Modle AEQ6000ES2
The error code means a key is stuck; enter the service diagnostic
mode and perform the key test to determine which key is stuck.
Once the key is determined, try to unstuck it; replace the
electronic control board (part number 134557201) if the error code
continues to appear after the button is unstuck.
Press and hold simultaneously the Select and Cancel buttons for six
seconds to reset the control then immediately after the buzzer sounds,
turn the cycle selector knob 5 clicks counterclockwise to position the
cycle indicator light second (Touch Up) from the bottom.
Press and hold the Options and Cancel button simultaneously for two
seconds to enter the service diagnostic mode. The buzzer will sound
three times and all of the LEDs will flash indicating the service
diagnostic mode has been entered successfully.
Rotate the cycle selector knob 4 clicks to the Heavy Duty cycle; the
motor runs with the heater off. The buttons can now be tested. Press
each button and all corresponding LEDs should flash; otherwise the
button is stuck or a faulty. Unstuck the key and perform the key test
again; replace the control board if the problem is not resolved.
Access to the control board requires the removal of the top panel and
the console. Disconnect power to the dryer prior to servicing to avoid
the risk of electric shock.
Remove the two screws attaching the top panel to the rear of the dryer then slide the panel rearward and lift it off the dryer.
Remove the four screws, two on each side, securing the console
to the front panel then flip the console forward. Disconnect the wires
from the control board and lift the console off.
Remove the five screws mounting the control board to the console and
lift the control off. Remove the control board's rear cover by
releasing the two locking tabs the flip the cover off the control
board. Try to unstuck the faulty key and reassemble the dryer in
reverse of the disassembly steps
Need Aeq6000es2 to stop LOC
