Jun 16, 2011 | Cell Phones
Forgot password
remove my passward in my cell
Jun 02, 2011 | Samsung SCH-U470 Juke Cellular Phone
Touch screen color black and has a wireless radio and has a camera
You may want to back up your information and data and master reset the handset, if there is any firmware glitches it would be eliminated and phone should work fine. If problem remains it will be hardware issue as the wireless radio is inbuilt mechanism of the handset. to reset the phone press
* 2 7 6 7 * 2 8 7 8 # from your phone keypad
May 04, 2011 | Samsung GTC3300 Cell Phone
What is the default code to unlock samsung caliber i turned the phone on but i have to put in a code to open phone a 4 digit number is there a default code for that like 9999 or 7777
1.From the home screen, touch Menu
2.From the Main Menu touch Settings
3.Touch Phone Settings
4.Touch Security
5.Touch the grey box then enter the Lock code and touch OK, default lock code is usually the last 4 digits of your phone number
6.Touch Reset Phone
7.Touch Yes to confirm resetting the handset to the factory default settings
Before you reset your Samsung Caliber r860, make sure have back up the important data. Then when you finish the reset, you can transfer the data back to your device.
May 02, 2011 | Samsung Cell Phones
I have an AT&T Spirit phone system. I"ve moved and taken the system with me. The phone now calls out on a pulse mode. Automated answering systems that I call will answer but will not respond when...
Have you try to reset it? If no, Just try to reset it to factory settings.
Remove the AC Adapter from the AC power (either at the base or at the wall outlet) and immediately connect it again. Remove battery from the handset and immediately replace it. Place the handset back into the charger for about 5 seconds. That should reset the phone and put the phone on default.
Take care.
Oct 08, 2010 | AT&T Spirit 6-Button Stard Misty Phone
Wharfedale Florence handsets restart on incoming call
We are having the same problem as you with our Wharfedale phone. Did you ever find a solution?
Thanks
Oct 29, 2009 | Lands Phones
Uniden DECT 6.0 Cordless Telephone Expansion Handset Logo
166 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
