Question about Cisco Computers & Internet
GNS 3 , IOS images "quemo host" configuration help
Those who are well versed with routers, and router simulators please help me configure quemo host on the GNS 3 , i hv rest of the router IOS images...so just need the quemo host one ...
im waiting ;))
    Producer:
    Uploaded 30 video answers.
  • 95 Answers
Hi Jhonny583,
Im a Cisco certified Network Associate (CCNA) and im well versed with routers and GNS 3..i have included a video tutorial to show how to install qemu hostHope it helps
Goodluck :-)
was i helpfull ?, please rate me.
Posted on Apr 27, 2010
Testimonial: "cool man !!"
I want to update the IOS on a CISCO Catalyst 2950. I'm connected via console:serial to my Windows 7 Ultimate machine. I've also got PuTTY installed. The internet is being routed thru a Linksys NR041. What...
Please check whether the console cable is connected properly.
use Hyperterminal to configure the router.
Select the ISO image location in the computer and use the appropriate commands to copy it to flash.
Jan 22, 2011 | Linksys Computers & Internet
I have cisco 1841 router stuck at Rommon> only IOS is ok,but still in this mode/.
what shows the following?
dir flash: If IOS is ok the follow the below step The router will guide you through changing the registry. You want to press y to chang the configuration. The only other change you need to make is the change to the console baud rate, set that to 7 (115200).
do you wish to change the configuration? y/n [n]: y
enable "diagnostic mode"? y/n [n]:
enable "use net in IP bcast address"? y/n [n]:
enable "load rom after netboot fails"? y/n [n]:
enable "use all zero broadcast"? y/n [n]:
disable "break/abort has effect"? y/n [n]:
enable "ignore system config info"? y/n [n]:
change console baud rate? y/n [n]: y
enter rate: 0 = 9600, 1 = 4800, 2 = 1200, 3 = 2400
4 = 19200, 5 = 38400, 6 = 57600, 7 = 115200 [0]: 7
change the boot characteristics? y/n [n]:
Configuration Summary
enabled are:
console baud: 115200
boot: the ROM Monitor
You must reset or power cycle for new config to take effect.
rommon 2>
3. When you reset the router in your console window you will see characters that you cannot read. You have to stop the session and set your baud rate to 115200. This will let you increase the speed that you use to transfer the file.
4. At the rommon prompt enter xmodem -c {filename}
5. When prompted, enter y to continue
6. From your hyperterminal prompt, click on transfter then send file
7. Select the IOS image then change the protocol to xmodem via the dropdown box then click send.
8. After the IOS has been downloaded, change the boot order by using the confreg 0x2102 command.
Dec 18, 2009 | Cisco (1841) Router (cisco1841)
Dhcp setup on a Cisco 2851 router
Let's look at how to configure basic DHCP on an IOS-based router. For this example, we'll start off with the default configuration on a Cisco 2611 router running IOS 12.2. (The configuration should be the same—or very similar—on all IOS-based routers).
To begin, connect the router's Ethernet port to a switch, and connect the switch to a laptop, which will serve as the DHCP client.
To configure Cisco IOS DHCP, follow these steps, which include sample commands:
1.Configure an IP address on the router's Ethernet port, and bring up the interface. (On an existing router, you would have already done this.)
Router(config)# interface ethernet0/0
Router(config-if)#ip address 1.1.1.1 255.0.0.0
Router(config-if)# no shutdown2.Create a DHCP IP address pool for the IP addresses you want to use.
Router(config)# ip dhcp pool mypool3.Specify the network and subnet for the addresses you want to use from the pool.
Router(dhcp-config)# network 1.1.1.0 /8 4.Specify the DNS domain name for the clients.
Router(dhcp-config)#domain-name mydomain.com5.Specify the primary and secondary DNS servers.
Router(dhcp-config)#dns-server 1.1.1.10 1.1.1.116.Specify the default router (i.e., default gateway).
Router(dhcp-config)#default-router 1.1.1.17.Specify the lease duration for the addresses you're using from the pool.
Router(dhcp-config)#lease 78.Exit Pool Configuration Mode.
Router(dhcp-config)#exit
I hope this is helpfull for you.
Thanks
Vikrant
Oct 26, 2009 | Computers & Internet
I have a used 802.11g/2.4Ghz wirless router and i dont know how to use it cause i dont have a cd or directions it was used by my cousin like 3 years ago i would like to use it please help. I have a cable...
First you have to re-configure the Router according to your Internet connection (ISP setting). Any software disk is not required to configure the Router. Just login to your Router and configure.
To login to your Router just use the IP 192.168.0.1 (type in Web Browser) to get in.
The default Username is "admin" and there may be no password or the default password may be the 'password'.
Now input the details like your ISP username, password, IP address etc. to configure the Router.
You may also refer the User Guide of the Router to configure it.
Better do a Google Image search for for information:
http://images.google.co.in/images?hl=en&um=1&sa=1&q=how+to+configure+wireless+router&btnG=Search+images&aq=f&oq=&start=0
Good Luck!!!!!!!!!!!!!!!!!!!!
Sep 05, 2009 | D-Link High Speed 2.4GHz (802.11g)...
Hi all. Now i'm lose IOS of cisco 2691. help me! and give me how to load IOS to Cisco 2691 by tftp. thanks alot
Recovering Cisco IOS Software imagesIf your Cisco router experiences difficulties and no longer contains avalid Cisco IOS software image in flash memory, you can download a newCisco IOS image using one of the following ROM monitor commands:
blank.gifxmodem—(AllCisco 2600 series routers) Use this command to copy a Cisco IOS imagefrom the console, if the computer attached to your console has aterminal emulator with Xmodem capability. See the "Copying an Image from the Console Using the xmodem Command" procedure.
note.gif Note blank.gifDownloadinga Cisco IOS image from a console is very slow. This procedure should beused only in an emergency and is not recommended for normal Cisco IOSimage upgrades.
For the fastest possible download from a console, set the console speed to 115200 bps by using the confreg ROM monitor command. See the "Configuration Register Commands" procedure.
blank.giftftpdnld—(ExceptCisco 2691) Use this command to copy a Cisco IOS image from a TFTPserver that is accessible through the FastEthernet 0/0, Ethernet 0/0,or Token Ring 0/0 port. See the "Copying an Image from a TFTP Server Using the tftpdnld Command" procedure.
note.gif Note blank.gifThetftpdnld command is not available on the Cisco 2691 router. Therecommended method for installing a Cisco IOS image on a Cisco 2691router is from a CompactFlash memory card loaded in the externalCompactFlash memory card slot. See the "Entering Boot Commands" procedure.
P.S.: If this information was helpful, please rate this solution.
Mar 12, 2009 | Cisco 2691 Series IOS
Auto backup IOS of router.
If you want to back up your Configuration on any Cisco Router, You can just use RANCID (http://adi-sunardy.net/2008/12/24/how-to-automating-cisco-router-switch-firewall-backups-on-fedora/).
Or, some other solution:
  • ciscowork
  • ziptie
  • solarwind
  • cirrusmanager
Or follow these instruction: http://www.techexams.net/forums/ccna-ccent/22447-how-setup-tftp-server-backup-restore-2500-ios.html
Or You can read this: http://blogs.techrepublic.com.com/networking/?p=532
Hope it'll help
Mar 11, 2009 | 2wire HomePortal® 1800HW Router...
How do my router configure
open your browser. in the address line type in 192.168.0.1
username = admin
password = system
You should be able to make configuration changes there
Jan 14, 2009 | Cisco IOS
Help me plz
cisco routers make use of an IOS software for configurations.
you have to connect the router to a computer system through an hyper terminal program in order to access the router command interface,there is no way you will be able to configure this router without having cisco configurations knowledge.
the steps could be complex/complecated for a novice.but all the same,
after running the hyper terminal program on your computer to connect the router(start-accessories-communication-hyper terminal) make sure you use cisco serial cable or a cat5e roll over cable.
press the enter key once and type 'enable' then press enter,
configure terminal,to take you to a global configuration mode.
i will advice that you should contact a cisco person in your area for help
Apr 23, 2008 | Cnet CN UM56-RS (CNUM56-RS) Modem
Cisco 1721 router problem
Does the router boot to rommon mode everytime you turn it on?
There are two reasons why the router could be booting to rommon mode
1. There isn't a valid ios image loaded in flash memory
2. The configuration register is set to a number that ends with '0'
Change the configuration register setting to a number that ends in '2'. (i.e. 0x2402)
You do this with the command: confreg 0x2402 <hit enter key> (in rommon mode)
Reboot the router and it will first search for boot system commands in the startup config, if none found it will boot to the first valid ios image in flash memory.
If there isn't a valid ios image in flash memory, the router will continue to boot to rommon.
Apr 12, 2008 | Computers & Internet
Computers & Internet Logo
1,076 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
