Question about Brother DCP 130C All-In-One InkJet Printer
Code 50 on screen
Code 50 needs cleaning.How and what do i clean?
  • 4,041 Answers
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 27, 2010
Minolta dialta di183 copier error code c06 50
C 0650 - Faulty scanner home position sensor.
Remove the glass and clean the home sensor.If the scanner moves smoothly remove foreign matter and other obstacles,clean the scanner rails,clean or change the scanner bushing.Place WD 40 oil on scanner bushings.
Dec 02, 2013 | Minolta DiALTA Di183 Copier
Printer Brother DCP-6690cw unable to print 50, sometimes unable to clean 50. please help
A 50 error code indicates a problem with the "maintenance unit".
This unit controls and cleans the printhead and ink delivery system. You will need a technician to figure out if this is the problem or some other component has failed.
Sep 03, 2013 | Brother Office Equipment & Supplies
I need to clean my 50 inch dlp hd tv screen. It is at my dads house and he is a smoker. How would you clean the haze from the smoke? Something I could do right away, without having to buy a special...
do not use Windex. Or any other ammonia-based product. Trust me, ammonia and TV's is not a good combination.Chances are, your instruction manual agrees with me too.That Office Depot Screen Cleaner, along with many others out there, is safe to use - gentle on the screen - and will do a great job at cleaning.Usually that stuff will be < $25 for a decently sized bottle that should last about 3 years for a 50" screen that gets cleaned weekly. Most come with a micro-fibre cloth too. Overall not a bad investment. Will work great on the smoke residue on your tv - along with any computer screens and anything else in the house. Definately worth picking up.
Sep 16, 2011 | Samsung 56" Slim-Depth LED DLP HDTV
UNABLE TO CLEAN 50
This means the encoder strip is out of position. You need a technician to repair it.
Apr 15, 2010 | Brother MFC 6490CW InkJet Printer
My printer brother DCP115C ''UNABLE TO CLEAN error code 50''
Machine error 50 is a error in Purge unit.You can't fix it by yourself and your printer need service.In most case the cost of repair is more than cost of new printer.
Nov 03, 2009 | Brother DCP 115C All-In-One InkJet Printer
Cleaning
It is recommended to use a simple alcohol solution to clean an LCD or PLASMA screen. This solution is made up of 1 part distilled water and 1 part 50% isopropyl alcohol. Be warned that isopropyl alcohol is flammable.
50% isopropyl alcohol is very common. If you find 70%, 91%, or 99% isopropyl alcohol, adjust the formula to use less alcohol and more distilled water.
By mixing these two in a bottle, you will produce a model cleaning solution. Remember not to use tap water -- only use distilled water.
Do NOT use tissues/Kleenex to wipe your screen. That is as ineffective, because they will leave little tissue particles all over your screen . Try and find some microfiber cloth to clean your screen. Cloths that come along with prescribed glasses are usually good.
You may want to clean the rest of the actual screen before moving onto the LCD or PLASMA part. First dampen the cloth with the solution. You should never spray any sort of liquid directly onto the screen. Wipe the screen gently from top to bottom and wait for it to dry.
Be careful not to let the cleaning solution leak into the sides of the monitor. Also, be certain that you do not press hard on the LCD or PLASMA screen. You can permanently damage an LCD or PLASMA screen by pressing on it too hard.
If there is just dust on your screen, there is no need to fully clean it. To remove dust all that must be done is to wipe it away with a microfiber cloth. Simply wipe your screen from end to end gently with the cloth. For smoke filled room, It would be good to clean it once a month when the smoke is not around during cleaning.
Apr 13, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Cleaning plasma screen
I wouldn't use the screen cleaner as I have seen it discolor the Front panel of the plasma before. Then the panel needs to be replaced.
Just put a small amount of water on a VERY soft clothe and clean it like you would a window. Do not spray onto screen as that can cause problems.
Mar 28, 2009 | Pioneer Elite PRO-1140HD 50 in. Plasma...
What products can I use to clean my childrens hand prints off of the screen?
The recipe is easy: Mix Isopropyl alcohol and distilled water in equal parts (50/50) inside an empty Windex-like bottle. Do not use tap water! Doing so will leave white smears on your screen after cleaning it up because of the dissolved minerals inside the water. When finished mixing, just close the bottle using the "spray" adaptor that comes attached to it.
Next, you will need to find a good, soft piece of microfiber cloth to clean your display. Avoid paper tissues at all cost! Using those on your screen would be just like scrubbing sandpaper on it and may scratch it permanently. You wouldn't want to do that right?
Now that we have everything we need, start by turning off your screen. Dampen your piece of soft cloth with your cleaning mixture and then wipe the display gently from top to bottom. Never spray liquid directly onto the LCD. When you're done, wait a few minutes to let your screen dry, and then turn it back on. Voila, you're done! Your screen should now be sparkling clean.
Mar 05, 2009 | Vizio VW37L 37 in. LCD HDTV
How to clean 50 in rear projection tv
For the screen Philips make projection screen cleaner this is a spray with brush that is made for cleaning tv. The CRT's you can use some type of glass cleaner, not to waste on board.
Oct 05, 2007 | Philips 50P8341 50" Rear Projection...
Projection tv
Yes you can safely clean tv, just remove front speaker panel and you should see screws holding up front prot. screen. Becareful not to snap screws. You can take screen out and there is a mirror that you can clean and 3 lenses.
Apr 01, 2007 | Hitachi 50UX57B 50" Rear Projection...
Brother DCP 130C All-In-One InkJet Printer Logo
95 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
