Question about Samsung RS2630SH Side by Side Refrigerator
Getting very hot in the middle betweenthe fridge and freezer
My 2630 is getting very hot between the fridge and freezer seems to not be cooling as well also
  • 619 Answers
The condenser fan located on the bottom near the compressor is not circulating well enough to keep the compressor at a good operating temperature causing the compressor to shut down for longer periods of time until cool enough to run again. Clean the coils good and replace condenser fan and you will be fine. The fan works as a cooler for the compressor. Imagine working in the yard on a hot day wearing a mask over your nose and mouth. Your body shuts down quicker because you have to take more rest due to the restriction of fresh air. Same applies to the compressor. Hope this helps. Rick
Posted on Apr 27, 2010
Testimonial: "Fan was not running at all ... big help ...thank you"
  • 161 Answers
Yeah,what he said.
Posted on May 11, 2010
The beam in middle of refridgerator where both doors rest against while closed is too hot to touch
Is the cooling fan for the compressor working? There is a coil of the condenser line that runs around the freezer side. This will get hot but the cold freezer side keeps it form not getting too hot. It could get very warm if the freezer is not cold yet.
Sep 10, 2014 | Kenmore Refrigerators
Beko CDA751FW/1 mostly on all the time - fridge 4 degC, freezer -30degC
there is no thermostat in cda751fw/1. apparently the pcb controls fridge temperature. which pcb, the main one or the one behind the temp dial I dont know which.
Apr 11, 2012 | Refrigerators
Freezer running, ice maker not producing, hot in middle divder.
The dividing section should be warm, to keep unit from sweating. (by design). Cleaning under the refrigerator was what cooled it down. You cleaned the condenser. The condenser allows the refrigerent to cool down. When it was dirty, the condenser could not get enough air to cool down.
Mar 14, 2009 | Kenmore 57029 Side by Side Refrigerator
Kenmore 5126101 middle separator b/t fridge/freezer extremely hot
There are 2 or 3 things that would cause this. first make sure the condenser coils are not plugged with dust (vacumn or blow them out) next check to make sure the fan that cools these coils is running, (this is the most likely problem). if both of these check out ok then you would need to check to make sure your interior lights ar going off when the doors are closed as these will add extra heat and cause the center rails to run hot. last and most uncommon would be a freon system problem.
fyi there is a hot gas freon line that runs in between the doors to prevent exterior sweating. when poor or no air flow problems for the condenser coil exist it causes this area to become hotter.
One more thing. if you do determine that the condenser fan motor is bad you can put a normal house fan blowing on to the coil to help cool this area down until you can get the unit repaired.
If you need any further assistance leave me a comment here and I'll gladly get back to you. Thanks Peyton
Mar 11, 2009 | Refrigerators
Fridge freezer over heating and is not cooling fridge section
It is normal for the middle strip to be hot. Did you check the temp setting in the fridge section?
Also - you might check for blockage in the bottom. Excessive dirt/dog hair can block the air flow.
Good luck
Jan 18, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refridgerator
Hi. thanks for the question. the heat between the doors is normal . to solve . pull the fridge away from wall .remove back panel. clean all lint in coils .Dust in the coils causes the heat between the doors to get warmer . so cleaning of coils. will solve the problem thanks the appliance doc
Oct 04, 2008 | Jenn-Air JCD2389G Side by Side...
Samsung RS2630SH Side by Side Refrigerator Logo
627 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
