I have a brivis MPS Gas Ducted Heater,but today wall control is not display,please help!!!
SOURCE: Error code 62 on Brivis Me20 ducted heater
When it comes to error 62 resetting the unit probably won't work. Because the NG1/lo is INSIDE the heater it is subject to significant hot / cold temperature fluctuations - causing crystallisation in soldered joints on the PC board and a loss of electrical continuity.
Posted on May 05, 2010
Hi
Error 62 is related to hot surface ignitor (HSI)or/nglo module
you can check the resistance of the ignitor should be less than 10 oms @ 20 degrees
failing that, if you incomming suppy exceeds 270 volt will also result in error 62
Posted on May 15, 2010
Testimonial: "The error did indicate an HSI problem but it turned out to be a fault on the circuit board of the control module, thanks anyway"
SOURCE: Burners on our Brivis Buffalo 52 Ducted heater aren't getting gas
test thermosat for proper operation ie-broken wire-power if good jump stat and check if unit goes on if it does than stat internal problem or wiring problem and needs replacement or repair --if stat good check fan safety/high limit sensor if good would need to check and test thermocouple thats the tube that the pilot flame burns on may be enough to keep pilot burning but not enough to open valve for heat demand
Posted on May 31, 2010
Apr 20, 2014 | Heating & Cooling
Jul 26, 2013 | Cars & Trucks
Apr 25, 2013 | Heating & Cooling
May 31, 2010 | Heating & Cooling
May 04, 2010 | Heating & Cooling
Apr 30, 2010 | Heating & Cooling
Apr 12, 2010 | Heating & Cooling
May 12, 2009 | Heating & Cooling
May 03, 2009 | Honeywell Programmable Thermostat Heater
Jun 10, 2008 | Heating & Cooling
319 people viewed this question
